sjm autoprod
Old 05-23-2012, 02:11 PM   #1
Billabongi
Billabongi's Avatar
Drives: '17 2LT/RS 50th Camaro
TF3 Stripes Care
Ok so I searched and found a couple of things but nothing quite clear.
I have the TF3 stripes and im wondering how to properly care for them as they are part matte black and part carbon fiber.
I saw suggestions for Meguiars Natural Shine Protectant, would that work? I like the idea of that since it has UV blockers.
Thanks in advance!
Billabongi is offline   Reply With Quote
Old 05-23-2012, 02:22 PM   #2
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
from what little I've seen of them its pretty much all matte... the simulated CF is pretty much just a different matte than the black.
that being the case you want to avoid abrasives (polishes) and waxes.
clean with soap/water for the mostpart... you can use detail sprays and waterless wash for light dust removal and wipe downs.
if they start to look chalky or uneven a water based low gloss dressing (like our Super VRT) can be applied for protection and to even out the appearance.
Old 05-23-2012, 02:50 PM   #3
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged V6
This, I use the fine machine polish from Adams on the revive blue hex applicator then the VRT On a block and I get so many complements
Lil' Nasty is online now   Reply With Quote
Old 05-23-2012, 03:36 PM   #4
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
Yes you can use Meguiar's natural shine no problem. You can also use some paint sealants that dry clear. I have a simulated carbon stripe hood and I used BLACKFIRE Crystal Seal on it with no problem. It actually gives a slight sheen (which I prefer) and water will bead up to a month on it with no worry about water run off.
