Old 05-24-2012, 08:51 AM   #1
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
Stock ZL1 .vs. Torq Heat Exchanger!!
We are finally able take some photo's of our Dual Pass Heat Exchanger .vs. the tiny inefficient stock heat exchanger. This is a 100% direct bolt on and uses stock OEM ZL1 hoses, stock pump location, etc We have TONS in stock ready to ship.
Our heat exchanger was among the first designed for the Camaro and first for the ZL1. This assembly was designed using real world testing, fitment as well as CAD data made available through the SEMA technology transfer program. We have tons of these in-use on the street and strip keeping some of the fastest and highest HP superchrged cars in the country cool.
When we set out to design a heat exchanger for these cars we used our years of testing/installing and heat exchanger use in the Ford (03 cobra and GT500) markets to assist with the R&D. We knew going too big did not mean the best cooling. One way to help reduce these intake temps and the risk of damage is to add more fluid into the inter cooler system which in turn helps lower intake temps by dissipating heat.
Torq Heat Exchangers are TIG welded and feature furnace brazed cores with no epoxy. Each unit is pressure-tested before it ships
Torq Dual Pass .v.s Stock
Radiator Style: Crossflow
Overall Width (in): 26.25" / 23.5
Overall Height (in): 11.375 / 12.00
Overall Thickness (in): 2.0" / .750
Row Quantity: Dual Pass / Single Pass
Core Height (in): 11.0 in. / 11
Core Thickness (in): 2.0 in. / .650
Core Width (in): 26.00 in. / 21.5
Fan Included: Optional / Not
Notes Torq's is 298sq.in Front Face Area!
Whenever you add more boost to your car, cooling becomes extremely important. Whether it be on the street or at the track the warmer the car runs the more timing gets pulled. In addition to that an excessive amount of heat known as heat soak starts to take place. This keeps the car down on power and running less efficient. This again can be helped by adding more fluid into the cooling system. The temperature of the inter cooler fluid will lower and cool down faster in between runs. You can do all this with the addition of the Torq Double Pass Heat Exchanger and dual fan setup.
Meister@Torq is offline   Reply With Quote
Old 05-24-2012, 01:34 PM   #2
Meister@Torq
6rwhp and 6rwtq by keeping the temps down. No matter how hard you beat on it the recovery is simply amazing. With the stock HX the temps would continue to rise after a run...not anymore! Drops down to 100F within 10 seconds
Just at idle we are noticing a 15* drop in IAT2's with the larger HX with fans and increased capacity of fluid
Full data coming shortly
Old 05-24-2012, 01:51 PM   #3
ZmbHord
2012 ZL1 #0012
Drives: 2012 ZL1 #12 - CONTAGION
Definitely interested, do you have pricing yet?
ZmbHord is offline   Reply With Quote
Old 05-24-2012, 03:29 PM   #4
Meister@Torq
You can see a detailed writeup and data here:
Torq ZL1 Heat Exchanger Data and Testing
Pricing is on our website or you can PM me for more info. These are ready to ship and in stock.
Old 05-24-2012, 07:33 PM   #5
crg
Drives: '68 Camaro SS, '74 Corvette
haven't been up close and personal with a ZL1 yet. Is the intercooler seperate from the radiator or is it intergal like the trans cooler?
crg is offline   Reply With Quote
Old 05-25-2012, 07:48 AM   #6
Meister@Torq
It is a stand alone unit designed strictly for the supercharger unit
Old 05-27-2012, 01:50 PM   #7
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
link to website?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 05-29-2012, 03:35 PM   #8
Meister@Torq
I cannot post direct links to the website. Please PM me for more info
