Old 06-03-2012, 08:16 PM   #1
ubrimah
Oreo
ubrimah's Avatar
Drives: Summit White LT/RS A6
Amp and subwoofer
So I'm looking to get this subhttp://www.jlaudio.com/12w3v3-4-car-...-drivers-92154 but I have no clue what amp to get for it. I also heard something about replacing the stock amp with a better one and wire the sub into that for better results but it seems like a pricey way of doing things. Could anyone recommend an amp for me?
Click the pic!
ubrimah is offline   Reply With Quote
Old 06-03-2012, 08:21 PM   #2
mycamaro2011
mycamaro2011's Avatar
Drives: 2010 Camaro 2LT Victory Red
well, just me but its a 2ohm sub so you need to buy a 2ohm mono amp to power it.
But i would problly go with 2, 12" 4ohm subs in a box and wire them into 2ohms
I just put in 2-12" kicker subs paid $180 shipped, custom box for 2-12" paid $120 and 1 MTX audio 1000 watt 2ohm amp for $180 shipped. just installed it and the bass blows the roof off.. still making some adjustments and using deadening mat too
mycamaro2011 is offline   Reply With Quote
Old 06-03-2012, 08:58 PM   #3
ubrimah
Oreo
ubrimah's Avatar
I'm just looking to have one sub. for now at least. there's a 4ohm version though so would it make a difference getting that instead?
Click the pic!
Old 06-03-2012, 09:12 PM   #4
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
I would suggest getting the 2-ohm version of the sub. This will allow you to get the most power out of your amplifier. You can then get a mono sub amp and run it at 2-ohms.
CrutchfieldBrooke is offline   Reply With Quote
Old 06-03-2012, 09:15 PM   #5
CrutchfieldBrooke
http://www.crutchfield.com/I-rCHVc111/App/Product/CompareTo.aspx?compareItems=01|500MRPM500&compareI tems=01|2061DX5001&compareItems=01|136JX5001D&g=34 7250
Here are a few amps that will give you the exact amount of power you would need for the 2-ohm version. I really like the JL amp in this list!
Old 06-04-2012, 05:05 PM   #6
ubrimah
Oreo
ubrimah's Avatar
Around how much would install be?
Click the pic!
Old 06-05-2012, 12:14 AM   #7
mycamaro2011
amp speaker
well i think it all depends on wether you are going to update you system anytime soon as far as a 2ohm speaker and amp.
If you later upgrade to another 2ohm amp in a box i dont think you could run both in parrell without getting a diff amp. If you do 2- 4ohm subs and wire they in parell it will give to 2ohm load.
Maybe someone else can chime in but i think it how long before u upgrade. I had a 10 inch and it didnt do that much
I mean your looking at about prob $300 shipped for that 1- 12inch. I paid $180 shipped for 2- 12inch MTX VT subs and $180 for a 1000 watt mtx amp
Old 06-05-2012, 10:08 AM   #8
kalimus
kalimus's Avatar
Drives: '14 Z51 3LT Stingray and '13 Cruze
If you hook a 2 ohm sub up to an amp that's not designed to put power out at 2-ohms, you're going to screw your amp, or your woofer, or both. If you only want 1 sub, get a 4 ohm sub. Or a 2ohm sub with dual voice coils wired in parallel for 4 ohms. If you want 2, you can get two 8 ohm subs and wire them in parallel. The possibilities are really endless. And save the money and get a good sub amp. JL amps are good at almost any impedance you put to them because of how their power supply works.
kalimus is offline   Reply With Quote
Old 06-05-2012, 11:47 AM   #9
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
Wired in series, not parallel.
jeepguy_1980 is offline   Reply With Quote
Old 06-05-2012, 12:22 PM   #10
CrutchfieldBrooke
You guys make some valid points, but I'd still be more likely to stick with the 2-ohm version for now unless you are going to upgrade to two of the subs quickly. If so, plan ahead with the amp. Kalimus, you are correct that some amps aren't stable at 2-ohms, but that tends to be when you are bridging channels on an amp. This is the reason I'd stick with a mono amp when powering sub(s). They are all stable at 2-ohms, and some lower.
If going to include two informative links on subs, amps, and wiring of the two in case it's helpful:
http://www.crutchfield.com/I-rCHVc111learn/learningcenter/car/subwoofers_wiring.html?g=100&tp=14
http://www.crutchfield.com/I-rCHVc11...ml?g=500&tp=13
Old 06-05-2012, 12:33 PM   #11
kalimus
kalimus's Avatar
I got ahead of myself. I was thinking of a pair of DVC's that had the voice coils wired in parallel and then the pair wired in series. I didn't even pick the right impedance. At least i got the dual 8ohm subs with the correct word haha. It happens sometimes when I get a lot of options running through my head.
Old 06-05-2012, 01:36 PM   #12
LineofPerfection
LineofPerfection's Avatar
Drives: 2010 2SS Camaro "Big Blue"
Go with this, you can't go wrong. It is all plug and play and replaces the original amp.
http://www.camaro5.com/forums/showthread.php?t=129862
Big Blue
LineofPerfection is offline   Reply With Quote
Old 06-05-2012, 06:31 PM   #13
ubrimah
Oreo
ubrimah's Avatar
Wow that looks pretty good. How does it compare to the 12W3v3? And also I couldn't locate a price
Click the pic!
Old 06-05-2012, 07:37 PM   #14
Storm T
Can't slow down
Drives: 2013 SS Dusk Edition (Insain Bolt)
Infinity plug and play?
The link is dead for that Line. Could you PM me a link on that and where you got it?
Storm T is offline   Reply With Quote
amp
