Caryle Racing
Old 05-27-2012, 09:55 PM   #1
Highlife
Drives: 2012 Camaro LS
radio antenna splitter?
Is there a Y splitter cable out there so I can plug the am/fm antenna into my pioneer radio and have the other plug plug into a xm tuner from the factory antenna. I want to be able to split the factory antenna to my radio and xm tuner box. My tuner box plugs into my radio for sat so I need a splitter cable. The radio receives the normal am/fm plug and the xm tuner box takes the xm antenna connector plug, It should work right. Anyone know where I can get one?
Highlife is offline   Reply With Quote
Old 05-27-2012, 10:26 PM   #2
IC1Patton
IC1Patton's Avatar
Drives: 2017 Camaro 2SS
nope that wont work the Xm tuner requires a different antenna i have it in my truck your going to have 2 antennas
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived." - General George S. Patton
IC1Patton is offline   Reply With Quote
Old 05-27-2012, 10:41 PM   #3
Highlife
but it has xm in the car already. I get im taking the radio out and losing the xm tuner, but im putting in an xm tuner that fits my pioneer radio, so the factory antenna in theory should be able to plug into both the radio and the xm tuner if its split? right? I was think putting these three cables together
http://www.amazon.com/gp/product/B00...A1729W3053T57N
http://www.amazon.com/gp/product/B00...=AF8CJ05KGZIBN
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Old 05-27-2012, 10:51 PM   #4
IC1Patton
IC1Patton's Avatar
good luck
Old 05-27-2012, 10:59 PM   #5
Highlife
i know right
Old 05-27-2012, 11:04 PM   #6
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
The fm/am and the the xm radio anetenna's are different The spilt you are you will only to get the fm/am.
I have up loaded a picture of the back of my camaro radio.
Caddy
Caddyroger is offline   Reply With Quote
Old 05-27-2012, 11:06 PM   #7
Highlife
so its one wire from the antenna that splits to 2 for the back of the radio? one for fm and one for xm?
Old 05-27-2012, 11:07 PM   #8
Highlife
will this still work then??? For the fm
http://www.amazon.com/Metra-40-EU10-Motorola-Vehicle-Antenna/dp/B000329HEK/ref=au_pf_pfg_s?ie=UTF8&Model=Camaro|432&n=1077068 &s=car&Make=Chevrolet|47&Year=2012|2012&vehicleTyp e=automotive&newCar=1&carId=004
would i be able to use this^ for the fm and add something like this to the xm wire to my xm box and have it work
Old 05-27-2012, 11:25 PM   #9
IC1Patton
IC1Patton's Avatar
you need a GM antenna adapter
Old 05-27-2012, 11:29 PM   #10
Caddyroger
Caddyroger's Avatar
Let's try this again. Your fm/am antenna is at the bottom part of your rear glass. That wire for goes to the connector that is marked fm/am antenna. The XM antenna in the part the is mounted on your roof. That wire goes to the connector that is marked XM antenna.
You get this part from Amazon
Plug your fm/am into that adapter then to the pioneer radio. Next you plug the xm in your fm tuner. The data wire takes the xm singnal to the pioneer radio.
I know this because i installed a pioneer AVIC-Z130 BT in my Camaro
Caddy
Old 05-27-2012, 11:34 PM   #11
Highlife
oh i thought the fin was all in one. so the fin should plug into my xm tuner then, so i need the above cable for my radio and probably an extension on the xm cable right?
Old 05-27-2012, 11:43 PM   #12
Caddyroger
Caddyroger's Avatar
oh i thought the fin was all in one. so the fin should plug into my xm tuner then, so i need the above cable and probably an extension on the xm cable right?
Correct. You probably going to need a extension cable you don't have much cable to work with. I had to get the 5 ft xm to Sirius adapter cable because I use Sirius radio
Caddy
Old 05-27-2012, 11:49 PM   #13
Highlife
ok cool thanx
