Old 06-07-2012, 03:36 PM   #29
BeachBum
Drives: 2012 (ZL-1) #468
Originally Posted by oldfriend View Post
You should have asked HER .
I Did Ask Her !!!! Air Conditioner Came On Full Blast - Does This Mean I Got The Cold Shoulder? L-O-L
BeachBum is offline   Reply With Quote
Old 06-07-2012, 05:00 PM   #30
racebum
Drives: 2012 ZL1 Hennessey 700 Ashen Grey
Speed had nothing to do with it, Joe. I didn't touch the brakes during that speed run. My wife had done all the driving to the 1500 mile mark and she doesn't hot rod.
racebum is offline   Reply With Quote
Old 06-08-2012, 05:54 PM   #31
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Might ask Erik @ Torq to see what pads he was using last weekend... Thread is on the home page... 1st thing he did was swap pads before hitting the track... all else was showroom stock except wheels.
Old 06-09-2012, 11:09 AM   #32
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
there he is! am i to assume you coasted 2 miles to stop then? how many miles now? i was hoping to get up with you before texas. a little stock auto/manual comparo if you will
joes407 is offline   Reply With Quote
Old 06-09-2012, 01:13 PM   #33
thespymaster
thespymaster's Avatar
Originally Posted by BAD ZL1 View Post
Is anyone doing that Brake Burnish procedure the owners manual says you should do? I would like to know before I get my car, do I seriously need to do that procedure? Hell, my drive home alone will be 250miles on the freeway, no time to burnish the brakes on the freeway.
Per videos and manual; only needed done prior to track use!
However both stated to avoid hard stops
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
Old 06-09-2012, 04:12 PM   #34
01pewterz28
Camaro Junkie
01pewterz28's Avatar
You are too late I believe the car is loaded for the trip next week.
**FIFTY HBM 2SS VERT**
Old 06-10-2012, 03:00 PM   #35
maddmark54
Drives: 2012 ZL1
Originally Posted by OldJedi View Post
Thanks for the info, I will take a better look at mine. I am at 975 miles into the break-in and trying to keep it under the 80mph/4000RPM max. But I am noticing quite a lot of brake dust. Just a simple 25 mile cruise without any hard braking at all is leaving quite the noticeable amount of dust in the wheels. Is anybody else seeing this on their ZL1's?
WAY too much brake dust. Already called the dealership and asked about replacements.
maddmark54 is offline   Reply With Quote
Old 08-09-2012, 01:01 PM   #36
Kmax
Kmax's Avatar
Drives: 2012 ZL1 125HP kit , EIBACH springs
I plan on re-placing mine with EBC Red pads. I've good luck with them on other cars in the past.
Kmax is offline   Reply With Quote
Old 08-09-2012, 01:59 PM   #37
gm_joe
Drives: 2002 Pontiac GP 40th GTP, 2012 ZL-1
Originally Posted by BeachBum View Post
gm_joe - I'm seeing the dust too - Are you too thinking of changing pads to something that does not dust as bad? - Your right, sure shows on the Yellow after just a few miles of easy driving
I will probably go to a "lower performance" brake pad when the time comes.
gm_joe is offline   Reply With Quote
Old 08-09-2012, 10:38 PM   #38
OldScoolCamaro
The factory brake pads on the ZL1 leave an exorbitant amount of brake dust that accumulates on the wheels, tires, and lower exterior surfaces of the fenders and quarter panels after very little use.
Old 08-10-2012, 08:00 AM   #39
DRKS1D3
DRKS1D3's Avatar
Drives: 2011 Camaro SS Convertible LS3
Agreed. My Dad polished his car for over 3 hours and it was spotless. We drove it around town, running errands, etc. for two days (less than 100 miles total) and after every trip there were little balls of brake dust all over the wheels. There was no hard braking or anything out of the ordinary, just cruising and enjoying the car. I've never seen brake dust turn into little balls before. At first we thought it was grease or some sort of road grime, but it was in fact the dust. We cleaned up the wheels after each trip because of all the dust and it would return like clockwork.
MY RIDE: 2011 TRIPLE BLACK SS CONVERTIBLE (BOUGHT NEW 4-2011)--6 SPEED MANUAL, K&N TYPHOON INTAKE, FLOWMASTER FORCE II MUFFLERS, HOTCHKIS SUSPENSION, BLACKED OUT BOWTIES, GLOSS BLACK 20x9 STYLE 41 WHEELS, 285-35-20 GOODYEAR EAGLE SUPERCAR G2'S, JBA HIGH-FLOW CATS, BBK HEADERS, LUNATI CUSTOM GRIND CAM: 227/235 .619/.626 114 +3
DAD'S RIDE: 2012 ZL1 #1866 (BOUGHT NEW 6-2012)--BLACK, 6 SPEED, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 08-10-2012, 08:38 AM   #40
wilmaya
wilmaya's Avatar
Drives: 1970 Chevelle SS396/496
It's the only complaint that I have about the ZL1 so far is the brake dust on the wheels. I did happen to install Hawk Ceramic's last week on the fronts and the dust seems to be greatly reduced. I didn't get to drive it as much this week to really compare how it would look after a few days use.
ZL1 PZVSH2 VIN #428 02/24/12
Official Delivery Date 04/18/2012
GAZ-Summit White
MN6, B92, RTQ, WBP
Russell Chevrolet, AR
11/15/11, 1100
01/13/12, 2030
01/30/12, 2000
01/31/12, 3000
02/02/12, 3300
02/11/12, 3100
02/20/12, 3400
wilmaya is offline   Reply With Quote
Old 08-10-2012, 08:48 AM   #41
01pewterz28
Camaro Junkie
You will see almost Zero dust I have had mine on for 2 months it's soo much better
Old 08-10-2012, 09:05 AM   #42
All-American ZL1
Chevy Power
All-American ZL1's Avatar
Drives: 13 ZL1 M6 #123, '98 Jeep Wrangler
I understand that I am going to have to live with the dust if I want the performance. I was just wondering if anyone had any advice one the best way to keep that dust from etching into the wheels. I have the polished wheels and after the first cleaning with soap and water I noticed that the dust was etching into the surface. Would it be best to wipe it off after each use with a damp rag, or do you need a mild wheel cleaner each time?
All-American ZL1 is offline   Reply With Quote
