Old 05-24-2012, 04:25 PM   #1
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
Stock ZL1 .vs. Torq Heat Exchanger w/ TEST DATA & INFO INSIDE
Let me first state that we were super anxious to try our Dual Pass Heat Exchanger on a ZL1 as soon as we knew the car was being created as we knew how undersized it would be. We are VERY happy with the results but from our testing know there are many other restrictions in the system....good news is that we are already testing and developing new products for this beast.
We have posted the data and results at the end.
Background
Having a long history with factory supercharged [Ford] vehicles, we knew the potential of an aftermarket heat exchanger was huge. When dealing with Roots or Twin Screw Superchargers there's always the issue of intake temps. When running the car hard and spinning the blower fast you create heat. Heat equals a loss in power as well as the possibility of damage to the engine. One way to help reduce these intake temps and the risk of damage is to add more fluid into the inter cooler system which in turn helps lower intake temps by dissipating heat.
After carefully interviewing many manufacturers we selected one of the biggest and best radiator/hx manufacturers in the country to design our exclusive Camaro SS/ZL1 Dual Pass Heat Exchanger.
We were among the first to release a real replacement Heat Exchanger for the Camaro SS equipped with aftermarket Superchargers and designed it with the intentions of being universal for all Supercharged SS's as well as the ZL1.
We were able to test fit one a few weeks ago and we were extremely pleased that it is a 100% direct bolt-on and uses the factory intercooler hoses.
Heat Exchanger Design
This double pass heat exchanger is of the highest quality. The cores, welds and design are used in many high performance applications for both street and track use.
Using years of experience, advanced design, and thorough testing, Torq ZL1 Heat Exchangers are designed to promote optimal air flow and cooling by utilizing appropriate fin count, tube size, core thickness, and fin serration for each particular application.
* High efficient double pass design vs. Single Pass
* Increased HP due to intake temperature drop compared to stock
* Drop in intake temp at idle, cruise and wide open throttle because of the improved cooling efficiency
* Increased recovery of temperatures (consistent and reliable power)
* Helps prevent heat soak and detonation due to increased intake temps
* Furnace brazed core (no epoxies) with beautifully tig welded tank construction
* OPTIONAL Dual 10" fans provide the ultimate in airflow at all vehicle speeds
Of course, as an Torq product, quality is second to none. Torq Heat Exchangers are TIG welded and feature furnace brazed cores with no epoxy. Each unit is pressure-tested before it is ship
Regains Lost Power
By more effectively cooling intake temperatures, Torq Camaro ZL2 Heat Exchangers keep the air entering the combustion chamber cooler and more dense, even in high-demand situations.
Allows for More Consistency
After hard acceleration, especially in drag racing applications, Torq's ZL1 Heat Exchangers allow the supercharger to cool faster and remain at a constant temperature, which means power delivery is more consistent.
Results/Findings
Immediately after firing up the car we noticed how much better this was compared to the factory unit. The larger capacity ZL1 Heat Exchanger has an increase of 60% more fluid capacity, which means it takes a lot longer for the fluid to heat up.
Sitting on the dyno at idle, without fans we noticed the IAT2's were not rising, or the few seconds it did, it immediately dropped back down to below 100F.
Driving around and cruising we also the temps were not rising anywhere near what stock was. We were seeing a 15-20 degree drop at idle and cruise and very impressed.
Installation
We hooked up the fans to the factory intercooler pump so when the pump turns on the fans would turn on as well. From the factory there is a delay for the pump to turn on and it only turns on after the car has been running.
To take advantage of the fans coming on during key on we modify the factory calibration (your tuner can do this for you) so the pump turns on as well as the fans without the vehicle running. This will draw fresh air through the HX and help circulate fluid. This is a great benefit for track use.
We will have an optional upgrade to hook the fans up to a switch or there are many other relays you can do this.
These are IN STOCK and READY TO SHIP!!
PICS:
Meister@Torq is offline   Reply With Quote
Old 05-29-2012, 04:39 PM   #2
Meister@Torq
Bump
Old 05-30-2012, 05:17 PM   #3
1st Gen Forever
ZL1 #140
1st Gen Forever's Avatar
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1
A few questions on this. It looks like your HX keeps the IAT2s about 10 degrees lower on average across the RPM range. So here go the questions...
1) Was your testing done with the stock pump?
2) Do you recommend a higher flowing pump?
3) Did you do any testing just to show how the fans help when the car isn't moving?
Thanks!
1st Gen Forever is offline   Reply With Quote
Old 05-30-2012, 05:25 PM   #4
sycraft
COTW 5/06/2013
sycraft's Avatar
will ask on this post too, I am curious.
It's nice to have that chart but can you post the actual data logs that show the real readings at IAT2 that's read in the blower plenum? Also do you have backup data on the street, drag strip and in a road course environment? Its been my understanding that the factory heat exchanger is pretty efficient and the bigger issues is quantity of reserve for cooling
Old 06-02-2012, 04:46 PM   #5
frcdfed
Drives: 04 GTO
Did you guys log the normal coolant temp at all? Just wondering if the larger intercooler causes an increase in engine temp as happens a majority of the time people go to a bigger front mount intercooler when it blocks air flow to the radiator.
frcdfed is offline   Reply With Quote
Old 06-29-2012, 11:42 AM   #6
Meister@Torq
Yes, we did and there is no increase in ECT's. This is why we did not extend the HX all the way down and block airflow to the radiator.
Old 06-29-2012, 11:42 AM   #7
Meister@Torq
Those are actual IAT2 readings, from the blower plenum, put in chart form to clean up the log. We will have some better logs on the street and track shortly.
We have had this heat exchanger running on hundreds of SS's with amazing results as well.
Old 07-10-2012, 08:11 AM   #8
Mike535
iRacing Pro
Mike535's Avatar
Drives: Camaro ZL1 Summit
Can you PM me with the price please !!!
Lapping Sanair Lapping Mosport
Race the Runway 248km/h
1 7/8'' ARH Headers & High Flow Cats
63 lb Fuel Injectors - 160 Degree Thermostat
Supercharger Isolator Coupling
2.55'' 8 Rib 10 Bolt Pulley - Kenne Bell Boost a Pump
8 Rib Poly V Belt For 10% Overdrive Pulley & 2.55'' Upper Pulley
Overdrive Harmonic Balancer Kit
10% Overdrive Balancer Pulley
10 bolt Supercharger Pulley Hub
Nick Williams 102mm Throttle Body
New Era CAI with w/w reservoir
Port and polish supercharger snout
Snow Water Meth
680 RWHP.....!
Mike535 is offline   Reply With Quote
