Caryle Racing
Old 05-14-2009, 02:27 PM   #1
MadMaxx
Master of the V6
MadMaxx's Avatar
Drives: 2010 Camaro 1LT/RS
Differences in LLT vs. LY7
So it looks like the head exhaust port spacing and bolt pattern is the same... what internal changes did they make on the LLT? Is the DI retrofit to the existing motor design (w/ increased CR) the only major changes to the design?
MadMaxx is offline   Reply With Quote
Old 05-14-2009, 02:56 PM   #2
Grape Ape
Drives: 96 Bronco w/ a 5 speed
The LLT has oil squirters to cool the bottom of the pistons, but I don't think the LY7 does.
Grape Ape is offline   Reply With Quote
Old 05-14-2009, 03:14 PM   #3
MadMaxx
Master of the V6
MadMaxx's Avatar
It doesn't. So it looks like the LY7 head at least sports the same bolt pattern on cold and hot sides, as well as the block surface. It's unclear if the valve areas are the same.
The reason I was interested is that we have 6 pulled from a solstice out in the boneyard. I was going to use it for mock up of some bits..
Old 05-15-2009, 01:31 PM   #4
Grape Ape
If you are just interested in the valves, I suggest you lookup the part numbers for the valves, cam shafts and everything in between. If that area of the head were different, then they would need different parts with different part numbers. You could also look at the Cadi boards because at least one Cadi was offered with both and there are probably some guys at least talking about upgrading.
I thought the Solstice was only offered with a 2.3 4-cyl or the sweet turbo, DI 2.0 4-cyl (LNF).
Old 05-16-2009, 11:20 AM   #5
MadMaxx
Master of the V6
MadMaxx's Avatar
Maybe it wasn't a solstice then, but we've got something sitting out there w/ a 3.6 from a late model car. Might have been that cady they picked up for parts, who knows.
I'll see what I can dig up on the heads.
LLT engine specifications Tran Wiki 2 03-29-2010 11:06 AM
Do you know how good this LLT is? 2SSRS@Gen5diy Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 47 03-25-2009 11:29 PM
DIFFERENCES BETWEEN LS 1LT AND 2LT DGordon Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 13 03-21-2009 12:58 PM
v6 vs v8 looks design differences cosmin haraga Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 9 01-01-2009 05:01 PM
V6 versus V8 -- exterior / trim differences? King Cash 5th Gen Camaro SS LS LT General Discussions 10 03-11-2008 09:31 PM
