JDP Motorsports
Old 05-29-2012, 06:24 PM   #1
Quickstir
Quickstir's Avatar
Drives: 2012 IBM Camaro LS
Send a message via Skype™ to Quickstir
Help with scratch or hit don't know
Don't know how this happened just cleaned it this weekend and I didn't see it. Do I need to get this painted?or what?
Quickstir is offline   Reply With Quote
Old 05-29-2012, 06:27 PM   #2
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
Can you feel it? Does your fingernail catch in it?
Iomcamaro is offline   Reply With Quote
Old 05-29-2012, 06:42 PM   #3
Quickstir
Quickstir's Avatar
Yeah it felt slightly rough. Not smooth like the rest of the body. Fingernail catch? I don't really have much knowledge about this sort of thing? Is it some sort of quick test?
Old 05-29-2012, 06:49 PM   #4
Iomcamaro
Iomcamaro's Avatar
Yup. If your fingernail catches in the scratch, it will need repainted. If it doesn't catch, it will be able to be wetsanded or compounded out.
Old 05-29-2012, 06:51 PM   #5
Quickstir
Quickstir's Avatar
Ok got it. I'll check ASAP! Thanks
Old 05-29-2012, 06:54 PM   #6
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
More like if its down to the.metal it will need repainting..if brought to the right perfson..and its not down to the.metal a little wetsanding and buffing may smooth it out
Sent from my SCH-I510 using Tapatalk 2
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 05-29-2012, 06:55 PM   #7
Iomcamaro
Iomcamaro's Avatar
Originally Posted by jeffny09 View Post
More like if its down to the.metal it will need repainting..if brought to the right perfson..and its not down to the.metal a little wetsanding and buffing will smooth it out
Even if the fingernail catches and it's not down to the metal, you can't safely wetsand and compound it out because you'll have to take the rest of the clearcoat around it off to. They could certainly make it look better, but not perfect without risking the chance of clearcoat failure.
Old 05-29-2012, 06:58 PM   #8
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Maybe....but id just do a light wetsand..then buff it well n see how it works out...
Old 05-29-2012, 07:00 PM   #9
Iomcamaro
Iomcamaro's Avatar
Oh no doubt. Anything could look better than that. Especially if the OP doesn't have the money for a respray right now.
Old 05-29-2012, 07:29 PM   #10
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Alll depwnds on how bad it.is lol
Old 05-29-2012, 07:46 PM   #11
Envious
Drives: 2011 Twin Turbo Synergy RS Coupe
I would just try a mild rubbing compound first, one made for clear coat. Take your time and don't rush, their that takes it out then polish/wax over top of that. Wet sanding may remove to much of the clear coat. I would do that as a last resort.
Envious is offline   Reply With Quote
Old 05-29-2012, 08:48 PM   #12
Quickstir
Quickstir's Avatar
Ok, is there any compound in particular that you guys would recommend?
Old 05-29-2012, 08:50 PM   #13
Iomcamaro
Iomcamaro's Avatar
If you're gonna try it on your own by hand, I would use meguiars ultimate compound. Should be able to find it at Walmart for $8 for 16 oz. By hand will only go so far. A machine will probably be necessary to remove that.
Old 05-29-2012, 09:06 PM   #14
Quickstir
Quickstir's Avatar
Yeah I was planning on using my machine. So would you still recommend meguiar's ultimate compound with a machine?
