| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
Thread Tools |
#101 |
![]() Drives: Silver 2SS, 68 Firebird 400,70 vett Join Date: Jul 2009
A man who crafts to my specs, very impressed with the craftsmanship and attention to detail, thank you for providing us the opportunity to get our hands on this.
#102 |
![]() Drives: 2010 SS2,6M Join Date: May 2012
That's what it's all about. Glad I could help.
#103 |
![]() Drives: 1994 Quasar Z28, 2010 SIM 2SS, 6M Join Date: Mar 2009
Got mine! Nice work.... gonna install mine like jrrod6410 due to allen bolt stripping problem too.
Great install info, pictures and nice engineering job! ![]() THANKS Guys..... |
#104 |
11.12 @ 130mph
Drives: A 4000 Lb BeaSSt Join Date: Jul 2009
![]() After driving with these bushings for a few days now all I can say is "Holy Fukkin $hit!!" These things make a world a difference! Firms up the slop like a MGW shifter but it slides into gear so smoothly and easily ![]() Also ran into my buddy last night H-TownSS who also bought the bushings and he was just as impressed as me ![]() Thanks again NH-SS for making these! If you guys are thinking about getting these you need to get off your a$$ and get them ordered! You will not be dissapointed at all!!
TEAM LS3
Built by: J-Rod6410. Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com) Check out my youtube channel: http://www.youtube.com/user/6410Jrod |
#105 |
![]() Drives: 2SS CGM/GRND FX/STRIPES/KN INTK, Join Date: Mar 2010
Got mine sat will install on Monday
#106 |
BLACK is the new Chrome!
Drives: 2010 2SS/RS RJT M6 Join Date: Jul 2009
PM sent for pricing!
#107 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro LS "Hot Blown Six" Join Date: May 2012
Just ordered a set
#108 |
![]() Drives: 45th SS Join Date: Jun 2012
What are the dimensions on the bushings, I have a shifter ordered and could go ahead and make a set to have ready
#109 |
#110 |
PM sent
#111 |
![]() Drives: 2010 2SS Camaro "Big Blue" Join Date: Nov 2009
Ordered mine, can't wait to get rid of "The Slop"
Big Blue
#112 |
When installing these, patience patience." And well worth it."
#113 |
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6 Join Date: Feb 2011
All I can say is UNBELIEVABLE! The shifter has absolutely no play. The best part is how you can actually feel the transmission click into gear through the shifter. Reverse used to be a little hard to shift into sometimes, but now it clicks right in every time.
It took longer to get the rubber boot back on than to install the bushing. I took the boot off and the pin out then burnished the bushings before I put them in. I was able to start the bushings using a little grease in the hole. Then I used a nut, bolt and two washers to draw the bushings together and into the hole. I put plastic with adhesive on one side on the face of the washers to protect the bushing faces. Also put the bolt through a piece of clear plastic tubing to protect the inside of the bushing from the bolt threads. Pin went in halfway easily with a few very light taps using a small wrench to get it the rest of the way. Normal use will complete the burnishing. Took about 40 minutes. Thanks NH-SS.
Way too many mods and way too much money. Wouldn't have it any other way. |
#114 |
Just had it installed,wow,night and day slop is gone, feels great the way it should be .now only time will tell..great job nh...
#115 |
![]() ![]() ![]() Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Hey NH-SS, I sent you payment through my wifes paypal just checking to see if you got it, thanks.
MODS:
Whipple 2.9L SUPERCHARGER 666RWHP 562TQ ADM Stage 2 Cam ADM Dual Fuel Pump System ADM CAI ADM Boost & Air Fuel Ratio Gauges Patriot Performance Dual Valve Springs Hurst Short Throw Shifter KW V1 Coilovers Stainless Works Full Length Headers & Full Exhaust Elite Engineering Catch Can Forgeline GA3 Satin black wheels 20x9.5-20x11 |
#116 |
As i have been reading this i will purchase one as well ..
#117 |
How do i get one
#118 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro IBM 2LT/RS M6 Join Date: Sep 2009
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade. Future Mods: Pedders Stainless Steel brake lines, Stage III radius rod inserts, Rear Cradle Bushings. |
#119 |
Ordered my bushings!
#120 |
![]() Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
I ordered a set as well. I can't wait to have a working shifter again!
2011 Camaro 1SS/RS
Hotchkis Chassis Brace, Rotofab Intake, Hurst Short Shifter, BMR Springs / Trailing Arms / Sways, Nitrous Outlet 150 Shot, SubThump Stealth Box, TSP 1 7/8 Headers, VMax TB, JRE Scoop, Rotofab Washer Relocation, JRE Tune |
#121 |
Camaro 5 Muscle
I had similar problems with mine and my brothers Camaro also. A few guys in the club recommended me to switch to MGW shifter and all i can say is that I would never try another shifter other this MGW. If you ever decide to try you it you will see what I mean. Your post was great and appreciate all the details during the install. - glad your shifter is working better.
Mods: Air Raid C.A.I., Custom Ported/Polished Throttle Body, Kooks 1 7/8 Headers, Dyno Tuned , LPE 3.91 Gears, BMR Differential Bushings, R/X Oil Catch Can, X-Pipe, Borla Exhaust, MGW Shifter, Hawk-HPS, SS brake lines, BMR front & rear sway bars, BMR rear sway bar end links, Pedders front radius rod bushings, Spohn front sway bar end links, BMR rack/pinion bushing, BMR Coils 1" drop, BMR Trailing Arm, BMR Toe Rods, Pedders Sub-Frame bushings, BMR Sub-frame Connectors, BMR Driveshaft Tunnel Braces, GM Strut tower brace, custom painted bowties
#122 |
My set just showed up. All I can say is WOW. Professionally packaged, perfectly machined, and better quality than I could have hoped for. I'll put these in tomorrow morning when it's not 109° outside.
Thank you NH-SS!
2011 Camaro 1SS/RS
#123 |
USA made,.. what else would you expect ? Glad your happy. Please follow install directions.
#124 |
![]() Drives: 11 IBM n White 2SS/RS M6 Join Date: May 2011
NH-SS
JRE installed my new hurst sts with the updated bushing and the bernished the new bushing with my pin Not that i ever had slop in my shifter but this is tight and i am diggin the new shifter Thanx for great quality work Roger Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune
![]() My SS layed down 462 hp on JRE's Superflow Dyno ![]() |
#125 |
needs gas money
My bushing kit came in the mail yesterday and I was completely happy about it. Such nice looking new bushings and a well written set of instructions too. It was all so carefully packaged, NH-SS is the man.
Something semi-weird has happened though. I bought a new shifter pin and clips from my local dealer and brought them home today. I looked at the pin and bushings at my desk and discovered that the new shifter pin I bought is much smaller than the hole through the center of the bushing, it totally rattles around inside the bushing. I think they must have sold me a smaller than normal shifter pin or something. I saw the parts diagram on the parts guy's computer, it looked like the right part to me. I guess I will have to pull the used pin from my car tomorrow and see if it fits the new bushings. The pin is supposed to be a tight fit inside the bushings, correct? After viewing the photos in this thread I am under the impression that the pin just barely fits through the hole in the center of the bushings and the burnishing process is to make the pin fit correctly and move smoothly. I guess I will find out for sure once i remove the existing pin from my shifter and compare it to the new pin I picked up at the dealership today. |
| Thread Tools | |
