JUICEDMOTORSPORTS
Old 05-14-2009, 08:20 PM   #1
Dentyneice
Drives: 2010 Camaro 2ss
Wheelie Possible?
Anyone think it's possible to get the Camaro to pop a wheelie with the ls3 engine?
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 05-14-2009, 08:23 PM   #2
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Yeah, fill the trunk with lead. Pop the clutch at redline. Replace drivetrain. Repeat.
Old 05-14-2009, 09:01 PM   #3
gunslinger
Drives: 1998 Z28 M6
You're kidding, right?
GTR: Get Transmission Replaced
gunslinger is offline   Reply With Quote
Old 05-14-2009, 09:31 PM   #4
Krazy and old
Krazy and old's Avatar
Drives: 2007 Shelby GT 500
Try it and let us know.
Krazy and old is offline   Reply With Quote
Old 05-14-2009, 11:39 PM   #5
Camarino
DrIvE iT LiKe Ya STOLE It
Camarino's Avatar
Drives: 2005 Mustang, '68 Camaro Z28
LMAO
depends ...
does the ls3 put abt 700 horses to the rear wheels ?
with something like 4.56 gears and abt 500+ lbs of torque
Lol SILLY RICER WINGS ARE FOR PLANES! :flag1: :flag2: :flag1: :flag2:
Camarino is offline   Reply With Quote
Old 05-14-2009, 11:41 PM   #6
Camarino
Camarino's Avatar
lol btw i was trying to find a vide of my neighbors car at the track (he lifted un- unexpectedly and he doesnt have wheelie bars) and came across this in a hot rod forum IT JUST MADE MY BRAIN HURT
You can come close if you know some details about your car. First you must know where the center of gravity of your car is in relation to the rear wheels. Since torque is force acting on a lever arm, you must be able to generate enough torque so your rear end can lift the weight "W" of your car acting on a lever arm "L" equal to the distance in feet from the rear wheel center to the center of gravity. Once you know that and the gear ratios in your tranny "Rt" and rear end "Rr", you can do an easy calculation. Also, if you are running a torque converter, you gain an approximate 2.5 torque increase "Rc" at the instant you begin to move which is applied in the equation.
Assume,
W = 3000#
L = 48" = 4ft
Rt = 2.75
Rr = 4.56
Rc = 2.5
Torque at the fly-wheel required is,
(L x W) / (Rr x Rt x Rc) = (3000# x 4ft) / (2.75 x 4.56 x 2.5) = 382ft.lb.
One more item I didn't mention B4, to find the center of gravity of the car all you need to do is weigh the front end "Wf" seperately and the whole car "W". Now, measure the wheelbase "Lc".
Here is how to use this info to determine the length "L" to use in the previous equation,
Assume,
Lc = 100" = 8.33'
Wf = 1800#
W = 3000#
L = (Wf x Lc) / W = (1800# x 8.33') / 3000# = 5'
Remind me and I'll post a picture in my Photo Album tonight when I get home that shows how to weigh your car with a 200# bathroom scale.
There are some issues with tires that will determine whether you lift the front end or spin the tires. If you have enough traction, it won't matter what size your tires are, you will pop a wheelie. Since they will be fixed to the ground during a wheelie, they could be 20" or 30", it won't matter because they are essentially a part of the ground and your car will be trying to rotate around the axle that is anchored to the ground. However, if the tires can't generate enough traction to anchor them to the ground, the torque you apply will break the tires loose, they won't be 'part of the ground' anymore and they will spin preventing the front end from raising. Traction "Wt" is a force (like weight) resisting the torque applied to the rear axle and is a function of the coefficient of friction "Fc", weight pressing down on the tire food print "Wr", area of the tire foot print "At", and diameter (radius) of the tire "Rt" which is the lever arm for the traction force.
Traction can be calculated if you know the weight of the rear of your car, the exact area of the tire in contact with the pavement, and the coefficient of friction of the tire/pavement combo. the equation is,
Wt = Fc x Wr x At
This is the force available to resist breaking the tires loose, thus causing a wheelie. If the it is at least
Wt = (W x L)/Rt
Then you can wheelie. If it is smaller, you will spin the tires.
