sjm autoprod
Old 05-29-2012, 02:11 PM   #1
209camaross
209camaross's Avatar
Drives: 2012 camaro ss ashen gray
GETTING SWIRL MARKS ON NEW CAMARO, HOW TO AVOID MAKING MORE??
Im starting to get swirl marks on my new ss. I wash my car by hand using turtle wax products and micro fiber sponges and towels but as hard as i tried they started coming out already. What can i do about this and what other products should i try??
209camaross is offline   Reply With Quote
Old 05-29-2012, 02:21 PM   #2
RallySS
RallySS's Avatar
Drives: 2011 Rally Yellow RS/2SS Vert M6
Two bucket method, rinse microfiber wash cloth in one, and resoap in the other. Remove as much sediment from the cloth each time as possible, and start from the top of the car down until you get to the front/bottom of door at the factory molding line and rear, then go from front to back, cleaning the wash cloth as often as possible as these are the most sediment collecting parts of the car.
If you expect to score points by whining, join a European soccer team.
RallySS is offline   Reply With Quote
Old 05-29-2012, 02:32 PM   #3
880
880's Avatar
Drives: 2011 Z06, 2004 Cobra, 1991 MR2Turbo
Are you using 2 buckets with grit guards?
How are you drying your car?
Check out the detailing section...
880 is offline   Reply With Quote
Old 05-29-2012, 02:47 PM   #4
onechuck
Onechuck
onechuck's Avatar
Drives: 2010 Camaro IBM 2SS\RS SC & Cammed
The less you touch your car the better. Blow dry it with an electric blower. Use a foam gun and let it soak in. Use the 2 bucket method. if you do dry it use a microfiber towel and some kind off show room shine.
onechuck is offline   Reply With Quote
Old 05-29-2012, 03:18 PM   #5
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Thats a big question... but there are a few key places to start:
1) Your wash routine. As the others pointed out a 2 bucket wash with quality wash/dry media, high sudsing and lubricity soap, and grit guards is key. In this technique is everything - wash top to bottom, use separate wash media for the upper and lower areas of the vehicle, clean and rinse thoroughly between each panel, etc.
2) Your choice of materials. Not all microfiber is created equal... there are many towels and applicators out there sold as microfiber that people assume are perfectly safe to use on their paint, but it isn't. A lot of the stuff sold over the counter is low quality and has things like hot wire cut edges and sewn in tags that could potentially cause swirls.
Theres a TON of information on this forum when it comes to detailing... its a very active section. Also if you're interested in checking out our products we have the instructional videos up that can help you out with your process:
http://www.adamspolishes.com/t-videos.aspx
Old 05-29-2012, 06:06 PM   #6
M3NTA7
Drives: 2012 Camaro 2SS Transformer Edition
Here is the posting that helped me a great deal, I hope it helps you too:
http://www.camaro5.com/forums/showthread.php?t=19526
M3NTA7 is offline   Reply With Quote
Old 06-02-2012, 05:55 PM   #7
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
Here's Autopia Car Care "How To" for everyone to read.
Autopia 5 Step Guide to Paint Care
Old 06-02-2012, 08:58 PM   #8
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
The swirls show the circular motion of your washing and drying technique.
Forget everything you "know" about how to wash a car.
Always wash and dry all vertical panels up and down, all horizontal panels front to rear. Same for applying and removing wax or other products.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 06-02-2012, 10:41 PM   #9
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
A foam gun helps. There are many options for a foam gun out there
Old 06-03-2012, 08:50 AM   #10
Sword5
Sword5's Avatar
Drives: 2010 2SS
I not only use the two bucket method but also rinse my wash mitt with the hose in between. Doesn't hurt i guess and pretty much swirl free in three years.
Ordered 6/19/09 Black on Black 2 SS Delivery 10/14/09! Added CAI, Heritage Grill, DRL Plug and Play Harness
Sword5 is offline   Reply With Quote
Old 06-03-2012, 10:00 AM   #11
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
It's not possible to completely avoid swirl marks. Just not gonna happen. You can greatly minimize them by reading some of the guides on here and Autopia forums.
I have a guide I posted on here awhile ago that is a little simpler than some of the others so as not to overwhelm beginners. I'm on my phone so it would be difficult to find it, but if you search washing beginners it should come up
Edit: OK it wasn't that hard actually lol
http://www.camaro5.com/forums/showthread.php?t=164072
Sent from my Galaxy Nexus using Tapatalk 2
[B]
Old 06-03-2012, 04:21 PM   #12
Angelo@Autopia
All we are trying to do is help you minimize in getting them. There's always a few that will pop up now and then.
Old 06-04-2012, 01:15 AM   #13
Fiveg56
Drives: -
I hear this alot, but it's not true. They aren't really swirls, just micro scratches that appear in circles around a light reflection. It has nothing to do with washing in circles or up and down lines, it's about what tools you are using.
Fiveg56 is offline   Reply With Quote
Old 06-04-2012, 10:04 AM   #14
14pilot
14pilot's Avatar
This statement is not true. The swirls appear in circles because they are placed in circles. Of course the tools and the rest of the process is important.
