SDTW Custom Wheels & Tires
Old 05-31-2012, 11:13 PM   #1
martinezj454545
Drives: 2011 Camaro LS V6
Wheel/Road Noise
So while driving from 0 to 30 i can feel a very slight rubber rubbing noise coming from the wheel. Now the stering wheel does not shake or anything its just that rubbing noise that i hear while driving thats bothering me. I check the clearence and everything is clear of the wheels. the closest thing to the wheels is the springs but i can still put all my fingers through it so i dont think its rubbing on that. I was also wondering if it could just be the road noise since i went from my OEM 18" wheels to wheels that are 265/35R 22. Could it just be the road noise or is something just rubbing under there.
martinezj454545 is offline   Reply With Quote
Old 05-31-2012, 11:23 PM   #2
usnatclee
usnatclee's Avatar
Drives: '12 2SS/RS, '13 Vette, '13 Wrangler
Less rubber = more road noise.
2012 Camaro Ashen Grey Metallic 2SS/RS "Timberwolf". Custom exhaust, RX oil catch can and oil breather, CAI inc intake, SLP 160* thermostat, TSP 2" LT headers w/ off road pipes, custom cam, tuned. 467rwhp 450rwtq.
2013 Corvette Torch Red LS3. 378rwhp/375rwtq SAE corrected, tuned.
ROCK CHALK JAYHAWK GO KU!
usnatclee is offline   Reply With Quote
Old 05-31-2012, 11:33 PM   #3
martinezj454545
yeah i tought that but just want to make sure it is cuz when i start to slow down you can hear it better and kind of feel it just a tad.
Old 06-05-2012, 09:16 PM   #4
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Please check your ebrake cable to make sure it isn't rubbing on the inner barrel of your rim.
Old 06-05-2012, 09:34 PM   #5
stlrammer
stlrammer's Avatar
Drives: 2017 2LT/RS Yellow
Check the inside sidewalls of each tire to make 100% sure your not cutting into your inside sidewalls. The noise you describe does not sound like road noise to me. Good luck.
stlrammer is offline   Reply With Quote
noise, road, rubbing, wheel
