| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: - Join Date: Nov 2010
Cats Delete result in loss of power?
I have a 2011 L99 with Stainless Works Retro Chambered Catback ... Recently I decided to replace the original cats with fabricated pipes in order to increase the true sound of the car ... I have made minor tunes and switched off AFM, and the engine light sensor ..
Having done that, I feel the car became lighter, but I feel that the power push when accelerating in a straight line is less than when I have my original cats on... I feel the car lost power without the original cats on .. Any idea why is this happening? Have I lost pressure when I installed fabricated pipes? Do I need to buy a CAI to solve that? Or do I need a basic tune? P.s.: The tuner wanted to increase the ignition timing and delete the factory's torque management but I was too concerned to do that as the car is still new and still didn't run over 10,000km. The car is not a daily use and I thought that such increase in ignition timing and deleting torque management would harm the engine in the long run. |
![]() ![]() Drives: 10' 2SS LS3 M6 Join Date: May 2012
i'd say the issue is in your tune.
10'SS- 417ci|ECS Novi 2200|Alky Control|10 Rib|ATI Balancer|Squash E85|ID2000|Fast 102|FSP custom grind cam|TSP LT's|Vmax|Pfadt|BMR|Farks|Mantic 9000|DSS Driveshaft & Axles|JRE Billet Caps|Eaton Tru-Trac|LPW|Rx|Katech|Barton|Corbeau|Braille|TSW|Weld |NT05R|-Mine
10'GT500- JLT 123mm|Cobra Jet 65mm TB|VMP Elbow|VMP 2.5 pulley|Dynatech LT's|AFCO Heat Exchanger|Cobra Jet drag springs|MGW|Dark Stars|Mickey Thompson ET-Wifes https://www.youtube.com/user/CamperRacing Matt @FSP is the best vendor money can buy! http://www.floridaspeedandpower.com/2010-camaro-ss/ |
It's not the tune .. I felt that before I did the minor tunes .. The car had a lot of power with the original cats on .. Now with the fabricated pipes installed instead, the car acceleration is less powerful when accelerating in a straight line ...
![]() Drives: 2012 camaro 2ss Join Date: Apr 2012
I'd say tune too.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
You should have definitely increased HP by deleting the cats (15hp or so). I've seen dyno sheets from several cars making 15-18 hp from removing the factory cats.
Also, because you have an L99 A6, I would suggest reducing some torque managment. A good tune on an L99 A6 shows a real nice jump in Torque.
#6 |
Out Front!
It's that whole loss of back pressure theory that no one seems to believe. I got the same feeling when i ran straight pipes. Just seemed to move the power band up higher in the RPMs. Its been proven with a dyno that you don't lose power. If you search "back pressure" you'll find the thread. It focuses more on loss of back pressure due to straight pipes, but it's the same concept. Hope that helps.
B Troop, 3-17CAV - Out Front
#7 | |
Could be true too. I feel more on the side of the power band, but even so you still have the power there. |
#8 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
It's definitely tune related...you lost some torque on the lower side of the band by removing the cats...A good dyno tune will fix that and even add a few more hp. Ultimately you have increased performance, just need to do it the right way
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, DOUG THORLEY LT'S, MAGNAFLOW HIFLOW'S, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM KIT & DYNO TUNED BY TORQ (WWW.GETTORQ.COM), 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - MUSTANG DYNO RESULTS: 431 RWHP 390 RWTQ
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 E92 M3 Join Date: Nov 2009
the car has a power band, people tend just to look at what you gain up top.people ALL the time report loss of low end power with straight pipe anything. specially without a tune.
idk why you dont tune, you already messed with the computer enough to the point where you are running a aftermarket tune. |
#10 |
Add an X pipe and you'll be good.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Doesn't the Stainless works catback come with one?
Halltech Yellowjacket fed Kooks LT's/ Dynomax VT Pfadted (springs/sways) JRE tuned Aint nobody got time for that |
#12 |
SoCal HT5 San Diego
Drives: 2010 2SS/RS A6 Join Date: Apr 2012
Yes it does
Sent from the rocket in my pocket, my all powerful DROID BIONIC.
Stainless Works 1 7/8 long tube headers w/high flow cats, Stainless Works 3" retro chambered catback, CAI Inc intake, JRE scoop, RX catch can, Jannetty tune, numerous visual appearance mods. |
#13 | |
Lots of guys are running long tubes, no cats, and catback exhaust making excellent power and torque. Butt dyno is broken or back to the tune issue.
#14 | |
Anyways, i had a basic tune and it seems that increasing ignition timing and disabling/deleting the factory's torque management solved the issue .. The car kicks/accelerates very well in cruising speed! Don't feel a loss of back pressure, a good basic tune solved it i guess .. I guess switching off AFM and the Engine Light sensor with factory tune was what caused the power loss upon replacing the original cats with straight pipes .. |
#15 |
![]() ![]() ![]() Drives: 2006 F150 Lariat Join Date: May 2010
It was the lack of a tune without cats, not really just cutting AFM
#16 |
![]() Drives: G8 GXP manual Join Date: Sep 2010
In what type of driving are you noticing the loss of power?
I can see you losing low end TQ in day-to-day driving with the car feeling more sluggish. That can happen. Like someone's mentioned, you likely moved the power curve up higher in the rpm. It's all about exhaust scavenging to keep the flow out of the engine at it's optimum. Can a tune fix that? Not sure.
2009 GXP, Manual with Sunroof
Zeta platform, LS3,TR6060 tranny ... ya, it's a 4-dr Camaro! Borla cat-back, H&R springs, & Sprintbooster & I love it! |
#17 | |
![]() Drives: 2010 camaro 2SS Join Date: Mar 2012
#18 | |||
Original Bumblebee Owner
Drives: 265hp ZX-14, 500hp Silverado, V-ROD Join Date: Apr 2009
So tired of read the "backpressure" myth. Truely is pure crap...
| Thread Tools | |
