Old 05-31-2012, 01:19 AM   #1
spacecowby
spacecowby's Avatar
Drives: 2010 black 2SS/RS
Blackfire users a little help
I am thinking about making the switch from Adams and my PC to Blackfire and a flex. How user friendly are their products? How did you like the results? Have you used Adams before and how does it compare?
Black cars are not hobbies, they are an obsession
spacecowby is offline   Reply With Quote
Old 05-31-2012, 01:53 AM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Just as user friendly. Results are stunning. I've used every Adams product they make, both are top tier, I prefer Blackfire
Sent from my Galaxy Nexus using Tapatalk 2
[B]
Old 05-31-2012, 01:58 AM   #3
spacecowby
spacecowby's Avatar
What about the pads? Do you use Adams pads or a different company's?
Old 05-31-2012, 02:03 AM   #4
CamaroDreams07
Drives: Slow V6
No reason you couldn't use the Adam's pads if you already have them. There are also Lake Country, the Uber line from Detailer's Domain...
[B]
Old 05-31-2012, 02:26 AM   #5
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
I'm glad you asked this question. I'm switching over from Adam's to Blackfire since in my opinion Adam's was ok. I'm glad its as easy as Adam's to use since I did like that about Adam's.
Old 05-31-2012, 02:49 AM   #6
CamaroDreams07
Drives: Slow V6
You guys are talking about the SRC polishes here specifically, right?
[B]
Old 05-31-2012, 02:59 AM   #7
spacecowby
spacecowby's Avatar
I'm not sure what SRC polishes are. That's what is confusing to me about other products. Adams are so easy, color coordinated pads etc... There is a place here that sells maybe when I'm ready to buy ill go see what they say, or some of the pros well chime in.
Old 05-31-2012, 03:02 AM   #8
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
Easiest thing here guys. If you go with LC pads, the compound goes with the orange flat pad, the polish goes with the white flat pad. If you go with the uber or buff and shine pads, the polish goes with the green and the compound goes with the yellow. The Blackfire sealant will work with any red or black pad from these two companies.
Iomcamaro is offline   Reply With Quote
Old 05-31-2012, 03:15 AM   #9
CamaroDreams07
Drives: Slow V6
SRC is just what they call their polishes. Scratch resistant clear. There are two, the compound (think SHR) and the finishing polish (think FMP).
Keith nailed the pads above.
[B]
Old 05-31-2012, 09:54 AM   #10
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
Our machine abrasive polishes (SRC Compound and SRC Finishing Polish) where originally designed for application at the OEM level in Germany, hence the SRC. (Scratch-Resistant-Clear).
In the mid 2000s, manufacturers (particularly in Europe) started introducing clear coat paints that were far less scratch sensitive than the clear coat finishes before them. These paints had a higher concentration of hard particles in the finish (hence the same "high-solid"). BLACKFIRE Polishes were originally developed with a close relationship with Menzerna GmbH (Menzerna of Germany). This was long before Menzerna became a household name in America as THE PREMIUM polish company.
While BLACKFIRE polishes have evolved over the years and the formulas have been upgraded for better performance, the close working relationship with Menzerna has continued.
These polishes will work with any pads you have. However if you are switching to a FLEX polisher, you want to make sure that your pads will work with the blacking plate on the FLEX. The stock backing plate measures 5.5 inches in diameter. As long as your pads have a 5.5 inch to 6 inch backing material they will work fine.
I personally love the new Lake Country Hybrid Power Finish pads on the FLEX; the dense foam does an excellent job of transferring the considerable orbital motion of the FLEX to the paint resulting in an excellent transfer of power.
Old 05-31-2012, 09:56 AM   #11
Todd@Autopia
Not only do I work for the vendor that sells them here, but I am the Director of Development for the BLACKFIRE line. Feel free to ask any questions and I can get you the correct answer.
Old 05-31-2012, 03:04 PM   #12
spacecowby
spacecowby's Avatar
PM sent to you Todd.
Old 06-06-2012, 10:59 AM   #13
Todd@Autopia
received and responded.
Old 06-06-2012, 01:42 PM   #14
spacecowby
spacecowby's Avatar
Thanks Todd, but will have to hold off on the flex for awhile. Just ordered a clean water filter kit from you. Can't stand this Hawaii water.
