Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 06-30-2012, 04:23 AM   #127
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
Originally Posted by From The Future View Post
My bushing kit came in the mail yesterday and I was completely happy about it. Such nice looking new bushings and a well written set of instructions too. It was all so carefully packaged, NH-SS is the man.
Something semi-weird has happened though. I bought a new shifter pin and clips from my local dealer and brought them home today. I looked at the pin and bushings at my desk and discovered that the new shifter pin I bought is much smaller than the hole through the center of the bushing, it totally rattles around inside the bushing.
I think they must have sold me a smaller than normal shifter pin or something. I saw the parts diagram on the parts guy's computer, it looked like the right part to me. I guess I will have to pull the used pin from my car tomorrow and see if it fits the new bushings.
The pin is supposed to be a tight fit inside the bushings, correct? After viewing the photos in this thread I am under the impression that the pin just barely fits through the hole in the center of the bushings and the burnishing process is to make the pin fit correctly and move smoothly.
I guess I will find out for sure once i remove the existing pin from my shifter and compare it to the new pin I picked up at the dealership today.
There is another pin (92165638) that connects the other end of the shift linkage to the trans. That might be what they gave you. I can't find the pin you need on any GM parts diagram so it may be part of the complete shifter assembly. I would take the pin in and explain which one it is.
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 06-30-2012, 05:48 AM   #128
Drives: 2010 SS2,6M
Could you please post a side by side picture of the pin you purchased from GM & the OEM pin that came with your car. It is possible that the OEM pin / shifter has been redesigned and you have a new Revision pin. Using the original pin that came with your car is good to use and is what I recommend.
NH-SS is offline   Reply With Quote
Old 06-30-2012, 09:23 AM   #129
From The Future
needs gas money
From The Future's Avatar
Drives: 2010 Camaro SS IOM 6M
Too hot!
Ugh, I don't think that I can get you a side by side picture of the two pins today. It is seriously hot out there already. I got the car up on jacks and I said forget it. I let it back down and came inside.
It sucks because I have the shifter bushing upgrade to do as well as a brand new set of long tube headers to install. I was planning to do both this weekend but at 106 degrees and 90%+ humidity in TN, it isn't going to happen this weekend.
I did get a few pics of the new pin I bought together with the bushings. They are crappy cell phone pics but I think you can see the new pin is too small.
So weird... I saw the picture and it appeared to be the right part. I wonder if he looked up a different car that uses the same type of linkage by mistake?
I will eventually pull my existing pin and compare the two if it ever cools off some. My car is a 2010 built in Sept 09, I cant imagine that it would be too different than everyone else's for this particular part.
Part number on the baggie is: 92165638. Made in Australia, mate.
From The Future is offline   Reply With Quote
Old 06-30-2012, 09:34 AM   #130
Drives: Silver 2SS, 68 Firebird 400,70 vett
Those look like the pins that go into the forks on the shifter assembly.
HtownSS is offline   Reply With Quote
Old 06-30-2012, 10:33 AM   #131
From The Future
needs gas money
I think toml_pa hit the nail on the head with his part number, it matches the one I received.... they sold me the wrong pin. I even looked at the parts guy's screen and pointed to the part I needed! Dagnabbit.
Oh well, I guess i will reuse my old pin once I do the installation. I just wanted to get a new one so I could start fresh with all new parts. I suppose the burnishing will take care of that issue and I shouldn't have to really worry about it.
I need an air conditioned garage, my new bushings and my new headers are just sitting here staring at me. I hear it is cool in Maine and Washington State, I should move so I can work on my car without dying from heatstroke.
Old 06-30-2012, 11:00 AM   #132
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
I reused the old pin as well. Burnishing it does take a bit of patience (getting it lined up and straight before you start is kind of a pain) but the old pin will go in without too much trouble after you get it started. Before burnishing, I cleaned the old pin and clips with carb cleaner and then dried them so they were basically brand new.
2011 Camaro 1SS/RS
Cammed, Sprayed, and Beaten Daily.
Aries240SS is offline   Reply With Quote
Old 06-30-2012, 02:09 PM   #133
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
Got my bushings today! I won't have a chance to do the mod for about 2 weeks though so I'll post when it gets done! I can't wait! Thanks NH-SS for the quick shipping
ssmike is online now   Reply With Quote
Old 06-30-2012, 02:32 PM   #134
alssiri's Avatar
Drives: 2012 ZL1 A6
Pm sent
2012 ZL1 A6
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Corsa Sport Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, AGP Dual Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
2015 Rear Fascia Conversion, Z/28 Side Skirts, Flares, Spoiler & Diffuser , ACS Quarter Ports, ShowStopper's Side Marker's, LightWurkz Halo's.
Sosche With KenWood, SLP pod with PLX guage, DashLogic .
alssiri is offline   Reply With Quote
Old 07-09-2012, 09:01 AM   #135
blazzin1's Avatar
Drives: 2016 2SS (A8)
Finally got my new bushings installed this past Wednesday, so I've had a few days to try them out. All I can say is...WOW, I am totally impressed!!! This thing feels like a "gate shifter" on a Ferrari now!!! 98% of the slop is gone. Installation of the bushings went smoothly (once the shifter was out). The end of the pin fit in my 3/8" drive drill without any problems, and the burnishing process worked perfectly. I did have some problems trying to get my shifter out, but used a 90 degree scribe (pick) to finally get a little gap between the shifter and the housing. Also, going back in, I figured I would re-use the old o-rings on the shifter, and lubed them up with grease, but it wouldn't go back in. For some reason, I think the o-rings swelled while they were out. I changed the o-rings and lubed with some petroleum jelly and it went right in. Just wanted to say a big "thank you" for the fabulous bushings, and you deserve all the profit you can make from these!!! I wish you the best in your future business ventures!!!
blazzin1 is offline   Reply With Quote
Old 07-09-2012, 02:40 PM   #136
Drives: 2010 SS2,6M
Thank you for the possitive review ! Very glad everyone is happy with this upgrade. The O-Rings supplied in the bushing kit are of Buna-N material,.. they will not swell from being exposed to petrolium based products.
FYI,.. I have just completed manufacturing another production run of bushings. Bushing Kits are available.
Old 07-16-2012, 05:18 AM   #137
OnkelMatze's Avatar
Drives: Camaro 2SS/RS LS3 AirForce
do the bushings work with the Barton shifter as well?
If so, I am very interested to oder
OnkelMatze is offline   Reply With Quote
Old 07-16-2012, 05:40 AM   #138
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
How much for these bushings?
Sent from my DROID BIONIC using Tapatalk 2
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 07-16-2012, 06:22 AM   #139
Caswell239's Avatar
Drives: 2011 2ss/rs
Are these for the stock hurst shifter or aftermarket?
Caswell239 is offline   Reply With Quote
Old 07-16-2012, 06:27 AM   #140
Smirnoff's Avatar
Drives: Camaro SS
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
