Vivid Superchips
Camaro V6 LFX Engine, Exhaust, and Bolt-Ons For all LFX related parts
Old 05-31-2012, 05:18 AM   #1
Jonzmaro
Jonzmaro's Avatar
Drives: 2012 IOM 1LT A6
Most Comprehensive White Sheet on LFX I've seen
http://gmpowertrain.com/PowertrainFi..._LFX%20V-6.doc
Learned a few things I did not know. This is simply a GREAT engine. GM
Jonzmaro is offline   Reply With Quote
Old 05-31-2012, 06:56 AM   #2
Camaro588
Drives: 2012 camaro LS
read it takes E85? Though it says no in the owners manual. so can you put e85 in these things or not?
Camaro588 is offline   Reply With Quote
Old 05-31-2012, 07:43 AM   #3
Magilla gorilla
Magilla gorilla's Avatar
Drives: 2012 45th Edition 2LT RS,2005 Tahoe
According to that white sheet you can. The computer recognizes the different fuel and adjusts for it.
Magilla gorilla is offline   Reply With Quote
Old 05-31-2012, 07:53 AM   #4
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS L99
Thanks for that link. There are certainly some impressive features. The E85 conflict is a bit disturbing, though this slick sheet implies there is no problem with burning it.
Sure would like some "official" clarification from GM/Chevrolet.
PalmerGA is offline   Reply With Quote
Old 05-31-2012, 09:15 AM   #5
DennisfromIowa
DennisfromIowa's Avatar
Drives: 2012 2LS silver ice metallic V6
I have a 2012 2LS an right on the window sticker in bold black letters it said E85MAX and it is in the owners manual that E85 is fine to run as a fuel. The conflict comes from owners of a 2010 or 2011 which can't run E85 so assume no one can and keep spreading this misinformation. I run it and get about 2 mpg less than E10 89 octane with no noticeable difference in drive-ability or power. I lose a little mileage but the car the Camaro replaced got 14 mpg so I'm still ahead.
DennisfromIowa is offline   Reply With Quote
Old 05-31-2012, 10:51 AM   #6
Camaro588
My manual says its not compatible 87 and higher only???? Anyone else check your manuals.
Read manual states the following.
"the eighth digit of the VIN shows the code letter or number that Identifies the vehicles engine.
RECOMMENDED FUEL: If the vehicle has a 3.6L V6 engine VIN CODE D, use regular unleaded gasoline with a posted octane rating of 87 or higher.
so mine is in a 3 so can we put E85 in these or not?
Old 05-31-2012, 11:36 AM   #7
GVMV
GVMV's Avatar
Drives: Check Signature :P
I just got mine a month ago, and manuel doesn't say anything about being able to run E85. The person who said it says it in there owners manual can you scan it and post it up.
Vince
2012 CRT 2LT
93 Z28 V8/A4 Black/Black
91 RS Vert V8/A4 Black with Pink Flames
89 Iroc-Z V8/A4 Copper/Grey
84 Z28 V8/A4 White/Blue
77 LT V8/M4 Aqua/White
71 V8/M6 Black/Black (someday if I ever get home to work on it)
GVMV is online now   Reply With Quote
Old 05-31-2012, 11:45 AM   #8
Camaro588
it doesnt say you cant either
Old 05-31-2012, 11:54 AM   #9
Fish-man
SS HWSE
Fish-man's Avatar
Drives: too many to say!
LFX goes into a lot of cars... and i beleive that the fuel system would also need to be compatible. Perhaps the Camaro doesn't have the fuel system to support, and thats why the manual doesn't state E85...
Fish-man is offline   Reply With Quote
Old 05-31-2012, 12:02 PM   #10
Camaro588
The only thing the manual states is you cant put in e85 if the vehicle is not designed for it. if you read my earlier post its also states that if the vin code is D you cant. LFX motors are VIN CODE 3...so im assuming you can.
