Thread Tools |
Muscle Maniac
Drives: 2012 Camaro ZL1 CRT Join Date: Nov 2009
K&N filter element
Will a K&N filter element do any harm installed in the stock air box? Will that allow too much airflow in for the stock factory tune?
MasterChief BT
USN (Retired) 2012 Camaro ZL-1 CRT VIN 2G1FJ1EPXC9800357/Arrived 4-21-2012 Reliable Chevrolet Richardson, Texas Life is GOOD ! ![]() |
I used to be Dragoneye...
As long as you're responsible when oiling the filter (don't over-oil), it shouldn't be different from any other car.
Muscle Maniac
Thanks....I had to ask. So much about a CAI needing a tune I figured that air flow thru paper element was dialed in to the factory tune. Guess with forced induction airflow is finicky with stock tune.
MasterChief BT
It is...but even most of the cold air intakes can be used without tuning. The beauty of a Chevy engine is that it's very smart. It will adjust as much as it can...in the case of a minor intake change - the difference is not usually significant enough to require a new tune.
![]() Drives: '98 Camaro Z28, '06 Z06 Join Date: Feb 2011
But a lot of companies have said you will lose power with a CAI kit if you don't tune it. So I would be worried. LS3 and L99 you would be fine, LSA
'10 Camaro 2SS/RS A6 Sold :( ARH, FM Super 44's, K&N CAI, ADM scoop, Diablo Tune, RX catch can.
'98 Camaro Z28 M6 TSP headers, true duals, AIR/EGR/AC/muffler delete, CAI, Subframe con., shock tower brace, Stg. 2 T56 rebuild. Monster Clutch Stg. 2, Electric Water Pump, TT2 wheels, 315 NT555's '06 Z06 2LZ, Cam, P/P/M Heads, FAST Intake/TB, ARH, CAI, HP Clutch/FW, C5 Axles, Pfadt Coilovers/Poly Bushings, Carbon Fiber: Everything, lol. HID's, 360 Forged Spec 5's/Invo's, Custom Interior. 550 RWHP http://www.camaro5.com/forums/showthread.php?t=235911 |
#6 |
They have? If so, I'd really like to read the thought process behind such a statement...
#7 | |
Originally Posted by adamgl I'm sure he does. But I was looking for a Cold Air kit to put on right when I get the car and not void the warranty. Then a year or 2 later, say by by to the warranty and get a pulley, headers and tune. Might as well use it as an excuse to get all those upgrades at once, lol. Unfortunantly testing shows very sensititive maf on these cars .Even changing just a filter could cause issues and power loss. __________________ ![]() Andy Mages Owner/Operator 214-228-8782 admperformance@gmail.com www.admperformance.com http://www.camaro5.com/forums/showpo...1&postcount=17 http://www.camaro5.com/forums/showthread.php?t=216462 I've heard similar from other sources.
#8 |
![]() Drives: 12 ZL1 & 08 Suzuki Boulevard C50 Join Date: Oct 2011
I have always run K&N Filters in all my cars. I just went over 1500 miles and I have installed a K&N tonite. I will let you know if I have any issues. I also got the K&N Oil filter to change the oil this weekend.
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
#9 |
![]() Drives: 2012 ZL1 Join Date: Feb 2012
I also have a K & N installed in my car and I can say the improved air flo
Seems to be a positive improvement. The Z to me feels like it pulls harder, It deffinately didn't hurt. |
#10 |
Muscle Maniac
I installed a K&N filter element tonite also. Seems to have a little better pick up maybe. I also took those 2 molded air inlets off the stock air box. When I get on the gas now you can really hear that supercharger wind up. Sounds cool!
MasterChief BT
#11 |
I'm broke in so I've really mashed it hard before and after the K&N.
This car could be very dangerous in the wrong hands. It jumps off the line Way harder than the ss and hits top revs. Thru the gears really quick. Kinda scary fast. Dut a little more wouldn't hurt. |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Accord Join Date: Oct 2009
Where do the 2 air inlets point to? I've read that the ZL1's air box had mods over the CTSV box to help performance. Just because it sounds better doesn't mean you're getting better performance.
#13 | |
Petro-sexual
Drives: Ultra-Grin Join Date: Oct 2006
Also - I read the OEM air filter is already a high-flow unit, consisting of fewer pleats to increase flow. It'd be interesting to see what gains there would be. I would lean more toward an oil-less element, but to each his own
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
#14 | |
#15 | |
Petro-sexual
#16 |
Muscle Maniac
They point to the front. The opening in the molded inlets are tapered and "necked" own in the middle. CTS-V has 1 air inlet and ZL1 has 2. 1 of the inlets is very small. I think a bigger opening allows more cfm upstream. I surely don't think it would have a negative impact. If anything one of the inlets seems to be getting input from the front side of the radiator. Guess the thought maybe a cooler air inlet but I don't think the temp in that area has a significant difference. To me, before and after, throttle response seems a little better after k&N install....but that's just me!
MasterChief BT
#17 |
![]() Drives: ZL1, Genesis, Grand Cherokee Join Date: Feb 2012
I went ahead and ordered the KN 33-2434 filter which is the same part number as the one for the SS, BUT I just noticed the book has different GM part numbers on section 11-14(service and maintenance). Are they not the same?2012 CHEVROLET Camaro ZL1 6.2L V8 F/I - AllAir Filter
- Designed to Increase Power - Million Mile Limited Warranty 33-2434 |
#18 | |
Fast Orange
#19 |
I just got the KN today. It fits very well, it's just not as deep as the original filter - maybe 0.5 inch less height. It shouldn't matter.
I think it has a bit better/quicker throtle response and the supercharger sound is just a bit louder. I just went around the block... I like it anyways and I believe it's worth it, especially in about 5k miles when the original one will start to clog up. I had them on all my cars and can't complain. I just wish they made the CAI with no tuning required. |
| Thread Tools | |
