Tom Henry Racing
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 05-13-2009, 07:02 PM   #1
kozzmo49
Drives: 2010 camaro ss rs
axle back vs catback exhaust
Can someone please explain to me the advantages and disadvantages of both of these. Is our stock piping good enough and wide enough where getting an axle back wouldlnt make that much of a difference?
kozzmo49 is offline   Reply With Quote
Old 05-13-2009, 08:28 PM   #2
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
Big Bird Style -
The larger your exhaust pipe the easier it is to get the air out of your motor, thus the more air you can put in, thus making more power.
I am unsure what the size is on the stock exhaust though.
Magnaflow Cat back / ROTO-FAB Intake / Whipple Kit / RDP Tune.
580hp - 650Tq
franknbeans is offline   Reply With Quote
Old 05-13-2009, 09:09 PM   #3
SemperFi
U.S. Marine Corps
SemperFi's Avatar
Drives: 2009 Ducati Streetfighter
Originally Posted by franknbeans View Post
Big Bird Style -
Yes, but keep in mind that the engine is only going to suck in so much. Also if you are getting much bigger pipes, you are going to have to get new headers as well.
Then when you realize you made more space than you need, get it supercharged.
Texas Residents: Join the Texas social group!
Semper Fi!
SemperFi is offline   Reply With Quote
Old 05-13-2009, 09:13 PM   #4
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
Big Bird Style -
bigger isn't always better.
the stock 2.5 exhaust is pretty big, should support up to about 550 rwhp no problem without being a hinderance. They have nice bends to them too, the real restrictions are probably at the mufflers and maybe the cats.
THE EVIL TW1N is offline   Reply With Quote
Old 05-13-2009, 09:15 PM   #5
THE EVIL TW1N
Banned
also, with bigger piping you will lose back pressure, which will result in the possible loss of low end tq without necessarily gaining anything up top. the dyno might not reflect it at WOT, but can be felt at part throttle.
Old 05-13-2009, 09:34 PM   #6
pruettfan
Drives: 2010 Camaro SS / 2011 Z28
I am pretty happy that there will be several AXLE back options. This allows for a pretty cheap way to improve the sound of the car and perhaps get some increase of performance. The Cat back systems theoretically offer a larger diameter or straighter bend which could increase performance. Since most of us won't be going with a full exhaust and header setup for ultimate performance we are more likely doing exhaust for a more robust sound rather than all out performance. I anticipate that I will go with an Axle back solution to get a little more performance sound rather than the ultimate exhaust system.
The additional benefit will be to not have to see those huge mufflers hanging under the car.
pruettfan is offline   Reply With Quote
Old 05-13-2009, 09:51 PM   #7
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
http://www.uucmotorwerks.com/html_pr...torquemyth.htm
Kyle2k is offline   Reply With Quote
Old 05-14-2009, 01:41 AM   #8
Epitaph
Custom User Title
Drives: Fast
Thank you ^
Remember, you can get different HP/Tq ratings with different mufflers. Just because you go with Borla rather than Magnaflow, it doesn't mean you're going to get more Tq. It depends on the size of your pipe, initial HP/Tq, etc... It would be cool if someone did a comparison on stock Camaro's similar to these:
http://allfordmustangs.com/forums/5-...-shootout.html
http://www.v8s10.org/forum/viewtopic.php?f=43&p=155840
As you can see, that was 7 years ago, and there wasn't THAT much of a difference. Of course, if you ran the test again, the numbers would change. Also, I have no idea if this was an average or what... It would be cool to see some new tests.
I searched around for axel back vs cat back, and found several different answers, basically:
If you're wanting more HP/Tq gains, just replace the entire exhaust system (including Long tube headers IF AND ONLY IF you don't need to pass inspection! If you do, get a high-flow cat put on there).
If you're looking to change the notes your exhaust plays, get the muffler changed out.
Epitaph is offline   Reply With Quote
Old 05-14-2009, 01:50 AM   #9
GMtothecore
"That Guy"
GMtothecore's Avatar
Drives: Camaro SS...........what else?
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
Good info, thanks guys
GMtothecore is offline   Reply With Quote
Old 05-14-2009, 02:25 AM   #10
FNKNSTN
Banned
Drives: A Black Car
good posts, dudes
FNKNSTN is offline   Reply With Quote
Old 05-14-2009, 06:26 AM   #11
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
Originally Posted by Kyle2k View Post
There is more involved here than this article discusses. This article seems to say that the biggest exhaust you can bolt on your car results in the most power. This is far from reality, especially at lower-midrange rpm. An appropriate size exhaust produces the best all around power, too big of an exhaust will always result in less low end power. This has nothing to do with A/F ratio. The exiting exhaust gases of any engine and the velocity of those gases create a scavenging effect to help remove burnt gases and draw in a new intake charge (where the intake and exhaust valves are both open-the overlap). This is what makes long tube headers so effective. Put a set of 2 1/4" race headers on a bone stock LS1 and I guarantee you will lose a ton of low end power. The same thing applies, maybe less so for the rest of the exhaust being too big. The further downstream, the lower the effect on scavenging is.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
72 VW Beetle, 2275cc, Dual 44 IDF's
rayhawk is offline   Reply With Quote
Old 05-14-2009, 08:07 AM   #12
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro 1ss/rs
ok question say if i were to change stock pipes from 2 1/2 -3 would that be that big of a difference
lakersftbl69 is offline   Reply With Quote
Old 05-14-2009, 09:33 AM   #13
franknbeans
Whipped
Drives: 2010 CAMARO
It's not a "big" difference but I was running a 3" exhaust on my Srt-4.
