BeckyD@RodgersChevrolet
Old 05-26-2012, 09:49 PM   #1
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
Vararam plus a diablo tuner?
If I were to do these mods how much extra RWHP could I expect?
jimmy5 is offline   Reply With Quote
Old 05-27-2012, 02:36 PM   #2
G8GT4now
G8GT4now's Avatar
Drives: 14 SS Sedan
If you are going to void the power train warranty, at least do intake, pulley, tune, hx. That would get you around 80 to 100 hp.
G8GT4now is offline   Reply With Quote
Old 05-27-2012, 02:38 PM   #3
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
Long tube headers most big for the buck with tune.
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois
TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
JL Audio XD400/4 amp
Pfadt trailing arms & tie rods sway bars.
pedders street 1 package. ,Hurst short throw shifter
With bronze bushings .
skar is offline   Reply With Quote
Old 05-27-2012, 06:34 PM   #4
jimmy5
jimmy5's Avatar
Will just a vararam void the warranty or is it the tune that does it?
Old 05-27-2012, 06:37 PM   #5
MikeMoach
MikeMoach's Avatar
Drives: 2010 RJT 2SS/RS
The tune voids it, I'm also looking into the vararam but prolly gunna do it the same time I do my headers like scar said big bang for ur buck
MikeMoach is offline   Reply With Quote
Old 05-27-2012, 07:02 PM   #6
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Vararam doesn't fit the ZL1...
Did you mean to post in a different subforum ???
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 05-27-2012, 07:05 PM   #7
G8GT4now
G8GT4now's Avatar
Drives: 14 SS Sedan
That is very debatable on the CTS V forums. Once tuner did headers only and said they were worth 8 RWHP with the stock tune. The biggest restriction is the first CAT, not the manifolds. Plus headers plus install is around $2K.
Old 05-27-2012, 10:15 PM   #8
skar
skar's Avatar
Most do hi flow cats with headers.
Old 05-28-2012, 06:13 PM   #9
hognutz
hognutz's Avatar
Drives: 2013 ZL1
most tuners say on lsa cars longtubes will will lose 1-2 lbs of boost. So you only net a few HP unless you put different pulley's on the car.
I have been reading on this as I would love to add them but if you just add longtubes and then tune sometimes the results are disapointing.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 06-14-2012, 08:56 AM   #10
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Or no cats at all
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 06-17-2012, 11:14 AM   #11
frcdfed
Drives: 04 GTO
Unless thats the only mod you plan on doing yes they are pointless for the price. Add a tune, bolt ons, a pulley swap and youll be happy you did, you wont see much of a change going to high flow cats on the dyno, more then likely you will see a large MPH change at the track.
When i had a Maggie 112 on my GTO i was stuck running 11.7 @ 114.XX, gutted the cats and ran a test pipe, showed no increase in power on the dyno, but ran 11.4x @ 118.XX.
frcdfed is offline   Reply With Quote
