SDTW Custom Wheels & Tires
Old 05-30-2012, 02:53 PM   #1
Bumblebee2012
Bumblebee2012's Avatar
Drives: 2012 2SS TF3, 1971 Chevelle
Android to 2012 Camaro USB, not just music being played.
I have a 12 2SS.
When I plug my phone in as a usb mass storage device, the car indexes the phone data and plays music, but also finds ringtones I've downloaded, all voice snippets from Google navigation and any other sound files that have been stored into the phone.
I would like to know if there is a way to control the location of indexed files, or a way to otherwise prevent anything aside from my MP3 music being played.
It's almost a great system, hopefully this is a user induced problem that someone can help with.
Sent from my Galaxy Nexus using Tapatalk 2
Bumblebee2012 is offline   Reply With Quote
Old 05-30-2012, 03:11 PM   #2
CyberPredator
50 Shades of Prey
Drives: TT/SS
does it do that when you play it through bluetooth?
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 05-30-2012, 03:32 PM   #3
Bumblebee2012
I use the BT to connect the phone to the hands free, I was under the impression that you can not do both. I use USB for music and BT for phone calls.
Can you use BT to transfer and play music while still using the hands free phone setup?
Old 05-30-2012, 05:30 PM   #4
Chino
Drives: 2ss/rs
Yup, but your music will be interrupted when a call comes in.
When using BT for streaming audio, it outputs whatever is currently running. For example, music playing from Pandora/Music Player.
I have a Samsung Epic and 2010 SS.
Chino is offline   Reply With Quote
Old 05-30-2012, 06:11 PM   #5
Bumblebee2012
I've tried to connect so that Pandora would work, but I've never got it to work. When I turn on BT, the phone instantly connects to the car as a phone, maybe I need to re read the car owners manual.
You do know that its painful for a man to use a manual!?
Old 05-30-2012, 06:57 PM   #6
Pur3vil
Drives: 2010 ABM 2SS/RS M6
There is a second connection/pairing required for music. If you go to your usb or aux input and hi
t the menu button on the head unit, there should be a bluetooth menu with a pair device option. Go through the pairing instructions and then connect the paired device. The media connection is called GMusicConnect or something similar by default. At least it is with the 2010...
Pur3vil is offline   Reply With Quote
Old 05-31-2012, 05:10 PM   #7
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
you can download a free app file manager and create a different folder for the music separate from the ringtones...worked for me
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 05-31-2012, 07:23 PM   #8
pnyklr
Drives: A Gift From My Wife
I created a Folder on my SD card called My Music and that is where all my music is stored. The radio picks up on that folder and only plays what is in that folder.
Galaxy S2
-Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping.
08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery).
08/16/2011 - (5000) Vehicle has been delivered to dealer.
08/19/2011 - In my possession.
pnyklr is offline   Reply With Quote
Old 05-31-2012, 08:03 PM   #9
Edwin320
Drives: 2012 Camaro Convertible 2SS RS M6
Yes, you can connect both streaming music and voice calls at the same time. Sometimes though, but music needs to be reselected on the radio after a call
Ed 2012 2SS RS M6 'Vert
Edwin320 is offline   Reply With Quote
Old 05-31-2012, 08:58 PM   #10
Bumblebee2012
I also use an application for file management, and have all .mp3 files in a custom folder named My Music. This is on the fixed 32 gig SD card in the Nexus.
Old 06-08-2012, 11:40 AM   #11
mntgome1
mntgome1's Avatar
Drives: 2012 AGM 2SS/RS
+1
1) aux input screen
2) push menu
3) pair device (1st option)
4) GMusic Connect.
5) Play music on your phone like you would through a headset.
mntgome1 is offline   Reply With Quote
Old 06-13-2012, 02:36 PM   #12
Easton091
Easton091's Avatar
Drives: 2011 Camaro SS
I also have a Galaxy Nexus. The first time I paired it to the Gmusic it didnt start playing ringers. After I disconnected it from USB and went into play music app, it now only plays the music. Its nice to, you can skip songs by using steering wheel conrols.
Easton091 is offline   Reply With Quote
Old 06-13-2012, 02:57 PM   #13
Bumblebee2012
I like to just play using the phone as a memory sick, just jam the USB chord in so the phone charges while your getting your groove on.... But... My way allows any and all sound files in the phone to be indexed by the car. It sucks in that respect. It should have a way to choose a default folder for the radio to look at so that you can avoid ringtones and other crap you have from zedge or similar.
Old 06-13-2012, 03:41 PM   #14
Rogue Leader
Iatefiberglassinsulation
Rogue Leader's Avatar
Drives: 2010 Camaro 2SS M6
Even though it says its charging the USB port is very low voltage, so you are not actually charging the phone, its just slows the battery loss.
2010 Chevrolet Camaro SS - was daily driver, now toy
2014 Mercedes Benz E350 4matic Sport - Daily Driver
2008 Chevy Silverado 2500 HD LT 6.0 - Tow Vehicle
1995 Volkswagen Golf Race Car
"Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin
Rogue Leader is offline   Reply With Quote