Coefficient of friction is a fraction from 0.0 - 1.0 and is experimentally determined for two surfaces in contact. Polished steel skate blades on ice have an Fc of near 0.0 (impossible to reach perfect 0.0) while 80 grit sandpaper on 80 grit sandpaper has an Fc of 1.0. I don't remember what racing tires on pavement Fc is but it must be around 0.9.
As you can see from the equations, wheelies are enhanced by more weight on the rear tires, center of gravity toward rear wheels, tall tires, wide tires with a lot of tread lying on the ground. Spun tires are result of opposite trends. Both spun tires and wheelies benefit from low gear ratios and high engine torque. Drag racers perform a balancing act of getting as much traction on the rear tires (move weight over rear tires, biggest tires possible, etc.) while keeping the center of gravity far enough forward to prevent wheelies. They want ALL of the torque to be transmitted into the traction force which will propel the car forward as fast as possible. Spun tires and wheelies are both no-nos!
Old 05-15-2009, 12:43 AM   #7
Morepwr
woohoo
Morepwr's Avatar
Drives: Silverado, 70cutlass, 57chevy&more
with a floorjack
I am not useless, I can still be used as a bad example!
Morepwr is offline   Reply With Quote
Old 05-15-2009, 08:26 AM   #8
Metal Gear SS
Metal Gear SS's Avatar
Drives: 1987 Chevrolet Corvette
Oh, it's possible. Always a winner in NFS: Pro Street, but you gotta mod it beyond Stage 3
Metal Gear SS is offline   Reply With Quote
Old 05-15-2009, 08:31 AM   #9
fdjizm
Drives: 2008 Mustang GT/CS
Maybe, this mustang does wheelies with 400hp and some slicks but it's 3,300lbs
Many of you have been wondering, and we've asked the question ourselves, why the Cobra Jet is "only" rated at 400 horsepower. After all, the GT500, which also features a 5.4L supercharged V8, puts out 500. We asked around at Ford and found that the Cobra Jet has been de-tuned to meet specifications needed for NHRA's AA Stock class. The official horsepower figure has yet to be finalized, but expect it to be right around 400 as quoted before.
http://www.autoblog.com/tag/FordFr500cjMustang/
fdjizm is offline   Reply With Quote
Old 05-15-2009, 08:55 AM   #10
speedster
SST...
speedster's Avatar
Yeah, you're right. Someone could get the Camaro shell GM is selling for drag cars and do the same. Keep the weight down.
Old 05-15-2009, 09:05 AM   #11
fdjizm
that would be a nice track setup
Old 05-15-2009, 12:06 PM   #12
Camarino
Camarino's Avatar
He also installed low-compression CPE pistons and a custom Big Stuff Gen 3 fuel-injection system. To complete the build, twin Precision 88mm turbochargers force 50 psi of boost into a 510ci fuel-injected engine producing more than 2,600 horsepower and capable of revs over 10,000 rpm.To be competitive, the car will need to run in the mid-to-high 6s at around 230 mph, and with all this Bow Tie power, we don't see that as being an issue. In testing, the car has gone 4.43 at 178 in the eighth-mile, which would equate to about a 6.90 at over 205 mph....With 2,600 horsepower pushing 2,500 pounds,
more pics follow link
http://www.superchevy.com/features/c...car/index.html
Old 05-15-2009, 12:29 PM   #13
GMtothecore
"That Guy"
GMtothecore's Avatar
Drives: Camaro SS...........what else?
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
Originally Posted by Camarino View Post
Holy MASSIVE twin turbos Batman!!!!
GMtothecore is offline   Reply With Quote
Old 05-15-2009, 11:07 PM   #14
qbert48
qbert48's Avatar
Drives: 2SS SIM
and that mod cost what? holy bat crap
2SS RS SIM gray leather stick shift ground FX
thank you gary richards @ classic chevy in sugarland
welcome home
1100 4-27-09
6000 6-27-09
yes i got to the dance late don't hate me
qbert48 is offline   Reply With Quote
The Official FAIL thread theholycow Off-topic Discussions 926 09-01-2014 11:23 PM
Manual Transmission Dragster Camaro. Check out this wheelie! Mindz General Automotive + Other Cars Discussion 1 09-05-2007 03:43 PM
