Solo Performance
Old 05-24-2012, 12:20 PM   #1
Stalkker66
Stalkker66's Avatar
Drives: 2012 Imperial Blue Metallic
2012 CAMARO SS STARTER CLICK THEN DELAY START
Hey guys, I am new to the forum. Just got my 2012 camaro ss a few weeks ago. now have 700 miles on her. Noticed an issue last week that i dont think is normal. When i turn they key to start the motor, I hear a click (probly starter relay) then a second delay and then the motor cranks over and starts. This does not happen all the time. it worked fine yesterday twice in a row and then clicked with a delay last night. no rime or reason there. Im gonna have to go to the dealer but its time away from my job and a pain. Its brand new and i wouldnt think there would be issues already.
Any ideas on what this may be. Also i replaced the battery in my key fob and it didnt change anything.
Thanks guys.
Jeff
Stalkker66 is offline   Reply With Quote
Old 05-24-2012, 12:23 PM   #2
Ringo64
Forever Pontiac
Drives: 2012 Black 2SS/RS
Is this with the remote start? I confused cause you say turn the key then you also replace the key fob battery...
If you're turning the key in the ignition its not using the battery from the fob The remote features only use the battery in the key fob, once you're in the ignition its a regular key.
Overall go to the dealer, they'll fix it as you should be under warranty
Ringo64 is offline   Reply With Quote
Old 05-24-2012, 12:25 PM   #3
Coyotekiller
Drives: 2012 AGM 2SS
Sounds like a bad ground. Mine is slow starting but not like your describing.
Coyotekiller is offline   Reply With Quote
Old 05-24-2012, 02:13 PM   #4
Chevrolet Customer Svc
Drives: GM Vehicles
Thanks guys.
Jeff
Congratulations on your new Camaro! Going to the dealership, as Ringo64 mentioned, is the best thing to do if you feel like this is a concern you are having. Your dealership should be able to diagnose the issue you are experiencing and from there will be able to check your VIN for any applicable warranties. If you have any additional comments or concerns, please don't hesitate to contact me via PM.
All the best,
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 05-24-2012, 08:44 PM   #5
SS Mike
SS Mike's Avatar
Drives: 2010 Camaro SS/RS CGM M6
I have had this issue for nearly 2 years. Started before I had my car supercharged. It would click one or 2 times before starting. Over time it got worse and worse to a point that sometimes it would click 5 or 6 times, and I would have to remove the key and retry it a couple times before getting it to crank over. I brought it to the dealer, they said it was a bad battery. They didn't want to replace the battery because I had the supercharger on, but I told them that not only was the issue not related, and my car was under warranty for this, but I'm sure the battery had it's own warranty considering the car was less than a year old at the time. They replaced the battery and it did it the second I left the lot. They had no other suggestions and didn't want to take the car in at that time.
Recently I was in the shop for some upgrades and decided to have my mechanic check it out. He put his own battery (with 750 CCA) on it and it seemed to start just fine. I was able to use bump start for the first time in over a year! So I decided to swap out the battery. We put one in with 900 CCA and it was working just fine for a few days. Then it started clicking again. It'll only click once or twice now then start, but it still has a very slow crank. The only thing I can think is that the starter is bad, or something in the car is draining the battery while I'm not using it so it's not as strong when I go to start it.
I am going to get the started swapped out for a new unit and see if that solves the problem. If not then I guess look for a power drain somewhere. I've checked the grounds and can not find any bad ground that would be causing this issue.
I'll keep you guys updated!
Vortech V-3 Kit, ARH LT's, Custom Exhaust, Aeromotive A1000 Fuel System, Custom Tune - 582 rwhp 533 rwtq
22" Modulare H2 Wheels, CF Hood, Trunk, Spoiler & Roof by Carbon by Design, Custom Steering Wheel from P-Factor
Brembo GT BBK, Alpine INA-900, Alpine Type-R Speakers, Hurst Shifter, APR Splitter, Custom Quad Tip Diffuser
CKS C1 Coilovers, Falken 452 Tires, 265/35/22 & 285/35/22, Custom Grille, AAC Halos, and much more to come!!
