Old 05-13-2009, 11:30 AM   #1
Richochet83
Richochet83's Avatar
Drives: SIM 2LT Camaro RS
Maintenance costs?
Do you think it will be expense to maintain this car?
I never had own a high performace sports car before so this will be my first one. I had a Monte Carlo but the parts for that car wasn't so bad. So I just wanted to hear some input from you folks.
Richochet83 is offline   Reply With Quote
Old 05-13-2009, 11:32 AM   #2
Camaro509
Camaro509's Avatar
Drives: 2010 2SS/RS Black
I don't believe it will be any more expensive that any other modern car. Most issues should/will be covered under warranty, so no, I don't think it'll be bad.
Understeer, Oversteer, Wheel Alignment (Camber etc), Torque, Horsepower, Camaro
Fold for team 11108 to help find a cure!
Folding@home Stanford's Research DC Program.
Camaro509 is offline   Reply With Quote
Old 05-13-2009, 11:33 AM   #3
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Other than the 3 quart increased capacity of the LS3, I don't forsee any other major increase in maintenance.
My 145k T/A was not that bad... As long as you use top tier fuel, change your fuel filter and use common sense preventive maintenance approach, you will be fine.
I used Pennzoil Platinum and K&N filter on the LS1 for it's life and did not burn any oil.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 05-13-2009, 11:47 AM   #4
Jeffro19
Jeffro19's Avatar
Drives: 2016 Silverado High Country
Just when you need to get new pirelli p zero tires at $400.00 each. Ill prob go to bf goodrich once mine need to be replaced.
Previous Camaro's - 2002 Z28 6 spd manual, T tops, Sebring Silver - 2010 2SS 6 spd manual, Cyber Gray Metallic
Current Vehicles - 2016 Silverado High Country, Daily Driver
Jeffro19 is offline   Reply With Quote
Old 05-13-2009, 12:01 PM   #5
Richochet83
I second that. I not doing the P Zero tires again unless I can find then less that 200.00 a pop
Clutch replacement costs? - Aisin Warner AY6 MT rolnslo Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 10 04-23-2014 07:08 AM
Insurance Costs??? ctk1 5th Gen Camaro SS LS LT General Discussions 34 12-03-2008 11:39 AM
option costs teamlynn1 5th Gen Camaro SS LS LT General Discussions 5 11-09-2008 07:50 AM
Maintenance reference The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 09-18-2008 02:35 PM
New car maintenance AerospaceGuy General Automotive + Other Cars Discussion 4 04-08-2008 07:44 AM
