Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > V8 Bolt-Ons & Tunes
Old 05-25-2012, 01:13 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2010 X5 Camaro Turbo
Melling High Volume LS3 Oil Pump :: 2010-2012 Camaro SS @ Phastek Performance
2010, 2011, 2012 Camaro MELLING/MTI High Volume LS3 Oil Pump
High volume performance upgrade for LS Engine. This oil pump provides more oil volume at a higher pressure relief setting. The relief spring installed in the pump is designed to increase the internal pressure setting an additional 10 psi over stock. A stock pressure spring is supplied with this pump which will reduce the internal bypass pressure back to the stock psi setting.
- 18% increase in volume over stock oil pump.
- The cast aluminum housing is CNC machined and hardcoat anodized.
- The cast iron cover is CNC machined and phosphate coated.
- The relief valve features a screw in valve plug with the optional lower stock spring supplied.
- Uses stock 1-1/4” bolt on screen.
Fits GM GEN III & IV 4.8L-5.3L-5.7L-6.0L and LS3 6.2L
Place your orders at www.PhastekPerformance.com
Sales@Phastek is offline   Reply With Quote
Old 06-12-2012, 11:54 AM   #2
Sales@Phastek
post or pm with questions
Old 06-18-2012, 04:10 PM   #3
Sales@Phastek
HI !
Old 06-26-2012, 06:17 PM   #4
Sales@Phastek
taking orders
Old 07-10-2012, 02:29 PM   #5
Sales@Phastek
place your orders
Old 06-25-2013, 12:37 PM   #6
h018871
Geoff
h018871's Avatar
Drives: 2013 1LE Blue
what do you see as the pros & cons for the 10psi pressure increase?
i can see the volume increase side, make sure that the pressure relief stays open longer and the oil channels stay full at higher oil temps.
h018871 is offline   Reply With Quote
