BeckyD @ James Martin Chevy
Old 05-31-2012, 11:22 PM   #1
ACS Composite
ACS Composite's Avatar
Drives: 2010 Camaro
NEW ACS Bumper T3 Side ports with LED Turn !
Another innovative ACS products, port is installed without the use of any adhesive or 2 way tape. Kit includes a set of intake ports, snap on grill mesh, inner mounting brackets, templates and instructions. Simply trim the bumper using the supplied template, slide port in and by the back side install the mounting bracket and screw in place by reusing the wheel well fasteners.
T3 Components are designed to fit Camaro SS V8 Bumpers
Lighting Option (33-4-063)
Safety; Did you know your Camaro has no Side Blinking Marker. Driver's ahead of you may see your front blinker, and driver's behind you will see the rear lights, but the driver in the lane next to you, in your blind spot has no clue you are intending to change lane.
Enhance your safety by becoming more visible the drivers around you. Our Side port blinker will be activated in sync with your turning lamps letting the driver in the lane next to you aware of your intentions and reduce the chances of collision.
Convenience : With the simple action of unlocking your door, the side port LED light will illuminate a bright white light forecasted on the side of your car.
More info can be found in our webstore
ACS Composite is offline   Reply With Quote
Old 06-01-2012, 12:55 AM   #2
Falundir
Falundir's Avatar
Drives: 2017 1SS 1LE - Hyper Blue, P85DL
I think that is awesome, great job!
Falundir is offline   Reply With Quote
Old 06-01-2012, 03:29 AM   #3
sub zero
sub zero's Avatar
Drives: RED@2SS
nice , how it's look like in video ?
sub zero is offline   Reply With Quote
Old 06-01-2012, 09:31 AM   #4
ACS Composite
Drives: 2010 Camaro
Funny you say that, made a video last night just need to compile it.
Old 11-23-2012, 01:53 AM   #5
camarostar2010
Drives: 2011 SS
waiting..I hope u have black friday sale for all these ports. i will definitely jump on
camarostar2010 is offline   Reply With Quote
Old 11-24-2012, 04:50 PM   #6
Cmlloveless
Drives: 2010 2SS RS
Any pics of the full front end? Would like to see what it looks like on the car when it's not up close.
Cmlloveless is offline   Reply With Quote
Old 11-24-2012, 04:59 PM   #7
ACS Composite
Drives: 2010 Camaro
Old 11-24-2012, 04:59 PM   #8
ACS Composite
Drives: 2010 Camaro
Use coupon code BLACK and get 10% off.
http://www.acscomposite.com/store/#!...83&id=10970882
Old 11-24-2012, 05:15 PM   #9
ACS Composite
Drives: 2010 Camaro
acs, camaro t3, port
