Centerforce Clutches
Member Car Journals Want to keep a long term Camaro project journal to share with the community? Use this forum to create a single thread which you can update over time to document the progress.
Old 05-30-2012, 03:13 AM   #1
SSWAG
COTW 6/4/2012
Drives: 2011 Camaro 2SS/RS Convertible
Arrow "SSWAG" JOURNAL: 2011 Camaro 2SS Convertible Modifications [COTW 6/4/12]
I finally got a chance to take some decent pictures of my 2011 Camaro 2SS Convertible (V8 6.2L Auto) after modifications. In the future, I plan to do more interior modifications (mostly electronics). Below is a list of the modifications so far:
• Razzi Camaro V8 Ground Effects Kit (P/N 130-100)
• Camaro Heritage Grille (GM P/N 92208704)
• GM Dovetail Rear Spoiler (GM P/N 92234283) *
• Painted Stripes with ghost flames on hood
• Windshield Frame painted in gloss black
• Rear Trunk Alcove painted in Matte Black
• Painted shadow effect on gills
• Factory SS Brembo brakes, custom painted IOM w/ white "Brembo" lettering
• Sparks Restorations "SS" emblem badges for grille and trunk (IOM painted inserts) (P/N HGEPR/TEPR-11)
• Custom "SSWAG" emblem badging
• Engine Cover, custom painted IOM (GM P/N 92247664)
• V8 Engine Cover Trim, Chrome (P/N 9590-9581V8)
• K&N 63 Series Cold Intake Kit, custom painted IOM (P/N 63-3074)
• Rear Sequential Turn Signal Pre-Wired Harnesses (P/N PHASTEK-CAMARO-TURNSIGNAL)
• NoWeeds.net Exhaust Diverter System (P/N 25NWCAML99)
• Pedders eXtreme Xa Coilover Springs (P/N 160086)
• JDP Motorsports HALO Color Changing Headlight Kit (P/N JDPL1001)
• Cross-Drilled and Slotted Brake Rotors (Brakeperformance.com P/N CB-62124 F & CB-62119 R)
• 22" Giovanna Mecca wheels (matte black with IOM barrels/lips + custom painted "SS" center caps)
• Yokohama Parada Spec-X Sport All-Season Tires: 265/35R-22 Front + 285/35R-22 Rear
• Orange Billet Aluminum Door Kick Plates with SS logo (P/N BC1003)
• Cup Holder Trim - IOM (P/N CAMC953)
• Window Tinting (20% Windows + 5% Windshield)
• Clear Bra (front, hood, windshield trim & fenders)
• Color-matched IOM License Plate Frame (P/N P076961)
• Coverking Cover, IOM with Black Stripes (CVC3SS85/CH9458)
* The body shop removed the antenna from the previous spoiler, so the AM Radio doesn't work anymore. I am still working on a solution.
Some of the items were purchased from PhastekPerformance.com. GMPartsDirect.com has the best pricing for factory Camaro parts. I also purchased the Pedders coilovers from JDP Motorsports.
Below are the factory Pirelli PZero tires and Camaro SS wheel statistics before new coilovers and new wheels were installed:
• Front Wheel & Tire Weight (lbs): 63.4
• Rear Wheel & Tire Weight (lbs): 68.8
• Front Wheel: 8.0"
• Rear Wheel: 9.0"
• Front Tire Height: 28" *
• Rear Tire Height : 28" *
• Front Fender Height: 29.75"
• Rear Fender Height: 29.75"
• Front Fender to Tire Gap: 1.75"
• Rear Fender to Tire Gap: 1.75"
• Front & Rear Wheel Diameter: 21.5"
• Front Tire Width: 9.5"
• Rear Tire Width: 10.5"
* The manufacturer's actual specs are higher for this tire
Below are the new statistics with nitrogen filled tires, Pedders eXtreme Xa Coilover Springs and 22" Giovanna Mecca Wheels:
• Front Wheel & Tire Weight (lbs): 64
• Rear Wheel & Tire Weight (lbs): 72
• Front Wheel: 9.0"
• Rear Wheel: 10.5"
• Front Tire Height (265/35-22): 29.125" *
• Rear Tire Height (285/35-22): 29.5" *
• Front Fender Height: 29.125"
• Rear Fender Height: 29.5"
• Front Fender to Tire Gap: 0"
• Rear Fender to Tire Gap: 0"
• Height the car was lowered in the front: 0.625"
• Height the car was lowered in the rear: 0.25"
• Front Tire Width: 10.4"
• Rear Tire Width: 11.2"
• Height of Rear Diffuser from the ground: 5.5"
The following guys were great to work with:
Jordan at JDPMotorsports.com
Jason at Phastek Performance
Terry at SparksRestorations.com
Gene Tjin at Wheel Warehouse (714-772-1281)
Ross at Tirerack.com (888-541-1777 Ext 796)
Even though I didn't buy from him, I would also like to thank Tony Whatley (Nine Ball) for answering all of my emails and phone calls about wheels and tires! Tony was very helpful and patient!
