| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
![]() Drives: 2010 Camaro SS Join Date: Oct 2010
How to lube Pfadt trailing arms
To those that have Pfadt rear trailing arms: How are you greasing the zerk fitting that is on arm where it mounts to the body? Is there an easy to get to it without having to take the tire off and jack the car up? I cannot seem to get my grease gun on it easily.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete Roto-Fab Intake Stainless Works 1 7/8" Long Tube Headers Corsa Exhaust |
The zerk fitting I'm talking is shown on the right size of this picture. That is the side that mounts up by the body.
L99 - 440 RWHP
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Well the bushing is designed to take grease as applied from a gun, but be very careful to not use the wrong grease. Generic grease or lithium grase that we typically see used in grease guns isn't going to offer great life versus the lube we provide. Poly can be a cranky product to use at times, and the Energy Suspension Formula #5 is by far the best lubricant we've used with polyurethane.
If you're trying to do preventative maintenance we would rather see you not use the Zerk fitting with a typical automotive grease, and instead just disconnect the arm and properly relube with Energy Suspension Formula #5 that we provide with all of our kits if you do hear a little noise. You can purchase this lube in tube form, but it's pretty expensive. Typically Jegs/Pegasus Racing/Summit will have Formula #5 available in big tubes. |
Logic is dead
Sorry for hijack, but to piggy-back off the Pfadt post, how often should you relube? My arms are on their way to be delivered.
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ - Vortech V3 Supercharger - Kooks Stepped Headers, Magnaflow 16580 - Suspension by Pfadt, Hotchkis. 2007 Trailblazer SS- Sold 2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold 1994 Camaro Z28 - Sold |
#5 | |
![]() ![]() ![]() Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
#6 |
Lube them well on installation, and take a look at them every 6 months to a year. It's less about periodic maintenance with these parts and more about making sure they get relubricated properly if they start to squeak.
#7 | |
You've got a couple options. Use the proper lube the first time and don't worry about it for many many miles, or preemptively replace the Formula #5 with something which may not work out so well and end up causing more maintenance headaches than if the original lube was left intact. This doesn't mean that our polyurethane products are going to be maintenance free because none are, but when they do need maintenance using the recommended products and procedures will save you loads of time in the long run. Given that every driver and driving conditions will differ it's really tough to say exactly how often to relube polyurethane bushings. We do go to great lengths to keep performance and reliability high, such as using Graphite Impregnated bushings, coating all poly sleeves with a low friction coating, cutting grooves into bushings for improved lube retention, as well as including one of the best poly lube products available with all of our kits. Our suggestion is that if you're going to service your tailing arms taking your time and using the best product available will eventually save you a lot of time over using a generic product and servicing them more frequently. But keep in mind that we haven't tested with this particular SuperLube product, so your mileage may vary. |
#8 | |
#9 | |
![]() ![]() ![]() ![]() Not only that, but theres virtually no way to get to the fitting unless you have it pointing downward on that arm |
#10 | |
Ultimately the choice is yours. Worst case scenario you try it out a different product and it doesn't work quite as well, either way you're not going to cause damage to the bushing it's self so you've really got nothing to lose here. Providing folks with a Zerk gives folks with this option at all.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 Join Date: May 2011
Hotchkis sells lube in grease gun size for poly bushings. Works very well and is a pain to get off anything you get it on. Undoing the outer bolt and dropping the arm is the easiest way to reach the fitting so I agree it doesn't make much sense there. It's not something you should have to do very often though.
#12 |
![]() ![]() Drives: Black 2010 2SS/RS LS3 Join Date: May 2010
I am pretty sure you can replace the straight fitting with a 90 degree one...
#13 |
Found this at Spohn.net
Poly Super Lube You would think Pfadt would sell what they recommend or at least tell you where to find it.
Built and tuned by Cincy Speed
C5FestIII 2012 Photo by Mindz |
#14 | |
http://www.energysuspensionparts.com...shing-Lube.asp Again, you're free to use what ever bushing lube in what ever delivery mechanism you prefer. Our recommendation is that even if the Formula #5 isn't available in grease gun form to still use the Formula #5.
| Thread Tools | |