Old 05-31-2012, 12:51 PM   #11
KMPrenger
KMPrenger's Avatar
Drives: '10 ABM LT/RS, 01 Ford Ranger
It depends very much on the tune. The LFX CAN run E85 in other vehicles, but not openly advertised as such on the 2012 Camaro.
That could mean that the programming to run E85 is included in the other vehicles but perhaps not on the Camaro.
Could the camaro run it if it is tuned for it? Of course. E85 has been ran in several LLT V6s and proven to make great power at a cost in fuel mileage. I'm certain you could tune the LFX to do the very same thing.
Is E85 supposed to be used in a stock 2012 V6? Not sure about that.
Shes ALL MINE! - 8/24/2009 2G1FB1EV2A9133373 Custom Magnaflow Exhaust, Vararam intake, MACE Ported Intake Manifold, RX Ported TB, RX "Black Ice" manifold insulator, Trifecta Tune, Mike Norris Catch Can, DRL Harness, Heritage grill, Street Scene lower grill, NLP Spoiler, ZL1 rockers, Switchblade silver interior, Defenderworx sills, and more!
KMPrenger is online now   Reply With Quote
Old 05-31-2012, 12:58 PM   #12
PalmerGA
PalmerGA's Avatar
I'm not "assuming" anything. After spending $150 to get the fuel system on my lawn tractor repaired becasuse of 3 years of using 10% ethanol gas... I'm staying away from E85 until someone can officially tell me my car can handle it without causing damage.
Old 05-31-2012, 01:00 PM   #13
PalmerGA
PalmerGA's Avatar
And that, I believe, is the question at hand.
Old 05-31-2012, 01:04 PM   #14
CPT_Hoolie
CPT_Hoolie's Avatar
Drives: 2012 1LT RS
I called the Chevrolet Customer Assistance Center (800-222-1020), and the answer was...
NO
the stock 2012 Camaro can NOT use E85.
2012 1LT RS SW
15MAR12 purchased
22MAR12 Custom stripe install
25APR12 Installed CAI intake / ADM scoop / Roto-Fab windshield washer relocation
02MAY12 Installed RX Catch Can
...MORE TO FOLLOW
"Life's full of ironies, if you're stupid." -- P.J. O'Rourke
CPT_Hoolie is offline   Reply With Quote
Old 05-31-2012, 01:06 PM   #15
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
Nice find!
I think I'll stick to running 87 though
awfarley is offline   Reply With Quote
Old 05-31-2012, 01:13 PM   #16
PalmerGA
PalmerGA's Avatar
Thanks Hoolie.
Old 05-31-2012, 01:25 PM   #17
Ocikat
Ocikat's Avatar
Drives: 2012 2LT 45th convertible
Thanks for posting
As far as the E85 ? it states in the Doc. posted...........
E85 Flex-Fuel Capability
E85 is a clean-burning, domestically produced alternative fuel composed of 85 percent ethanol alcohol and 15 percent gasoline. Ethanol is renewable and produces fewer greenhouse gas emissions in the combustion process. It can be produced from various feed stocks, including corn and wheat stalks, forestry and agricultural waste and even municipal waste.
The 3.6L’s flex-fuel technology is both sophisticated and durable. Hardware changes are limited to the injectors with a higher maximum flow rating. Because ethanol has fewer BTUs (less energy) than the same volume of gasoline, more fuel is required to produce the same horsepower at wide-open throttle.
A special fuel sensor is not required for the LFX engine; it uses a “virtual sensor” within the Engine Control Module that takes readings from the oxygen sensors, fuel level sensor and vehicle speed sensors to adjust the length of time the fuel injectors open for the type of fuel used.
I would assume from this that the engine is capable of using E85 but that the injectors would need to be changed to provide the proper fuel ratio
Top Ten Reasons I Procrastinate
1.
Ocikat is online now   Reply With Quote
Old 06-01-2012, 05:31 AM   #18
Jonzmaro
Jonzmaro's Avatar
Wow, I really thought the car was ready (no mods) to run E85. I thought I actually heard that on a video??
