Nickey Chicago
4th Generation Camaros 1993-2002
Old 06-01-2012, 07:10 PM   #1
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
Thumbs down It's tranny problems now..
So here's the low-down. The 'maro's tranny is shifting really slow, winds out the gears, and when it finally does shift into gear it does it kinda hard. Any ideas on what it could be?
3" Magnaflow cat-back, MSD 8.5mm Super Conductor Wires, NGK Iridium plugs, KN Air Filter, Halo Headlights, Shaved Air Lid, Chrome ZR1 Rims, SS Hood Scoop/Spoiler
Lee0123567 is offline   Reply With Quote
Old 06-01-2012, 07:22 PM   #2
insidethreat07
4-17-11
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
Take it to H&K and talk to Kevin Vennekotter
2001 Camaro 3.8 V6
Silver Hockey Stripes, Berger Panel, Cardinal Red Camaro Rear Insert, 10 Spoke SS Wheels, Bowtie Center Caps, BMR Shock Tower Brace, Air Silencer Delete, Shaved Intake Lid, K&N Air Filter, Whistler Headlights, Eaton Limited slip, UMI Rear LCAs & PHB, Nitto 555, Flowmaster Axle Back Exhaust
Soon To Be Added:
Pacesetter Mid-Tube Headers & Y-Pipe, 3'' High Flow Catalytic Converter, SS Front & Rear Sway Bars.
insidethreat07 is offline   Reply With Quote
Old 06-01-2012, 09:57 PM   #3
dmginc
dmginc's Avatar
Drives: 01 Jeep/11 HHR
i had a car that did that a long time ago, turned out to be a vacuum leak.
dmginc is offline   Reply With Quote
Old 06-01-2012, 09:58 PM   #4
austinjames
Account Suspend...Right
austinjames's Avatar
Drives: Synergy LS & Vulcan 1600cc
austinjames is offline   Reply With Quote
Old 06-01-2012, 10:09 PM   #5
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
Clean that MAF, and make sure the battery is in good shape.
I had similar issues and I replaced the battery after finding it to be completely dry. I haven't had an issue since, but I had seen a bulletin from GM about the MAF's causing similar problems as well.
2011 Camaro SS, Summit White with Orange Stripes
1998 Trans Am, Red, Functional WS6 style hood, MTI Carbon Fiber Lid, ARH LT's, Magnamouth, LS6 intake, UMI STB, UMI LCA's, UMI LCA Reolcation Brackets, UMI Adjustable Lower A-Arms, BMR Upper A-Arms, UMI 35mm and 22mm Solid Sway bars, BMR Springs, KYB AGX Shocks
xXSilencerXx is offline   Reply With Quote
Old 06-02-2012, 06:28 AM   #6
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
I put a new MAF in it a week or so ago so i don't think it's that. I do have a new O2 sensor that goes in the manifolds.
