Old 08-13-2012, 12:40 PM   #169
txgoose
txgoose's Avatar
Drives: 2010 VR 2SS/RS
Originally Posted by sycraft View Post
looks like it is serviced with the assembly
I thought someone who had already changed theirs out might have mic'ed the pin for future reference. Guess I'll give it a shot later this month (fingers crossed).
txgoose is offline   Reply With Quote
Old 08-14-2012, 05:56 AM   #170
NH-SS
Drives: 2010 SS2,6M
As a referrence,.. OEM Pin dia. .4713
NH-SS is offline   Reply With Quote
Old 08-14-2012, 08:43 AM   #171
Moe55
Drives: 2011 1ss
Ordered my new bushings from NH-SS two days ago. Can't wait to get it installed
Moe55 is offline   Reply With Quote
Old 08-14-2012, 10:19 AM   #172
SS/GA
SS/GA's Avatar
Drives: '68 SS396 - '98 Z28 - '10 2SS
NH-SS - Thank You!!
Thank You Dave, for your prompt reply...
I'm sure Your Parts are going to fix what Hurst wouldn't or won't?
SS/GA
SS/GA is offline   Reply With Quote
Old 08-14-2012, 08:04 PM   #173
J-Rod6410
M6 10 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Just ordered another set for an install I'm gonna do! Still lovin mine!!
TEAM LS3 Best pass: 10.49 @ 135 with M6
730RWHP 650RWTQ ECS S/C stock bottom end, 4L80, 9"
Built by: J-Rod.... Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com)
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 08-14-2012, 08:09 PM   #174
10black1ss
Drives: 2010 black 1ss camaro
are you still making these?
10black1ss is offline   Reply With Quote
Old 08-15-2012, 06:13 AM   #175
NH-SS
Drives: 2010 SS2,6M
Yes,.. These Replacement Bushing Kits are available. PM. me for order info.
Thanks
Old 08-16-2012, 08:30 AM   #176
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I'm planning on putting my bushings in this weekend hopefully, i will be installing my 9 inch also so I will have my driveshaft out as well, can I just install the bushings and burnish the pin without pulling the shifter out? I'm mechanically inclined so was just trying to keep from stripping out the screws used to hold shifter in. Thanks.
MODS:
Old 08-16-2012, 09:07 AM   #177
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
See post #113 about halfway down this page. All I removed was the rubber boot. Shifter and driveline were still in car. You should have no problem with the driveline out, but you will have to burnish the two bushing pieces before you put them in since a drill won't fit in the tunnel.
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 08-16-2012, 09:47 AM   #178
SS/GA
SS/GA's Avatar
Can someone show us which screws these are please.
(when doing this mod, maybe we should have a slightly larger diameter replacement screw on hand... just in case?)
Thanks
SS/GA
Old 08-16-2012, 10:29 AM   #179
10aSSee D
10aSSee D's Avatar
Thanks for the info, this was what I had planned on doing myself.
MODS:
Old 08-16-2012, 04:34 PM   #180
txgoose
txgoose's Avatar
Thanks. I'll file that away for future use.
Old 08-18-2012, 08:49 PM   #181
H1Chester
Bowties forever
H1Chester's Avatar
Drives: 2010 2SS/RS, 2015 Ram 1500 Sport
Ok, so far for me this has been very difficult. Been on this all day. I got the the shifter back in, and trying to get the pin through. It slid through the bushings just fine, but when I got the shifter in the car and the lever connected, now the pin went through but not all the way though and and the very tip is not feeding through. Can't move it now... HELP!
“LUCILLE” 2010 RJT 2SS/RS M6
5% tint, AC red interior overhead LED, footwell, grill and engine bay lighting, license plate LEDs, reverse LEDs, painted black badges, bowtie, and tail light bezels, Heritage grill, T3 ports with LEDs, T3 splitter with cooler, carbon fiber vinyl hashmarks, TSW Nurburgring wheels, Nitto Invo tires, Hurst shifter, RX 1LE catch can, Rotofab intake, American Racing headers, Flowmaster exhaust, CMS camshaft, 3.91 rear end, BMR suspension, StopTech rotors, steel brake lines 456RWHP 422Tq on Mustang Dynamometer. Built, tuned by Cunningham Motorsports. SD Region SCCA
H1Chester is offline   Reply With Quote
Old 08-18-2012, 09:30 PM   #182
H1Chester
Bowties forever
H1Chester's Avatar
Ok well I got the pin back out. I think what happened is that the hole is not lined up perfectly one side due to not having a perfect burnishing of the pin hole. I tried pushing the pin through on both sides and when I push through starting from one side, it goes all the way through until a small part of the pin is sticking out on the other side but won't go through the whole way. When I take the pin out and try pushing through the other way it does the same thing but there will be some small slight resistance at first. I think this is from forcing the holes to line up now for the other side since it didn't go through on the original try.
So sounds like this set of bushings is F-ed. I'm pretty pissed off. Unless anybody has any other idea of what might be happening.
