Old 06-03-2012, 04:08 PM   #1
flyer08
Drives: 2010 2SS/RS
amp/sub purchased - now what?
Ive got the BA system and am going to replace the amp and add a sub. I bought a new amp (Jl Audio 900/5) and sub (JL 10w3). Im going to pick up the fark kit when they become available and the camaro box from ******** and some sound deadner.
What else do I need to finish this process? Ive seen amp kits sold online but not sure what all is in them and if I need to pick one up. Thanks
flyer08 is offline   Reply With Quote
Old 06-03-2012, 04:16 PM   #2
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
You need need a sub enclosure, an amp wiring kit, and someplace to mount the amp. I too have the HD900/5. While small, I don't think it can exactly fit in the factory amp location and still leave room for wires.
I went with the ******** amp mount (left side install), Knu-Konceptz 4-ga 4-ch amp install kit. Even with this kit, you will need more ground wire, if you want to use the battery as your ground, and some wire for your sub. Also the fuse is too big, I used this fuse.
I used the Audio Integrations enclosure. But more people seem to go with the ******** Stealth Enclosure.
jeepguy_1980 is offline   Reply With Quote
Old 06-03-2012, 08:03 PM   #3
flyer08
Drives: 2010 2SS/RS
Thanks, the stuff is in the mail so I havnt had a chance to check to see what fits where
Old 06-03-2012, 08:21 PM   #4
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
Looks like JeepGuy has you all covered on this one.
CrutchfieldBrooke is offline   Reply With Quote
Old 06-03-2012, 08:31 PM   #5
mycamaro2011
mycamaro2011's Avatar
Drives: 2010 Camaro 2LT Victory Red
Grab a farad Cap too
mycamaro2011 is offline   Reply With Quote
Old 06-03-2012, 08:32 PM   #6
jeepguy_1980
While I'm sure you could force it to fit on in the factory location, I don't think it's ideal. If you want all the materials ready for your install just check out the specs below. The HD900/5 is .24"x.54" too big. This is how mine looks.
Originally Posted by ********.com
2010 & Up Camaro Factory Fit Amp Mount
Effective mounting area: 7.75" x 10.5"
Amps larger than this will not fit
Originally Posted by JLAudio.com
HD900/5: 5 Ch. Class D System Amplifier, 900 W
Height (H) 1.93 in / 49 mm
Width (W) 10.74 in / 273 mm
Depth (D) 8.29 in / 211 mm
Net Weight 6.85 lb / 3.11 kg
Old 06-05-2012, 06:07 PM   #7
flyer08
Drives: 2010 2SS/RS
What would I need this for?
Old 06-05-2012, 06:15 PM   #8
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
swap the stock battery for an Optima Yellow top while you're at it...