Also, does anyone know the manufacturer of the mufflers on the GM exhaust?
580hp - 650Tq
Old 05-14-2009, 09:36 AM   #14
hp for life
Drives: 93z28 with a few mods
Going from 2.5 to 3 on a stock motor will net you a lose of bottom end TQ. You will see it on a dyno and feel it alittle but i don't think 1/4 mile times would suffer. As said before dual 2.5 pipes can support 550rwhp. A plus side or down ( dending on ears) is you will gain more bass in your exhaust note. On my 93 I run long tubes to a off road y-pipe into a 4in i-pipe to a stock muffler with the square tips. I've yet to hear a car sound like mine.
hp for life is offline   Reply With Quote
Old 05-16-2009, 12:17 PM   #15
franknbeans
Whipped
Drives: 2010 CAMARO
580hp - 650Tq
Old 05-16-2009, 01:52 PM   #16
THE EVIL TW1N
Banned
3" dual exhaust??
I know pretty much ALL the 03/04 Cobra guys run 2.5 Catback (stock was 2.25) and midpipe unless they are running a KB or Whipple (600 rwhp) and even then, they don't always jump onto the 3".
Old 05-16-2009, 02:55 PM   #17
blackedout010
Drives: on order black 2010 2ss
3" dual exhaust??
yea the cobra run stronger off the exhaust backpressure with the 2.5 up to around 600+rwhp!! however a lsx motor thats been modded (cam, heads, etc.) runs better with the 3 inch piping.
blackedout010 is offline   Reply With Quote
Old 05-17-2009, 10:51 PM   #18
LDGn63
LDGn63's Avatar
Drives: WNABEE
Samsonite?
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Old 05-18-2009, 11:03 AM   #19
davidj
davidj's Avatar
Drives: .
FYI going from 2.5 to 3 IS a big difference. 2.5 = 4.906 Sq/in 3 = 7.065 Sq/in. So you can see only a 1/2" diff flows a lot more than you would think.
davidj is offline   Reply With Quote
Old 05-18-2009, 11:08 AM   #20
franknbeans
Whipped
Drives: 2010 CAMARO
Not dual. .it was a srt-4. . 4cyl turbo.
But it was 3" from the turbo back
580hp - 650Tq
Old 05-18-2009, 11:10 AM   #21
franknbeans
Whipped
Drives: 2010 CAMARO
Originally Posted by LDGn63 View Post
Samsonite?
what?
don't they make TV's?
strike that.. luggage
580hp - 650Tq
Old 05-18-2009, 11:14 AM   #22
SilverBulletSS
SilverBulletSS's Avatar
Drives: 2004 R/Cab F-150
I believe it was quoted on here as Borla....I think they said they made the GMPP catbacks, as well....
Future: 2SS/RS M6 Silver Ice Metallic
SilverBulletSS is offline   Reply With Quote
Old 05-18-2009, 11:52 AM   #23
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
3" dual exhaust??
to pretty much everything here. Just because the pipes will support the airflow, doesn't mean the engine is pumping that amount of air. As the exhaust gets further from the combustion chamber, it gets cooler and slows down. When it slows down efficiency is less. It's my understanding what the headers and exhaust should do is completely evacuate the chamber of all burned and unburned gasses on the exhaust stroke. In order to do that, the headers/manifold and the rest of the exhaust has to be tuned in order to facilitate a vacuum to extract the chamber. The bigger pipes will retain less heat because there's more surface area to radiate it, therefore the exhaust gasses will cool sooner. Unless you have an engine that pumps enough exhaust, you'll just have a loud exhaust and not make use of all the power the engine has the potential to generate.
But the engine has to support that additional flow, otherwise you're adding restriction within the exhaust and not vacuuming all the gasses out of the combustion chamber on the exhaust stroke.
I believe Borla has specifically designed the GMPP exhaust and has two separate designs for their mufflers/CBs.
Personally, I'll be looking at finding an X-pipe system sans resonators with good flowing mufflers. If my engine can support dual 3-inch pipes I'll go that route, otherwise, I'll look into modifying the H-pipe and resonators. No LTs in Cali' mean shorties and OEM cats' :(
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 05-18-2009, 12:15 PM   #24
davidj
davidj's Avatar
Drives: .
I was just comparing the two sizes nothing more.
Old 05-18-2009, 01:56 PM   #25
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Question about potential exhaust setup. Xanthos Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 22 07-29-2011 10:59 AM
Exhaust Plans JMAN311 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 29 10-23-2008 02:30 PM
Factory Exhaust Option SPECULATION!!!! jmliptak Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-21-2008 10:13 AM
The 2010 Camaro, back then and now... bolteon593 Camaro Photos | Spyshots | Video | Media Gallery 15 06-25-2008 05:36 PM
Muscle car exhaust sound linkwpc 5th Gen Camaro SS LS LT General Discussions 19 12-09-2007 06:50 AM
