Old 05-24-2012, 03:16 PM   #1
2012-2SS
2012-2SS's Avatar
Drives: 2012 Camaro 2SS/RS
Clutch issues, new pedal assembly? - UPDATED 7/13/12
So the other day I went for a clutch dump to spin the tires a little and the pedal got stuck half way down. (I've read this is common) So since i was on the gas heavy, the engine shot to the rev limiter and immediately smoked the hell of the clutch, and I'm talking seriously visable smoke.
Two days later my car still smells like burnt clutch and it chatters a bit so I stopped at the dealer today. They service rep stuck his head in my car and said yup its gone. So since its still under warentee they are replacing the clutch and they said there is a TSB out about the clutch pedals sticking. The solution is an updated clutch pedal assembly. The parts are on order and will be installed next week. But has anyone heard of this updated pedal assembly? Will it really prevent the pedal from sticking again or is it just a bandaid fix?
2012 Camaro 2SS/RS, Hurst Short Throw, IdealG M/C, Pypes Pipe Bomb, LSR Cold Air Intake, LSR Toe Links/Lower Control Arms Clear Image headers, high flows, Slowhawk tune
1974 Chevy K10 Built 355, FAST EZ EFI, 5speed
2000 Chevy Tahoe LT 5.3L, Slowhawk tune
2012-2SS is offline   Reply With Quote
Old 05-24-2012, 11:18 PM   #2
Nevadabill
Nevadabill's Avatar
Drives: 2010 Camaro 2SS
That's a good question, that I can't answer. I've had the same issue (stuck pedal) and there are threads all over with opinions about the cause.. But I would like to hear how things work out for you after the new pedal assembly is installed.... and you give it a good test of course. Would be wonderful if that is a real fix.
Nevadabill is offline   Reply With Quote
Old 05-25-2012, 03:13 PM   #3
BBQdDude
BBQdDude's Avatar
Drives: 2010 Chevy Camaro 2SS RS
I have a Tuesday "initial appointment". They will go out with me to reproduce. I told them this was spirited driving but no WOT. They confirmed a TSB for the peddle not coming all the way back out. I got the return pedal spring from a vendor here but hope for more than a band aid.
BBQdDude is offline   Reply With Quote
Old 05-25-2012, 07:33 PM   #4
Nevadabill
Nevadabill's Avatar
You talking the Lingenfelter clutch return spring kit ?. I'm installing one of those. Supposed to be here today actually.. I had taken it in awhile back because of clutch smell and they had a TSB on customer complaints of this (clutch odor) and were willing to check it out and repair if they found something. Up till then it was just a odor and I have warranty left so I didn't do it just cause it did take 'sprited driving' to happen.. But couple weeks ago after some 'SD' thru the hills, I went to do a burn out and she stuck to the floor, hit the limiter and well it just sucked... my personal opinion is the hydraulic clutch slave is just junk on these cars. Fluid over heats causing slippage and pedal issues. Was kinda hoping if there was a now known pedal issue and warranty replacement upgrade, I'd get it done.
I'd rather not have to reproduce the driving conditions for them if you know what I mean...probably scare the sh@t out of a passenger.. let me know how it works out. Thanks
Old 05-26-2012, 09:25 AM   #5
tkrupinski
Hugger Orange
tkrupinski's Avatar
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80
My car had the sticking pedal under mid to heavy acceleration. I replaced my clutch with a
street slayer dual carbon and have not had any pedal issues, 3000 miles on new clutch. I think it is in the GM pressure plate, seems like even the LS9 clutch is having similar problems. I have abused this clutch with hard launches and pedal returns just fine.
tkrupinski is offline   Reply With Quote
Old 05-26-2012, 10:11 AM   #6
L99CAMA2011
L99CAMA2011's Avatar
That's exactly what I assumed it was, the stock pressure plate. My pedal doesn't stick but sometimes I get slippage like I have a worn clutch even when my car was new also with clutch burn smell. I will def. upgrade my clutch.
