Old 05-23-2012, 03:30 PM   #1
netz
Drives: 2012 2SS/RS LS3
Amp selection help!!
I'm wanting to upgrade my BA sound system with some speakers I already have.
(2) 6.5" - 60w RMS / 260w MAX @ 4ohm
(2) 6x9 - 80w RMS / 360w MAX @ 4ohm
(2) 12" - 300w RMS / 1200w MAX (already have amp for these)
My main question is what would be the best quality amp for this setup at a good price? My next question would be how can I go about hooking both up without cutting into factory wires? Would the FARK harness work alongside the X3 harness? I want to keep the factory wiring and integrity of my car just in case the day comes where I want to sell her I would be able to easily revert back to stock. Thanks in advance everyone!
netz is offline   Reply With Quote
Old 05-23-2012, 05:41 PM   #2
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
MB Quart ONX4.60 - 4 x 60W, $110, nice features for tuning
Precision Power BK340.4 - 4 x 55W, $115, similar features
Those are both pretty good quality amps and very good for the price. If you want to spend more (like up to $300), you have some better options, but I was looking for quality 60W x 4 on the cheap.
The FARK kit actually includes the X3 harness, so yes.
That cover everything? What brand are your speakers?
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Visual Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Pioneer DEX-P99RS * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 05-23-2012, 08:55 PM   #3
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
Boston Acoustics GTA-704 • 70 watt x 4 • $165 at crutchfield on sale now, if you wanted better sound quality than the 2 above.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Extendolator • SOLO Hi-Flo Cats and Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 05-23-2012, 10:07 PM   #4
netz
All Pioneer. The subs are Premier TS-W12PR which I had in my Escalade EXT and they are the cleanest hitting subs I've personally listened to. The 6.5's are TS-D1602R and the 6x9's are TS-D6902R. What all will I lose with this setup as far as factory speakers? Not quality but which actual speakers will just be sitting there doing nothing?
Old 05-23-2012, 11:28 PM   #5
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
Hi Netz. The Boston amp that Yzark mentioned is a good buy right now and offers you a good match on power for your speakers. Others you could consider in the same neighborhood of power and won't break the bank are the Rockford PBR400X4 (which I love the size of) and the JL JX 360/4.
http://www.crutchfield.com/I-rCHVc111/App/Product/CompareTo.aspx?compareItems=01|065GTA704&compareIt ems=01|136JX3604&compareItems=01|575PBR3004&g=3470 50
CrutchfieldBrooke is offline   Reply With Quote
Old 05-24-2012, 12:23 AM   #6
darkrider01
I like Pioneer. I think they perform a lot better than their price would indicate, and everything I have ever seen from their Premier line I liked.
As far as what you will lose, you don't have to lose anything. Since your 6.5's are coaxial, you could retain the factory tweeters, but I recommend against it (the tweeters are 4 ohm, and dropping the channel load to 2 ohm might overpower them). The only thing you would lose by replacing the amp would possibly be the center channel (since your Pioneers each have tweeters.
http://www.crutchfield.com/App/Produ...R3004&g=347050
I like those Rockford Fosgate Punch Boosted Rail (PBR) amps. They are so tiny. Only problem with them is that they are not intended for less than 4 ohm loads. It wouldn't be a problem in the op's case if he only hooks the new speakers up though.
Old 05-24-2012, 12:54 AM   #7
Kevinshawnm
Biggz
Drives: 2010 Camaro 2SS L99 Rally Yellow
What amp are you currently using for your subs, I personally always like to stay with the same brand?
Kevinshawnm is offline   Reply With Quote
Old 05-24-2012, 02:48 AM   #8
netz
I have a Memphis 1000w class D amp pushing the subs. I've always liked Memphis amps and it being 1 ohm stable was a plus for me. I have the subs wired up to 1 ohm so I am slightly overpowering the RMS on the subs but they can handle it and it sounds amazing.
Edit: I also keep the gain on the amp turned down low to help offset some of the overpowering.
Old 05-25-2012, 05:10 AM   #9
netz
I think I'm going with this amp. I guess it's just my personal preference but I've always preferred to overpower my speakers than to overpower the amp. Obviously I don't have to give the speakers all the power but I just don't like it when I can't give them enough. Thanks to everyone for their help and opinions!!
Old 05-25-2012, 09:35 PM   #10
CrutchfieldBrooke
Hope you enjoy the amp, it'll work great for the power your speakers need.
Old 05-25-2012, 11:52 PM   #11
Kevinshawnm
Biggz
Is it the small silver amp?
Old 05-29-2012, 11:34 AM   #12
netz
It's black and silver. The model number is Memphis 16-PRD1000.1
