Gen5DIY
Old 05-31-2012, 08:55 PM   #1
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Beginner Questions
Okay guys, I have a few questions for the pros! First off, let me say that I have no clue about anything when it comes to sound systems. I know completely nothing so please bear with me. I have a Non-BA system and would like to upgrade it. I don't have a lot of money so I don't want something that is going to tear up the bank either. As of right now, I don't know if I am going to add a sub since I need all the trunk space I can get (if someone has an alternative to this, please feel free to tell me). What should I do first with these requirements I have listed above. Also, what would be the best "bang for the buck" upgrades. Any company I should look at or stay away from? Thank you for the help in advance guys!
Old 05-31-2012, 10:08 PM   #2
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
The first thing is what you're looking for? Better sound quality or to add a little bump?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 05-31-2012, 10:20 PM   #3
lscamaro
lscamaro's Avatar
I guess a little of both. I want a little more bass but nothing too too obnoxious. I'd like to actually be able to hear some bass since I feel like the stock system has none but I'd also like better quality for sure. I don't know if that's possible but that's really what I'm looking for. Nothing that will annoy other people.
Old 05-31-2012, 10:32 PM   #4
Chris82xx
Chris82xx's Avatar
I would start small in that case. There are a ton of boxes out there that will fit your trunk, you just have to decide which one works for you. I would go with 1 or 2 10" subs. I've always been partial to Alpine or JL. As far as an amp, you can mount it to the back of the seat. Take your time doing it and it'll look nice. Then you just have to buy the wiring.
811RWHP/719RWTQ
Old 05-31-2012, 11:20 PM   #5
lscamaro
lscamaro's Avatar
If I'm not too sure about a sub, should I start with the speakers or will they not offer any improvement in sound? Does the amp and sub make a huge difference?
Old 06-01-2012, 12:01 PM   #6
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
Yes. I typically tell customers to start with speakers and build onto the system if needed after that if you aren't sure. Just speakers alone will make an audible difference in your system and may be all you need, but a sub can certainly round out the sound even if you don't happen to be fan of a lot of bass.
CrutchfieldBrooke is offline   Reply With Quote
Old 06-01-2012, 12:28 PM   #7
lscamaro
lscamaro's Avatar
What speakers do you recommend for someone on a budget? Is there anything good that won't cost me an arm and a leg? I have the non boston acoustic system in case that matters
Old 06-01-2012, 12:52 PM   #8
CrutchfieldBrooke
What budget do you have in mind for the speakers?
Old 06-01-2012, 01:41 PM   #9
Chris82xx
Chris82xx's Avatar
Panel speakers really won't do too much unless it's hooked to an amp, or an aftermarket stereo. I would personally do a sub first that has a dual voice coil. You'll get all the pounding you want, with a little more sound. This would allow you to turn down the lows on the rest of the speakers and bring up the mids and highs. It balances out nicely.
811RWHP/719RWTQ
Old 06-01-2012, 06:20 PM   #10
lscamaro
lscamaro's Avatar
200-300 a set maybe. I'm not too sure at the moment.
Old 06-09-2012, 06:22 PM   #11
lscamaro
lscamaro's Avatar
Has anyone used an infinity basslink? My uncle has one in his Camaro and it makes the system sound pretty good. Anyone have any benefits and cons to it? Thanks!
Old 06-10-2012, 09:50 PM   #12
CrutchfieldBrooke
The Basslink is a good option if you're on a budget and just looking for something to fill in the lows that you don't get from the regular speakers. It wouldn't be my first choice for a powered sub, but it'll def work to give you some bass in the car. You should have a pretty good idea on how it'll sound and if it's enough for you since you've got to hear it.
Old 06-11-2012, 03:34 AM   #13
lscamaro
lscamaro's Avatar
Okay, well see now you have me intrigued
What would be your first choice for a powered sub. Also, any disadvantages for going with a powered sub?
What are your choices for something that would give me decent sound, by replacing some lows since thia car has no bass and being able to remove fairly easily and quickly. I liked that the basslink could be removed easily since I track my car quite a bit and remove things from the trunk
Old 06-11-2012, 08:06 AM   #14
ecko04
Drives: Too many to list
Stay away from the Kicker HS8 Hideaway powered sub...it absolutely sucks... having owned one myself.
ecko04 is offline   Reply With Quote