MY PERSONAL NOTES: The cool thing about these Pedders coilovers is that there are 30 settings for each corner! I am very pleased with the feel of the Yokohama tires with the coilovers. With such a low profile (sidewall), you would think these tires would feel every bump. However, with my setting (I have my coilovers set to 8 clicks from the left), the ride feels like stock! I just hope the tires perform well in the winter when it snows! I also highly recommend 22" wheels versus the 20" stock wheels. They look so much better, especially if you install a ground effects kit. In a way, the 20s almost looked too small. These Giovanna Meccas look like they are a 2 or 3-piece wheel, but are made of one-piece cast aluminum; and the entire set of these wheels and tires were less than 8 lbs more than the factory wheels and tires. When lowering your Camaro, be careful with the Razzi kit. My rear diffuser got damaged three times due to dips in entrance approaches! I tried to convince Razzi to redesign their rear diffuser, but they flat out refused. With the ground effects and nicely painted wheels, ALWAYS be careful when parking! My next plan is to get front and rear cameras installed!
SSWAG is offline   Reply With Quote
Old 05-30-2012, 03:18 AM   #2
SSWAG
COTW 6/4/2012
Below are more photos....
Old 05-30-2012, 03:40 AM   #3
SSWAG
COTW 6/4/2012
And even more photos....
Old 05-30-2012, 03:45 AM   #4
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
Drives: 2010 Camaro SS
Well done!!
ZWA SS is offline   Reply With Quote
Old 05-30-2012, 05:12 AM   #5
Apex Chase
Apex Chase's Avatar
Drives: it like I stole it.
Great job! The car looks amazing.
Apex Chase is offline   Reply With Quote
Old 05-30-2012, 06:01 AM   #6
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
very nice ,car looks killer ,i love the rims most.
Old 05-30-2012, 06:08 AM   #7
Bcarr
Bcarr's Avatar
Drives: 2012 Camaro SS 45th Convertible
Great work! I love the wheels and the overall profile of the car.
Bcarr is offline   Reply With Quote
Old 05-30-2012, 06:31 AM   #8
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2012 Camaro LFX
Pretty cool. You have the 5th gen Convertible equivalent of my 1994 Camaro lol
2012 Camaro LFX M6 - "Clifford" - 270hp/232tq on Dynojet (before TB was installed) - Cold Air Inductions CAI, VMAX Ported Throttle Body, MGW Short Throw Shifter
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
Michigan FBody Association
http://www.mifbody.com/
Proud member of the unofficial Camaro5 "Rodgers Chevrolet Fan Club"
meissen is offline   Reply With Quote
Old 05-30-2012, 06:44 AM   #9
1954 Belair-man
1954 Belair-man's Avatar
Drives: 2010 Camaro IOM 1SS M6
Well done! Looks amazing.
1954 Belair-man is offline   Reply With Quote
Old 05-30-2012, 06:49 AM   #10
Sword5
Sword5's Avatar
Drives: 2010 2SS
Good looking car
Ordered 6/19/09 Black on Black 2 SS Delivery 10/14/09! Added CAI, Heritage Grill, DRL Plug and Play Harness
Sword5 is offline   Reply With Quote
Old 05-30-2012, 07:17 AM   #11
dmwhiteman
dmwhiteman's Avatar
Drives: 2SS Black w/ Inferno Orange Stripes
Thats a mean looking vert! Great job on the mods.
dmwhiteman is offline   Reply With Quote
Old 05-30-2012, 08:50 AM   #12
Hec_45th
Hec_45th's Avatar
Drives: 2012 Camaro 45th Anniversary 2LT RS
The car is a beauty. Belongs in a pageant Lmao. But seriously great work an the wheels blow all others out of the water.