SS Mike is offline   Reply With Quote
Old 05-24-2012, 10:18 PM   #6
Stalkker66
Stalkker66's Avatar
Thanks for the info...that's a really crappy situation. That's not a good sign for me haha. I made an appointment for Saturday so ill let you guys know how it goes.....also, an update, driving home from work tonight and noticed the volt meter was reading 12v while driving. that's not a good thing either. when i got home i shut it off and went to start again and it was real slow. so it could be a charging issue or regulator. most likely the dealer will not see any of these symptoms though. ill keep you guys posted.
jeff
Old 05-25-2012, 12:38 PM   #7
Stalkker66
Stalkker66's Avatar
So i just got back from the dealer alittle while ago. First off, my car wouldnt start in the service dept bay when the "grunt" tried to move it to a lift. They called a tech over to help. Even with that, the tech said they could not recreate the problem of the starter or the clicking or delaying start. (so why is the grunt having the same issue at the dealer?) They said that there is a bulletin #2775683 stating that the key needs to be locked in the open position properly in order to recognize the transponder......Personally i think that is a load of crap. Even when it clearly would not start at the dealer they still were telling me nothing was wrong. What kind of crap is that? Obviously they saw the problem. Just cause they couldnt make it do that again dosnt mean its fixed. Ill just be somewere important when it acts up again. The car did start fine for me when i left the dealer but who knows when it will strike next. If the key is an issue i think its probably a poor ignition mechanism in the steering column maybe. Bottom line is that now i will be thinking about wether it will start or not every morninig and thats annoying. Like russian roulette i guess. Fun stuff. Waist of time at the dealer today!!!
Thanks for letting me vent...
Jeff
Old 05-25-2012, 02:59 PM   #8
Coyotekiller
My voltmeter has always read 12 volts while driving.
Old 05-25-2012, 04:54 PM   #9
Stalkker66
Stalkker66's Avatar
Really? It shouldnt. They should always read approx 14.5v to charge the battery. Running 12v will actually hurt your battery.
Old 05-25-2012, 07:17 PM   #10
90503
Drives: 2011 2SS/RS LS3
I'd say you are correct about the volts, especially right after starting it should go well over twelve, then may get closer to 12 after running for a while....It sounds like a good old fashioned starter solenoid that is hit or miss...Not sure, but they might be internal on starters these days...I would check yourself underneath and make sure the wires are tight on the starter/solenoid...if loose, could be why there's a "delay" and why you show no charge from time to time...If all tight, I'd say you got starter problems...good luck!
90503 is offline   Reply With Quote
Old 05-30-2012, 10:16 PM   #11
Stalkker66
Stalkker66's Avatar
OK guys, another update.....The car had a start failure again at the mall about a minute from the dealer (luckily). The car would not start at all. No clicking, cranking or anything. So, after a few minutes, i opened and closed my door and it started. I went over to the dealer and told them the problem once again. They took the car and held it to check. After a full day of checking relays, connectors etc. they found it to be a loose ground connection from the engine to the body. Once tightened the car acted fine, charged fine and starts fine. I guess the loose ground was not allowing the computer to act properly. So, now it is all good. So, if any of you have this issue i suggest checking grounds. Ill let you guys know if the car acts weird again.
Thanks guys for your support.
Jeff
Old 05-30-2012, 10:24 PM   #12
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Could be anything, failing relay / bad connection / failing starter / ill battery. Intermittent problems can be tricky and hard to duplicate in the shop.
You can bet it will get worse.
two_wheel_mayhem is offline   Reply With Quote
Old 05-30-2012, 10:24 PM   #13
two_wheel_mayhem
Oops too late
Old 05-30-2012, 10:45 PM   #14
Coyotekiller
That's what I thought too. But it's not hurting anything, so it's not gonna get fixed lol. My luck is it will start acting up once I void the warranty lol
