BeckyD @ James Martin Chevy
Old 07-16-2012, 05:09 PM   #141
NH-SS
Drives: 2010 SS2,6M
I believe the OEM Hurst Shifter & the after market Hurst Shifter are both Hurst PN 391-6030.
NH-SS is offline   Reply With Quote
Old 07-16-2012, 05:12 PM   #142
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
how much for a set of bushings then. all the way up to the cold climate.
217 fullerton drive
Fort McMurray, alberta,
canada, t9k1m2
Caswell239 is offline   Reply With Quote
Old 07-16-2012, 05:13 PM   #143
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
The OEM Hurst shifter is not the aftermarket Unit sold by retailers. The OEM Hurst shifter is very similar to the stock shifter, slightly redesigned with a shorter throw.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 07-16-2012, 05:18 PM   #144
nak3dsnake
nak3dsnake's Avatar
217 fullerton drive
canada, t9k1m2
These bushings will not fit the OEM unit. The aftermarket and OEM are completely different shifters. Pics of the KAE factory unit are bellow.
Old 07-16-2012, 05:44 PM   #145
NH-SS
Drives: 2010 SS2,6M
Yes,.. I agree. Thank You for the pictures and clarafication.
Are there issues with play in the stock / OEM Hurst Shifter also ?
Old 07-16-2012, 08:04 PM   #146
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
theres a little but nothing i would worry about. i was just curious as to how much is too much as some people are very particular with things like this
Old 07-18-2012, 07:01 AM   #147
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Have 3 thousand miles now on the new pin bushing "and JRE Get Gone Parts" and it still feel nice n tight and very precise about 1/16th of side to side motion is a bout it..
shifting thru the 6 gears has never been better!!
4 gears of smoke was something I have not done in years!!!
Thanx again NH-SS!!
RogerBzSS is offline   Reply With Quote
Old 07-18-2012, 08:41 PM   #148
NH-SS
Drives: 2010 SS2,6M
HAHA,... That's awsome,.. Roger PM,.. 99s for lunch
Old 07-21-2012, 04:09 PM   #149
BC 2010
BC 2010
Drives: 2010 Camaro SIM 2SS/RS M6 GFX SR
Just finish install. Anybody who has not done this mod you are really
Missing the boat. Thank you NH-SS
BC 2010 is offline   Reply With Quote
Old 07-24-2012, 07:54 AM   #150
cpc63
cpc63's Avatar
Drives: 2013 ZL1
Shifter Bushing
Price shipped to 66614, thanks.
Please follow install directions,.. very important. I want everyone to be very satisfied. If anyone has questions PM, me.
Thanks
cpc63 is offline   Reply With Quote
Old 07-24-2012, 10:13 AM   #151
Nessal
Drives: Exige, Miata, Ghia
I got mine a few days ago...can't wait!
Big thumbs down to Hurst for not having a fix for this already.
Nessal is offline   Reply With Quote
Old 07-29-2012, 11:56 PM   #152
Nessal
Installed it today. Boy was burnishing a PAIN. It took me 3 hours to do both bushings. It was a slooooow process. After all that was said and done, the cross pin went in with slight resistance so it seems just right. Prior to these bushings, I was getting 1/2" of play. Now it's down to about 1/4". Yes, there is a still a little bit of wobble, but it's not from these new bushings. These bushings got all the wobble out from one side completely. After getting everything back in, I can tell that the wobble is in another part of the transmission. It looks to be from the transmission side of the arm(fork) that attaches to the shifter. Also let me just say...everything is a VERY tight fit. I took a digital caliper and measured from one side of the bushing to the other and it came out to 1.470". Here are some tips.
1. Make sure you have a 1/2" drill. I have a 3/8" drill(very common) and the cross pin would not fit into the teeth of it. I had to pick up a cheap one from OSH.
2. Put the car into neutral before taking the shifter out.
3. After getting the new bushings into the shifter, I would test fit it in the car before the burnishing step to make sure that it fits back into the fork coming from the transmission. I got a big scare after putting it all back in and then felt that the fork would not slip over the bushings.
Old 07-30-2012, 12:52 AM   #153
montej23
montej23's Avatar
Drives: 2011 VR Camaro
are these bushings for the aftermarket 40 percent reduction hurst shifter? please PM me price
montej23 is offline   Reply With Quote
Old 07-30-2012, 05:17 AM   #154
RogerBzSS
RogerBzSS's Avatar
If youre shifter part # is 391-6030 then yes
Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
