BORLA
Old 05-14-2009, 07:58 AM   #1
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Auto Users, use the M mode and not paddles!!
I finally read the manual why the DIC says S when in M mode before I pushed a paddle. It keeps the car in a sportier mode with shifts. Basically keeps the car in the 2500 and above power range if getting on the gas. I did drive the car lite footed in that mode and got 23MPG around town and 16MPG when goofing off and normal driving in that mode.
Car is alot more peepy in the sport shift mode.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-14-2009, 08:24 AM   #2
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Found that out without even trying while test driving 1178. Then again, when I forgot to shift the car also yelled at me and flashed *Speed exceeded for gear selection* on the DIC
Salesman and myself kinda lol'd at it thinking at first that it was referring to the speed limit on the highway before actually reading the rest of the message. What.. I was concentrating on driving..
Zabo is offline   Reply With Quote
Old 05-14-2009, 08:42 AM   #3
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Scoot, in the "S" mode were you able to burn em?
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 05-14-2009, 08:49 AM   #4
Scott@Bjorn3D
Did not try.
But I did get an e-mail from Cherly about it.
Basically said the car is designed to hook up. Alot of the sticks you see doing burn outs are having to hit 4K and dropping the clutch to do it. So she said I can break them loose by litely holding the brake and stomping on it or buy cheaper tires to do it.
Old 05-14-2009, 08:57 AM   #5
edog
edog's Avatar
Good to know. I know I will want to do it at least once. If I can find a rental car I will do it there, but if not I will feel the need to shave some tire life from my car.
Old 05-14-2009, 09:49 AM   #6
MerlinZero
Big Orange
MerlinZero's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
Too true Scott...
the automated sport mode was programmed to be perfect. It takes some time to perfect the proper shift points with the paddles.
Its the same way with my current car, that sport mode is a LOT more crisper with the top end shifts. Only down side is the downshifts on mine are lagged.
" First, there was darkness, Then, On March 16th, Scott said LET THERE BE CAMARO, and there was Camaro, and Scott saw that it was good. Camaro5 3:16"
VIN: 2G1FT1EWXA9120523
ETA 7/6/09 (Delivered 7/10/09)
MerlinZero is offline   Reply With Quote
Old 05-14-2009, 09:54 AM   #7
MontyCarlo
MontyCarlo's Avatar
Drives: 2010 2LT/RS auto IBM
Just to make sure I'm reading this right - if I put the shifter in "M" but don't use the paddles, the Camaro still shifts on its own but with sportier settings than usual?
FAQs:
1. No, I do not have any strong opinions about the Monte Carlo.
2. Yes, I know what my name looks like.
3. Yes, but the medication helps immensely.
2LT/RS IBM/gray #21,895 ordered April 21st, delivered July 3rd
MontyCarlo is offline   Reply With Quote
Old 05-14-2009, 10:13 AM   #8
Scott@Bjorn3D
YES, that is correct.
Old 05-14-2009, 10:30 AM   #9
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
This has been discussed many times in transmission threads, but the word doesn't seem to be getting out. Good idea posting it as an appropriately titled thread.
Question: Does it start in 1st when in that mode?
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 05-14-2009, 10:33 AM   #10
levi1922
levi1922's Avatar
Drives: 2LT RS CGM
doesnt sport mode down shift aggressively under hard braking?
levi1922 is offline   Reply With Quote
Old 05-14-2009, 10:36 AM   #11
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
Question. So putting it in "M" position puts it in sport mode. Then pulling a paddle puts it in manual mode. How would you put it back into sport mode from manual?
"It's kind of fun to do the impossible" - Walt Disney
There's a great big beautiful tomorrow
shining at the end of every day
Just a dream away
stovt001 is offline   Reply With Quote
Old 05-14-2009, 10:41 AM   #12
The Dark Knight
Batmobile in Disguise
The Dark Knight's Avatar
Drives: 2009 Pontiac G8
I know EXACTLY what you are talking about lol
NOT once did I look at the speed-o-meter when I drove it...I was having too much fun "not" imagining I was driving the Camaro
I tend to do that alot when I drive any other car...wife has caught me a couple times lol
The Dark Knight is offline   Reply With Quote
Old 05-14-2009, 10:45 AM   #13
HuJass
Drives: GM
Can't you just turn all that crap off?
HuJass is offline   Reply With Quote
Old 05-14-2009, 10:48 AM   #14
theholycow
theholycow's Avatar
Probably have to put it back in 'D' for a moment then 'M' again.