Old 05-26-2012, 10:32 PM   #7
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
I have new aftermarket clutch, aftermarket hydraulic bearing, separate reservoir and pedal still drops to the floor at times. Starting to think it needs a new master cylinder too that will provide more fluid to the slave, and / or lines that flow more fluid as well. The pedal stays in position from the hydaulic system, not the other way around. The pressure keeps the pedal from dropping to the floor, that's why if a line is busted and fluid runs out, no pressure and pedal drops to the floor. The whole clutch / hydraulic system is really bad news all around.
calbert1999 is offline   Reply With Quote
Old 05-27-2012, 08:07 AM   #8
tkrupinski
Hugger Orange
tkrupinski's Avatar
I have to disagree alittle. If the preasure plate is being held open by centrifugal force there would be no pressure on the T/O bearing, which would lead to no line back preasure and the pedal sticking to the floor or halfway down. About everyone that has this problem has had the clutch slip which leads to the pressure plate not closing all of the way. When my car would have this problem i would have to delay my shift until the pedal popped back up, this was only under medium to hard acceleration. Some of the hydraulic problems might be due to increased clamping force of some of the single disc and a few dual disc clutches. Since the new clutch change no problems and my car was having big time pedal issues with the stock clutch. Just my take on this.
Old 05-27-2012, 11:55 AM   #9
calbert1999
Camaro SS Lover
Any ideas why this happens though or what the fix is? Is it really replacing the clutch pedal, or putting a return spring on it?
I had to reach under and pull the damn thing back up.
Old 05-27-2012, 01:20 PM   #10
tkrupinski
Hugger Orange
tkrupinski's Avatar
if you call Hendrix they can explain it better than I can. when I was looking for a clutch Hendrix said it will fix my pedal problem and he explained why, so far no problems. mine would stick down but if i lifted off the gas and paused it would pop back up. only did this under hard or mid acceleration. if mine suddenly takes a crap i will post back, but sos far so good.
Old 05-27-2012, 01:28 PM   #11
calbert1999
Camaro SS Lover
Let me guess Hendrix's solution was to buy a clutch from them? I'm not interested in that solution.
Strange thing for me; I had the problem with stock clutch system, but it never happened after we upgraded the clutch, then when GM slave blew out we went with RAM hydraulic bearing, and now the pedal to the floor issue again. Could be OEM slave was not strong enough to hold the pressure of new clutch and now the new slave is strong enough, but I'm thinking either pedal adjustment necessary to ensure clutch forks not overextended and sticking, or fluid pressure (master cylinder).
Well, more work to do I guess.
Old 05-27-2012, 02:07 PM   #12
tkrupinski
Hugger Orange
tkrupinski's Avatar
Before i bought my clutch i looked at a lot of them and many still had the pedal hang up. I talked with Huffer and he and a few others had nothing but good things to say about the clutch and did not have the pedal issue. After talking to Hendrix his theory made good sense so i purchased the clutch, best part i have installed yet. It is pricey but it looks like alot of people are spending more on replacing upgraded clutches or more parts to figure out why they are still having the same problem. Im not saying it is the cure but i have not seen anyone to date with this clutch have the pedal problem. It wouldn't hurt to call them and see what they have to say.
Old 05-27-2012, 02:18 PM   #13
tkrupinski
Hugger Orange
tkrupinski's Avatar
Hopefully the new slave fixes your problem. Nothing worse than shit going south and trying to figure out the cause. I should keep my mouth shut before i jinxs myself and clutch fluid starts spraying all over my leg.
Old 05-27-2012, 02:39 PM   #14
calbert1999
Camaro SS Lover
Yeah. I hear you man. That's how I feel now. Everytime I make headway something goes very wrong.
One thing I realized, is I should have went with a clutch manufacturer that has an entire "solution" for their product.
I won't mention any names but there are a lot of clutch manufacturers, and when something goes wrong they have no clue how to fix it.
Noticing some companies like RAM, Mcleod actually have systems not just clutches.
In hindsight I would have went with RAM, they have end-to-end solutions for every type of driving you could want to do. Very impressive.
