| Suspension / Chassis / Brakes Suspension, chassis, and brake components |
| View our official forum sponsors list. |
Thread Tools |
JUICED MOTORSPORTS
![]() Drives: 2012 2SS CAMARO 45th Join Date: Apr 2011
9" rear end G-FORCE REAR END PAKAGE FROM JUICED MOTORSPORTS!!!! AWESOME PRICING
Gforce Engineering is proud to introduce the bolt in 9" fabricated IRS rear.
The Gforce Engineering bolt in 9" IRS kit replaces everything from the transmission back with our heavy duty components. Our bolt in 9" IRS eliminates all the flex, noise and clunking (and weak parts) found with the OEM rear plus you get a piece of mind knowing that your riding with the strongest rear you can get for your ride. Our 9" IRS is rated for 1000+hp Our 9" IRS is fully fabricated in house on our state of the art cnc fabrication equipment. Our 9" kits come without the pumpkin, we can supply your pumpkin from Strange or Moser if needed. We recommend going with the Strange Pro Iron pumpkin with the 31 spline Eaton Truetrac or the Moser case and truetrac. You can add a pumpkin below in the options. The 9" kit comes complete with: * - Fabricated bolt in 9" housing that bolts up to the factory location * - Heavy duty front mount with BMR bushing * - 300m billet inner axle stubs * - 300m Anti Wheel-hop axles with our heavy duty cv joints * - 4340 billet outer axle stubs * - 1 piece 3.5" Aluminum driveshaft (Carbon fiber also available) ![]() http://www.juicedmotorsports.com/201..._cam9inch.html
Get more Power per Dollar!!!! We carry all the hot new products for your 5th gen! CAI, Roto-Fab, Solo, Corsa, MBRP, ARH, Stainless Works, MRT, SLP, Procharger, Whipple, BMR, Diablosport, Superchips, Street Scene, VFN Fiberglass and much more. Contact us for your Camaro5 discount today! Call us at 224-63-JUICE - 224-635-8423 |
JUICED MOTORSPORTS
If you plan on hitting the track with any amount of real power......this is a must!
JUICED MOTORSPORTS
6k launch on slicks......no problem
JUICED MOTORSPORTS
Awesome products!
JUICED MOTORSPORTS
Killer deals
#6 |
JUICED MOTORSPORTS
ORDER UP
#7 |
JUICED MOTORSPORTS
If you plan on any amount of track duty with solid power numbers......you really can't pass these up!
#8 |
JUICED MOTORSPORTS
BIG TIME POWER HOLDING
#9 |
JUICED MOTORSPORTS
These things don't break!!! If they happen to GForce backs them up with a lifetime warranty.
#10 |
JUICED MOTORSPORTS
THE REAR END YOU CAN TRUST AT THE TRACK AND THE STREET
#11 |
JUICED MOTORSPORTS
No more worring about overpowering your rear end
#12 |
JUICED MOTORSPORTS
kILLER PARTS
#13 |
JUICED MOTORSPORTS
WORRY FREE LAUNCHES ON STICKY TIRES....EVEN WITH BIG POWER
#14 |
JUICED MOTORSPORTS
KILLER SET UP
#15 |
JUICED MOTORSPORTS
GFORCE 1320 - THE ONLY NAME YOU NEED TO KNOW WHEN IT COMES TO YOUR REAR END!
#16 |
JUICED MOTORSPORTS
ORDER UP
#17 |
JUICED MOTORSPORTS
IF YOU WANT TO LIFT THE FRONT TIRES...
#18 |
JUICED MOTORSPORTS
DON'T EMBARASS YOURSELF AT THE TRACK....NO ONE WANTS TO GET TOWED HOME
#19 |
JUICED MOTORSPORTS
THE END TO YOUR REAR END ISSUES!
#20 |
JUICED MOTORSPORTS
ANY GEAR SIZE YOU WANT
#21 |
JUICED MOTORSPORTS
9" IT
#22 |
JUICED MOTORSPORTS
THROW A 1000RWHP AT IT.
#23 |
JUICED MOTORSPORTS
9" IT AND DONE!
#24 |
JUICED MOTORSPORTS
STICKY TIRES AT THE TRACK WILL GERNADE YOUR REAR END
#25 |
JUICED MOTORSPORTS
ORDER UP
| Tags |
| 9" rear end, axles, drivetrain, g-force |
| Thread Tools | |
