JDP Motorsports
Old 05-24-2012, 10:14 PM   #1
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Rattle noise coming from Rear end
So the past couple of days I have been hearing a rattling sound from the rear end. I have a headers and a Corsa exhaust on the car so I figured that was what was making the sound. Just to highlight, the sound only happens when I hit a good size bump in the road. It's definatly a metal on metal type of rattle. One that a loose muffler would make if it was to make contact with the bottom of your car. SO at any rate I started taking pieces of the exhaust off. Nope not the mufflers, they're off, went around the block still heard the sound. Hmmm maybe the exhaust is bouncing off the cross plate under the car. nope took the plate off. Maybe the the mid pipe is bouncing into the heat shield. nope.... I ended up taking eveything off down to the header and driving around the block noise, yeap still there. I have a stock suspension so I wouldn't think it's that, but then again. I was told that I'm chasing a ghost. Any thoughts out there??
Lnch Mny is offline   Reply With Quote
Old 06-11-2012, 02:26 AM   #2
RS_Camaro
my dream car
RS_Camaro's Avatar
Drives: Black 2011 Chevrolet Camaro RS
I think I have the same issue. I was driving around the city and I would go over a bump or a pot hole and I hear a metal on metal rattle. This is when it gets really good. I brought it to the dealership and they identified a crack in some thing that's located in the rear of car. Four hours I sat in the dealership so it could get replaced on the same day I just happened to be driving out of state. They told me that replacing this cracked part will most likely fix it but it didn't. VERY frustrating because whether this part was really cracked or not, leaving it wouldn't have made the slightest difference.
I had the mechanic go under my car and tighten everything that could possibly be tightened and it's still rattling. I'm going to go under tomorrow and manually shake every mechanical part that I can grab to see for myself if anything is loose.
RS_Camaro is offline   Reply With Quote
Old 06-11-2012, 03:16 AM   #3
newb
newb's Avatar
Drives: 2013 1LE
I remember reading somewhere that sometimes rocks and small pebbles get trapped in the rear control arms and rattle. Although hard to find this may be the problem. If I remember correctly they were upsetting the knock sensor also. causing a loss of power.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 06-11-2012, 11:46 PM   #4
RS_Camaro
my dream car
RS_Camaro's Avatar
No I know rocks have nothing to do with it. It's definitely metal on metal. Its beyond frustrating. Imagine driving around looking fresh in your car and it sounds like it's falling apart. I found nothing today while I looked. It sounds like two thin bars clinging together.
Old 06-12-2012, 12:18 PM   #5
Chevrolet Customer Svc
Drives: GM Vehicles
I am sorry to hear this. If you would like, I can contact your dealership and do some research about your concern. I just need your first and last name, address, phone number, VIN, mileage, and involved dealership. I will be more than happy to see if there are any options available to you.
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 06-13-2012, 11:09 PM   #6
RS_Camaro
my dream car
RS_Camaro's Avatar
I've had two GM dealers inspect my car and drive it around and both have found nothing. I'm pretty much just going to deal with it and avoid bumps and just have someone double check it every oil change. Hopefully, it'll be found or GM figures it out
Old 11-03-2016, 05:51 AM   #7
mph1972
Drives: Black SS
I have the same issues. I've lifted the car twice and throughly inspected my car. I thought it maybe possible that the lowered suspension installed by previous owner could be it, but there is no telling. I have a good looking car, but I hate driving it at times, because of this issue. Is what it is I guess.
mph1972 is offline   Reply With Quote
Old 11-08-2016, 06:37 AM   #8
Botta07
Botta07's Avatar
Drives: 2010 Camaro 2SS/RS M6
I had this very same issue. I took me several months to finally figure out what caused the noise. Im posting this to help anyone else that has this same issue because I was unable to find an answer on here that addressed the noise I had.
Symptoms: Clicking/ knocking noise which sounded either in the truck or on the bottom of the car in the rear. It sounded like metal on metal when going over bumps at low speeds only, not at higher speeds and would almost always make the noise when pulling into my driveway where the rear sway bar would be under load. I naturally thought "End links" but those were tight. I checked everything. I even took the right rear strut and spring assembly out and inspected it. All was good. No rocks in the rear arms either.
I gave up trying to figure it out. Then after a hurricane, i had some rain entering my truck, so in the process of drying out the car and fixing that I had put my rear seat down for a few days to allow the truck to air out; and just like that the sound was gone.
The latch on the rear seat had some play and would make the metal on metal clicking/ knocking noise when going over bumps. As soon as i put my seat down the noise was gone.
So I hope this helps someone out there as this would not have been my first guess to where the noise was coming from. Try putting your rear seat down and drive it a bit to see if the noise is still there.
FYI: This is my first post. 2010 2SS M6
Botta07 is offline   Reply With Quote
