Old 05-30-2012, 11:17 PM   #1
martinezj454545
Drives: 2011 Camaro LS V6
Wheel Lugs coming Loose
Okay i just purchased some new 22" wheels for my car and when i went to tighten the lug nuts i couldnt get to them becouse the housing where the lugs go for the rims where to small to fit the wrench in so i had to tighten it with a 7/8 socket with a breaker bar. Well all was fine until 2 days went by and i noticed a sound coming from the rear tire and there it was a loose lug nut just rattling around the inside cover of the rim. so it made me check all the lug nuts and a couple where loose. but i made sure to tighten them real good so what else can i do to make sure this doesnt happen again?
martinezj454545 is offline   Reply With Quote
Old 05-31-2012, 05:31 AM   #2
cabbe
Drives: 2014 2ss 1le
It's pretty common that you have to tighten them about two days after you put them on again.
Now after you tightened them again you should be good.
cabbe is offline   Reply With Quote
Old 05-31-2012, 06:16 AM   #3
FEN
FEN's Avatar
Drives: BLACK 2SS/RS
You also need to purchase a torque wrench.
CCW polished 505a's
Front 20x10 w/275/40/20's
Rear 20x11.5 w/305/35/20's
Eibach 1" Pro Spring Kit
Factory GFX
MPD1 spoiler
painted bowties
15% tint
FEN is offline   Reply With Quote
Old 05-31-2012, 07:44 AM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
The torque spec for the lug nuts is 140 lb/ft
Click to view my build thread
Old 05-31-2012, 05:07 PM   #5
ss409cid
ss409cid's Avatar
Drives: 2011 SS RS Convertible
Exactly what we tell all of our customers....
ss409cid is offline   Reply With Quote
Old 05-31-2012, 11:07 PM   #6
martinezj454545
all is well took the wheels to discount tires and they said it was the lug nuts so i purchased some new ones for after market rims and hopefully i will help. Thanks all for the inputs
22's, lug nuts, rims, wheels
