BeckyD @ James Martin Chevy
Old 05-25-2012, 09:35 AM   #1
NH-SS
Drives: 2010 SS2,6M
Hurst Shifter Fix
I installed the Hurst shifter, after only a few hundred miles on it the side play was rediculous. I called Hurst and they sent out a "new" design bushing. I recieved it and it was the same as originally that came with the shifter. What I did to fix the problem was design and MFG my own. I made a split bushing out of oilite bronze (SEA841), I Incresed the side surface area ( to increse side load stability ) Turned the O.D for a +.001 slip fit. Bored the I.D to -.0005 under size then took the original locating pin and burnished the bore to the pin. After thousands of miles I still have virtually zero play in the shifter. It's a great product,.. just needs a different bushing material..
NH-SS is offline   Reply With Quote
Old 05-25-2012, 12:38 PM   #2
MustangKiller
MustangKiller's Avatar
Drives: 2013 2ss/rs A6 yellow !!!!!
Delrin maybe or is that what the stock one is. Im wait on a new one from them.
MustangKiller is offline   Reply With Quote
Old 05-25-2012, 12:42 PM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
I think the bushing from Hurst is Teflon or something similar. NH-SS, I wish you sold those bushings you made!!! I'd buy one!!!
blazzin1 is offline   Reply With Quote
Old 05-25-2012, 01:34 PM   #4
NH-SS
Drives: 2010 SS2,6M
The bushing from Hurst I believe is PTFE (Teflon)
Old 05-25-2012, 08:16 PM   #5
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
can u make me one?
Whipped416 is offline   Reply With Quote
Old 05-26-2012, 05:44 AM   #6
NH-SS
Drives: 2010 SS2,6M
If there's enough demand for a replacement bushing out there I guess I could set up to make some more. The only issue I see is not being able to take the MFG production tolerence into account. I made my custom bushing to match my shifters pin O.D. & shifter I.D. Every shifter will have a + or - tolerance difference. But,..I willing to help out. The Hurst shifter is very nice,.. and with a replacement bushing it's pretty much perfect. So,.. how many of you would like these ??
Old 05-26-2012, 07:58 AM   #7
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
I will definitely take 2 bushings. You could make mine the same dimensions as yours. I have no problem hand fitting them if need be. I used the factory bushing to make one. The ID was good, but had to take a little off OD to fit Hurst shifter. Figuring out how to hold it in the lathe was the hard part. Shifter now has about 1/8" play at handle, but I would rather have something more durable so I never have to worry with it again. Please PM me if you are willing to make some.
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 05-26-2012, 08:51 AM   #8
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
I'll take one.....
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 05-26-2012, 10:31 AM   #9
chetkan
Haters gonna hate!!!
chetkan's Avatar
Drives: 2011 Camaro 2SS/RS Synergy Green
I haven't installed my kit yet. I'd rather do it once and do it right so I'll take one!
chetkan is offline   Reply With Quote
Old 05-26-2012, 03:04 PM   #10
NH-SS
Drives: 2010 SS2,6M
Well OK,..I will make some of these shifter bushings next week. I will let you know when there ready.
Old 05-26-2012, 03:45 PM   #11
HtownSS
Drives: Silver 2SS, 68 Firebird 400,70 vett
I will take two, I have two buddy's that I run with, and I know they will take at least one each. Making that four maybe more..
HtownSS is offline   Reply With Quote
Old 05-26-2012, 04:35 PM   #12
JackRabitSlims
Drives: 2010 Camaro 2SS RS LS3
I need to fix mine. I would take one. How did you fix it? did you have to take the whole shifter out or can you just pull out the bushings and put the new bushings in?
JackRabitSlims is offline   Reply With Quote
Old 05-26-2012, 05:00 PM   #13
NH-SS
Drives: 2010 SS2,6M
just replace the Hurst bushing with this new replacement. Sooo,.. how many am I making ??
Old 05-26-2012, 05:47 PM   #14
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
Originally Posted by Smirnoff View Post
I'll take one.....
Me too
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
