Forced Induction - V6 V6 Supercharger, turbo, nitrous discussions
Old 05-26-2012, 06:23 PM   #1
Dobbins
Drives: 2010 LLT CGM STS Turbo- 500 HP V6
Meth kit issue? Help?
So I got the meth kit installed this last Thursday but it is not getting tuned until this Thursday. Pretty much it's really annoying driving it because it just makes the fuel too rich and my car is weak when it hits boost. They did just a little drivability tune with the air fuel ratio but didn't put it on the dyno. Is there any way I can temporarily unplug it or something to try to have fun with my car at all for this week. I was told I could just pull the plug and it would be back to normal but I wanna hear from someone legit. So any solution for me??
Dobbins is offline   Reply With Quote
Old 05-26-2012, 06:26 PM   #2
Supercharged SS
Supercharged SS's Avatar
Drives: 2010 Camaro
Does it have a controller? If so just turn it to 0 and it shouldn't spray any meth. I have a cooling mist kit on my 335D BMW and that's what I do. Otheriwse, just pull the fuse. Assuming there is an inline fuse. What type of kit do you have?
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
Old 05-26-2012, 06:46 PM   #3
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2011 SIM 1LT M6 TT/ 2001 Malibu GTP
Just like Supercharged SS said turn your controller down to 0. What I do to mine is pull the fuse for the pump. Which should be in the back by the battery if your bottle is back there also. And if you do pull the fuse make sure the wire that is connected to the battery is taped up so you won't ground it out and blow fuses everywhere lol.
Sent from my iPhone 4s using Tapatalk
Can't_C_Me is online now   Reply With Quote
Old 05-26-2012, 06:47 PM   #4
Dobbins
It is an aem kit. And ya there is a control box by my pedals. They didn't go in depth about it when they gave it to me and this is my first time with this. What fuse would I pull?
I just checked and on the control box it has no dial or anything just numbers that correspond with errors.
Old 05-26-2012, 06:48 PM   #5
Can't_C_Me
Can't_C_Me's Avatar
^^ I told you how up top.
Old 05-26-2012, 06:55 PM   #6
Dobbins
I'm sorry, so there is one plug that connects to the engine, I'm just confused because it just seems like whatever plug I pull methyl will just be spraying everywhere. And there is no control on my control box. Sorry to be difficult but I don't get which fuse. There is one that connects to the engine, but my actual tub is on the right side opposite of the battery. I see a plug there that kinda looks like a drain plug. Is that what I should pull and tape up? But like I said it just looks like fluid will drain everywhere.
Old 05-26-2012, 07:19 PM   #7
Can't_C_Me
Can't_C_Me's Avatar
When I get to my car I will post pictures of my fuse plug and my controller. If you have the AEM we have the same one and if you look at your controller real well. There is a test button in a small hole and 2 small knobs that you will need a very small screw driver for. Those knobs need to be turned to 0. If you can't find your fuse that's your only option.
Old 05-26-2012, 07:24 PM   #8
Dobbins
Ok that would be awesome if youd send a pic. I see some but I don't know which. And ya If I still can't see it in the pic I can do the control box thing
Old 05-26-2012, 08:30 PM   #9
Can't_C_Me
Can't_C_Me's Avatar
THIS IS THE CONTROLLER AND WHAT THE KNOBS LOOK LIKE. JUST TURN EVERYTHING DOWN TO ZERO.
THIS IS THE FUSE FOR THE PUMP AND HOW THE HOUSING AND FUSE LOOK LIKE. JUST PULL THE FUSE OUT.
Old 05-26-2012, 08:44 PM   #10
Dobbins
Thanks a lot! I'm gonna try to figure it out when I get back to my car.
Old 05-26-2012, 09:04 PM   #11
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Unplug it. Problem solved.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 05-27-2012, 10:12 AM   #12
Dobbins
Ya I literally just cannot find it, I see the wire but I cant find it its tucked way back in there. Before I do this though, is it bad that he changed my airfuel ratios?
Old 05-27-2012, 11:03 AM   #13
Can't_C_Me
Can't_C_Me's Avatar
If its running on a drivability tune shouldn't matter. As it isn't tuned to the meth kit yet. But just test it out, go into boost with the kit and record your AFR's. Then lower the controller (which is turning it off) and hit boost if it starts to go past 12.5-13 AFR. And not going back down to 10.5-11.5/12) Then let off as its tuned to the kit.
Old 05-27-2012, 11:19 AM   #14
Dobbins
ok thanks a lot
Old 05-27-2012, 12:23 PM   #15
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 2012 LFX/2011 EcoBoost F-150
I believe the way the AEM controller works is that the left screw sets the boost at which it starts spraying and the right screw sets the boost at which it is at 100% spray. You would want to set both screws all the way up (turn to the right) to not spray anything.
EFR Twin Turbo LFX-GPI Tune-ZL1 fuel pump-10:1 CR forged pistons-3.45 gear-Meth Injection-BMR Trailing Arms, Bushings & Sway Bars-Drag Radials-CircleD 4000 Stall-GPI Fuel Enrichment System
586 RWHP & 606 RWTQ @20 psi on 93 Octane (unlocked converter)
1/8 mile -- 7.158 @ 102.10 (20psi)
Build Thread
GretchenGotGrowl is online now   Reply With Quote
Old 05-27-2012, 05:19 PM   #16
Dobbins
Ya something bad happened. I undid the plug and as soon as I started driving a high pitched alarm sounding beep was constantly going so I stopped and I was losing oil out of my exhaust and out of my turbo. I just put the plug back in and everything seems to be fine so I think I'll just let it be until Thursday!!
