JUICEDMOTORSPORTS
Old 06-26-2012, 01:17 PM   #113
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
All I can say is UNBELIEVABLE! The shifter has absolutely no play. The best part is how you can actually feel the transmission click into gear through the shifter. Reverse used to be a little hard to shift into sometimes, but now it clicks right in every time.
It took longer to get the rubber boot back on than to install the bushing. I took the boot off and the pin out then burnished the bushings before I put them in. I was able to start the bushings using a little grease in the hole. Then I used a nut, bolt and two washers to draw the bushings together and into the hole. I put plastic with adhesive on one side on the face of the washers to protect the bushing faces. Also put the bolt through a piece of clear plastic tubing to protect the inside of the bushing from the bolt threads. Pin went in halfway easily with a few very light taps using a small wrench to get it the rest of the way. Normal use will complete the burnishing. Took about 40 minutes. Thanks NH-SS.
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 06-26-2012, 04:29 PM   #114
ronss
ronss's Avatar
Drives: 2SS CGM/GRND FX/STRIPES/CAI, manual
Just had it installed,wow,night and day slop is gone, feels great the way it should be .now only time will tell..great job nh...
ronss is offline   Reply With Quote
Old 06-26-2012, 10:07 PM   #115
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Hey NH-SS, I sent you payment through my wifes paypal just checking to see if you got it, thanks.
MODS:
Old 06-27-2012, 10:58 AM   #116
20121lt
20121lt's Avatar
Drives: 1LE SS/RS 2013
As i have been reading this i will purchase one as well ..
20121lt is offline   Reply With Quote
Old 06-27-2012, 11:01 AM   #117
20121lt
20121lt's Avatar
How do i get one
Old 06-27-2012, 12:44 PM   #118
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Originally Posted by 20121lt View Post
How do i get one
PM NH-SS for info.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 06-27-2012, 06:23 PM   #119
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
Ordered my bushings!
Old 06-27-2012, 11:59 PM   #120
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
I ordered a set as well. I can't wait to have a working shifter again!
2011 Camaro 1SS/RS
Cammed, Sprayed, and Beaten Daily.
Aries240SS is offline   Reply With Quote
Old 06-28-2012, 12:15 AM   #121
copper98
Camaro 5 Muscle
copper98's Avatar
Drives: 2012 CAMARO 2SS/RS
I had similar problems with mine and my brothers Camaro also. A few guys in the club recommended me to switch to MGW shifter and all i can say is that I would never try another shifter other this MGW. If you ever decide to try you it you will see what I mean. Your post was great and appreciate all the details during the install. - glad your shifter is working better.
Mods: Air Raid C.A.I., Custom Ported/Polished Throttle Body, Kooks 1 7/8 Headers, Dyno Tuned , LPE 3.91 Gears, BMR Differential Bushings, R/X Oil Catch Can, X-Pipe, Borla Exhaust, MGW Shifter, Hawk-HPS, SS brake lines, BMR front & rear sway bars, BMR rear sway bar end links, Pedders front radius rod bushings, Spohn front sway bar end links, BMR rack/pinion bushing, BMR Coils 1" drop, BMR Trailing Arm, BMR Toe Rods, Pedders Sub-Frame bushings, BMR Sub-frame Connectors, BMR Driveshaft Tunnel Braces, GM Strut tower brace, custom painted bowties
copper98 is offline   Reply With Quote
Old 06-29-2012, 03:30 PM   #122
Aries240SS
My set just showed up. All I can say is WOW. Professionally packaged, perfectly machined, and better quality than I could have hoped for. I'll put these in tomorrow morning when it's not 109° outside.
Thank you NH-SS!
2011 Camaro 1SS/RS
Old 06-29-2012, 06:47 PM   #123
NH-SS
Drives: 2010 SS2,6M
USA made,.. what else would you expect ? Glad your happy. Please follow install directions.
NH-SS is offline   Reply With Quote
Old 06-29-2012, 08:53 PM   #124
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
NH-SS
JRE installed my new hurst sts with the updated bushing and the bernished the new bushing with my pin
Not that i ever had slop in my shifter but this is tight and i am diggin the new shifter
Thanx for great quality work
Roger
Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 06-29-2012, 11:34 PM   #125
From The Future
needs gas money
From The Future's Avatar
Drives: 2010 Camaro SS IOM 6M
My bushing kit came in the mail yesterday and I was completely happy about it. Such nice looking new bushings and a well written set of instructions too. It was all so carefully packaged, NH-SS is the man.
Something semi-weird has happened though. I bought a new shifter pin and clips from my local dealer and brought them home today. I looked at the pin and bushings at my desk and discovered that the new shifter pin I bought is much smaller than the hole through the center of the bushing, it totally rattles around inside the bushing.
I think they must have sold me a smaller than normal shifter pin or something. I saw the parts diagram on the parts guy's computer, it looked like the right part to me. I guess I will have to pull the used pin from my car tomorrow and see if it fits the new bushings.
The pin is supposed to be a tight fit inside the bushings, correct? After viewing the photos in this thread I am under the impression that the pin just barely fits through the hole in the center of the bushings and the burnishing process is to make the pin fit correctly and move smoothly.
I guess I will find out for sure once i remove the existing pin from my shifter and compare it to the new pin I picked up at the dealership today.
From The Future is offline   Reply With Quote
Old 06-29-2012, 11:41 PM   #126
RogerBzSS
RogerBzSS's Avatar
Yes pin needs to be bernished / fitted in to the new bushing
Sounds like you got the wrong pin from the dealer???