Hec_45th is offline   Reply With Quote
Old 05-30-2012, 09:00 AM   #13
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
VERY nice! Looking vicious.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 05-30-2012, 09:07 AM   #14
Rangore
Rangore's Avatar
Drives: 2010 Camaro 2LT Cyber Gray
The painted gills are sweet!!!
Current: 2010 Camaro 2LT - Current Mods: EGA on left and right windows - Solo CAT Back - Black CAI - Black Carbon Fiber Bow-tie Vinyl - Switchback LED Turn Signal bulbs - HOD Headlight bulbs - Aqua interior LED bulb
No longer owned: 1993 Camaro Z-28
Rangore is online now   Reply With Quote
Old 05-30-2012, 11:19 AM   #15
slicktempo
slicktempo's Avatar
Drives: 2011 Camaro
Excellently executed as a whole, even down to the car cover!
I've got the same cross-drilled and slotted rotors from brakeperformance.com with ss lines and motul fluid! Love them!
Anyway, one of the cleanest verts around!
slicktempo is offline   Reply With Quote
Old 05-30-2012, 12:03 PM   #16
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 JDP Track Spec Camaro
It looks awesome!!!! Very well done and we appreciate the support!
Kind regards,
Jordan Priestley
888.308.6007
AEM | Airaid | Anvil | ARH | BBK | BMR | Brembo | CAI | CSF | COMP Cams | DBA | DSS | ECS | FAST | Forgeline | Gforce | Hawk | Hurst | Hotchkis | Injen | MagnaCharger | Magnaflow | KOOKS | Oracle | Pedders | Pfadt Racing | ProCharger | Roto-Fab | RX | Seibon | SLP | Spohn | Stainless Works | Street Scene | Turn One | Vararam | VMAX | Whipple | + MORE!
JDP Motorsports is offline   Reply With Quote
Old 05-30-2012, 12:26 PM   #17
Wheel Warehouse
Wheel Warehouse's Avatar
Drives: 2011 Chevrolet Camaro SS
Send a message via AIM to Wheel Warehouse
Glad we were able to help make this happen, Jeff. Seems like it was definitely worth the wait, it looks awesome!
Wheel Warehouse is offline   Reply With Quote
Old 05-30-2012, 01:39 PM   #18
Mister-Camaro
Mister-Camaro's Avatar
Drives: 2011 2SS L99
...swag
Mister-Camaro is offline   Reply With Quote
Old 05-30-2012, 10:37 PM   #19
SSWAG
COTW 6/4/2012
Thanks for the kind words, everyone. All of my vendors made it happen, including Jordan, Gene, Steve, Jason, Terry, Athena, Ross, Ray and Tony...and everyone else who I left off this list. Hopefully, I'll be able to add more interior mods next year!
Old 05-30-2012, 10:41 PM   #20
SSWAG
COTW 6/4/2012
Another tip that I want to give everyone is to purchase some ramps if you need to work on your car, especially if you have a ground effects kits. Jordan from JDP recommended RaceRamps.com. Their ramps are expensive, but they're great and they work very well for my application! I was able to change the dampers on my rear coilovers.
Old 05-31-2012, 01:06 AM   #21
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: LS-3 429 TT with other odds-n-ends
Beautiful Car,
Old 06-01-2012, 05:38 PM   #22
Bromaro
Bromaro's Avatar
Drives: 45th Anniversary Camaro 2SS
Love the car! Did you have to install wheel spacers to fit the Giovanna Mecca's? There is conflicting info on the C5 forum about these wheels because of the concave design.
Bromaro is offline   Reply With Quote
Old 06-01-2012, 11:06 PM   #23
Ivan @ Southwest Speed
Southwestspeed.net
Drives: '10 2SS/RS, '96 Z28
Pretty Badass for your 15th Post!
Nice whip sir....
Ivan
Old 06-03-2012, 10:21 PM   #24
SSWAG
COTW 6/4/2012
No wheel spacers were needed. Wheel Warehouse verified with Giovanna first before I bought them to make sure the offset would work, and it did just fine. The space between the Brembo calipers and spokes on the front wheel was very close, but it cleared.
Old 06-03-2012, 10:25 PM   #25
SSWAG
COTW 6/4/2012
Nice whip sir....
Ivan
Thanks, Ivan! It took a lot of detailed planning, and I started planning it even before I bought the car back in January. I also got lucky finding this brand new Camaro which sat on a dealer's lot for 9 months, two states away, before I bought it.