Old 06-02-2012, 12:39 AM   #19
MediumLabowski
MediumLabowski's Avatar
Drives: iBM iLFX
The 2012 LFX engine is E85 capable. Check the window sticker, check the white sheets. A chick at GM customer service doesn't know crap, she doesn't reference tech data. I had to take my salesman to school too when I bought the car, most salesmen don't know s#@t either. In the manual it says (pg 9-46) not to run e85 in engines not designed for it, ie the V8, the LFX is designed for it.
The "85" in E85 is not the octane, it's a percentage... 85% ethanol. The octane rating of E85 is above 100.
MediumLabowski is offline   Reply With Quote
Old 06-02-2012, 10:32 PM   #20
coloeb
coloeb's Avatar
Drives: 2012 2LT/RS 6L50 automatic TF-3
Recommended Fuel
If the vehicle has the 3.6L V6 engine
(VIN Code 3), use regular unleaded
of 87 or higher. If the octane rating
is less than 87, an audible knocking
noise, commonly referred to as
spark knock, might be heard when
driving. If this occurs, use a
gasoline rated at 87 octane or
higher as soon as possible. If heavy
knocking is heard when using
higher, the engine needs service
Gasolines containing oxygenates,
such as ethers and ethanol, and
reformulated gasolines might be
available in your area. We
recommend that you use these
gasolines, if they comply with the
specifications described earlier.
However, E85 (85% ethanol) and
other fuels containing more than
15% ethanol must not be used in
vehicles that were not designed for
those fuels.
Notice:
This vehicle was not
designed for fuel that contains
methanol. Do not use fuel
containing methanol. It can
corrode metal parts in the fuel
system and also damage plastic
and rubber parts. That damage
would not be covered under the
vehicle warranty.
For the 2012 v-6 don't use more than 15 percent ethanol blended fuel. This was taken from my owners manual the " notice " in the last paragraph leaves little doubt.
Its better to burn out , than to fade away.
coloeb is offline   Reply With Quote
Old 06-02-2012, 11:23 PM   #21
colingordon
Her Name is Mila
colingordon's Avatar
Drives: 2012 Camaro 1LT A6
I am not sure if I am right buy isn't Ethanol peanut oil? If it is I know that Ethanol will destroy your fuel lines even if the car says it can run E85. I dont trust it, it ruins your fuel lines and I think can harm your engine
colingordon is offline   Reply With Quote
Old 06-03-2012, 08:55 AM   #22
MediumLabowski
Drives: iBM iLFX
It doesnt say no, what manual are guys reading? Methanol is not ethanol.
Whatever, E85 is not currently relevant anyway. You spend less, but use more, unless you drive the flex Saab 9-5.
(the letter designation "LFX" was chosen because its a flex engine)
Old 06-30-2012, 11:49 AM   #23
coloeb
coloeb's Avatar
My earlier post was copied and pasted directly from my owners manual. I am not sure why the lfx cars were not given a updated manual, but you are correct they are e-85 compatable.
Old 06-30-2012, 01:14 PM   #24
06_warrior
06_warrior's Avatar
Drives: 2012 1SS LS3 M6 black on black :)
I read on some web sites that the 2012 camaro with the LFX motor is compatable running E85 but it does not say any where in my owners manual that you can use E85. I'm not willing to risk problems using the E85 fuel. If a car is not compatable to use E85 that fuel can reek havoc on the fuel system and the engine itself. It's simply not worth trying it to see if it works or not.
06_warrior is offline   Reply With Quote
Old 07-03-2012, 09:15 PM   #25
rchrdp305
rchrdp305's Avatar
Drives: 2012 Camaro 2LS
i filled up first with 85, but after 89. i have an 2012 2ls. after 8000 miles, im doing 27.7 mpg in the streets. in the highway i do like 30 - 40 mpg
Instagram = @rchrdp305
rchrdp305 is online now   Reply With Quote
