| 4th Generation Camaros 1993-2002 |
Thread Tools |
![]() Drives: Red 95 Z28 Join Date: Apr 2011
Hey everyone so just as of today as I was leaving work my car wasn't starting, it would start then die. Then when I gave it gas it started right up. Sense then, every time I start my car I have to do it. previously of today it was always took a couple cranks to start then within the past few weeks it started getting worse where it would take a bit longer. Then this happened. now I question could it be the idle air control valve or a fuel pressure problem? im not sure. any advice to this would help me out a ton. :(
not enough fuel squirting through maybe injectors
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 3/4" LTH w/ high flow cats, roto fab cai, corsa exhaust, rx catch can, hurst short throw shifter. stage 3 comp cam, 3.91 gears 445rwhp 410 rwtq all installed and dyno tuned from slowhawk performance. |
![]() ![]() ![]() ![]() ![]() Drives: 6th Gen Join Date: Apr 2010
Throttle position sensor? MAF?
fuel delivery, maybe plugs?
what should I start with to diagnose my problem? because Id like to see if its the easier things rather than taking the journey down the spark plug road. any advice would be appreciated.
#6 |
![]() Drives: l99, procharged,full borla exhaust Join Date: Apr 2012
lol I hate to say it but could it be opti?
#7 |
![]() Drives: Check Signature :P Join Date: Mar 2012
You can get a guage to check fuel pressure, which would be first thing to do, but unfortunately almost always these types of issues are the opti on these years of cars.
Vince
2012 CRT 2LT 93 Z28 V8/A4 Black/Black 91 RS Vert V8/A4 Black with Pink Flames 89 Iroc-Z V8/A4 Copper/Grey 84 Z28 V8/A4 White/Blue 77 LT V8/M4 Aqua/White 71 V8/M6 Black/Black (someday if I ever get home to work on it) |
#8 |
I hate Optis lol wonder what gm was thinking when they put them in and right behind the water pump
#9 |
![]() Drives: 2010 1SS LS3, 1998 K1500 5spd Join Date: Aug 2010
Sounds like a fuel control problem to me, such as an ect sensor. The sensor is sensing a false temperature adding too much fuel and creating a hard start problem. That would explain having to work the throttle to get it to start (more air when the throttle plates are open). I'm not 100% sure that's your problem but it would be something to check into.
*ASE Master Certified. Now working on GM World Class Status
*2010 1SS, hennessey cold air intake, SW long tubes, catless midpipes, flowmaster catback, foose 20" wheels, custom tune with HP tuning software. *1998 Chevrolet K1500, 6' superlift, 35' pro-comp tires, cammed 355ci with forged internals, 4.56 gears, eaton locker, k&n cold air intake, shortie headers, custom tune with Hp tuning software. |
| Tags |
| fuel, idle, idle start up, starting |
| Thread Tools | |
