Old 05-29-2012, 11:19 AM   #1
masonacdc
masonacdc's Avatar
Drives: 2LS Inferno Orange "PHOENIX"
key wouldnt turn
What does it mean if you put your key in the ignition and it wont turn at all while in park I pulled the parking brake up nand pushed it back down then the key turned but i have never touched the parking brake
masonacdc is offline   Reply With Quote
Old 05-29-2012, 11:22 AM   #2
CamaroWinz
Drives: 2LT/RS (TBD)
Originally Posted by Scalded Dog View Post
Turn the steering wheel slightly... often the wheel lock creates ignition resistance...
This.
CamaroWinz is offline   Reply With Quote
Old 05-29-2012, 11:23 AM   #3
masonacdc
masonacdc's Avatar
ok thanks does this happen often its happened twice to me already today?
Old 05-29-2012, 11:23 AM   #4
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
actually, if or the next time it happens.....move the the streering wheel....usually the wheel is just a little in a bind and you will be able to turn it and start the car.
Old 05-29-2012, 11:24 AM   #5
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
lol...It happens every time that you need to turn the wheel!..j/k...It's no biggie...Just make it a habit to jockey the wheel a little each time you get in...
90503 is offline   Reply With Quote
Old 05-29-2012, 11:27 AM   #6
masonacdc
masonacdc's Avatar
would it help if i turned the wheels straight before shut down
Old 05-29-2012, 11:28 AM   #7
Sir Nuke
Sir Nuke's Avatar
when you stop your car, to put it in park, and remove your key, if the column lock isn't exactly in a "notch" and if you trun the wheel slightly to engage it. the next time you go to get in teh car and go to start it, put the key in, and move the wheel just a tad to release any tension in teh mechanism it will start with no proplem.
Old 05-29-2012, 11:29 AM   #8
Sir Nuke
Sir Nuke's Avatar
yes.....and if your on a slight encline....it could happen as well.
Old 05-29-2012, 11:30 AM   #9
90503
90503's Avatar
Mine's a manual...parked with wheels straight in the garage...still "does it" from time to time...
Old 05-29-2012, 11:31 AM   #10
masonacdc
masonacdc's Avatar
welll thanks for the help guys
Old 05-29-2012, 03:03 PM   #11
SnowVert
SnowVert's Avatar
Drives: Inferno Orange 2013 SS/RS LS3 6M
Manual or Auto, the steering wheel lock works the same
With this in the garage, I smile every day
6/29/2012 New 2013 ordered...
8/21/2012 New 2013 picked up!!!
SnowVert is offline   Reply With Quote
Old 05-29-2012, 05:24 PM   #12
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
Ya mine does this all the time if there is any preload on the steering wheel when I turn off the ignition, normal as long as it frees up completely when you move the wheel abit.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 05-30-2012, 08:41 AM   #13
Chevrolet Customer Svc
Drives: GM Vehicles
If you are still having a concern with this, the best thing would be to contact your dealership for a diagnostics appointment. If you have any other questions, please feel free to send me your VIN and I will be able to research this concern as per my resources allow me to.
Brandon
Chevrolet Customer Service
Old 05-30-2012, 04:01 PM   #14
camarozzzz
Drives: Blue
it means the steering wheel is locked, just turn the key gently while moving the wheel left and right and it unlocks.
camarozzzz is offline   Reply With Quote
