BeckyD @ James Martin Chevy
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 05-14-2009, 10:42 PM   #1
25thanniversary
25thanniversary's Avatar
Drives: 92 Camaro Convt RS,2011 Camaro RS
Question on a 92 Camaro
I have a question i have a 92 camaro rs 305 V8 engine with only 69,000 miles on the motor. i have this problem and i can't find out what it causing this i always have to check the engine oil. i check the dip stick to see if it has oil it does but i have to add more. the car is not smoking of any kind of smoke so i don't know if it's buring the oil or not. has this happened to any one here on the site with there 3rd gen. i did a compression check with a high performance shop and they told me i have 5 brand new cylinders and 3 that are still semi new.
TEAM LLT
1992 Camaro Rs Convertible
2011 Camaro 1lt Rs
25thanniversary is offline   Reply With Quote
Old 05-15-2009, 01:14 AM   #2
ksmarshall
Drives: 1992 camaro RS
When you pulled the spark plugs did they look black or any one of the plugs obvisouly worse than any of the others? if you have black soot or gunk on the spark plugs then you are burning your oil how often and how much oil are you haveing to burn and if you are burning oil most likely it is your valve guides which is fixable
ksmarshall is offline   Reply With Quote
Old 05-15-2009, 01:21 AM   #3
25thanniversary
i do notice black rings aroud the spark plugs when i change them is this bad i don't want to mess up my motor since i am trying to keep it stock. i change the oil like every 4 months since i really don't use it as much. are the valve guides hard to fix if it is the problem.
TEAM LLT
2011 Camaro 1lt Rs
Old 05-15-2009, 01:31 AM   #4
ksmarshall
im talking about the area of the plug that you screw into the motor usually they are brown or a little black but the valve guides may be the problem and usually your gonna need to take it to a grage to have fixed should be more than a few hundred the parts are cheap but labor is expensive but first check around the motor to make sure your not leaking anything park your car and something clean for a few days like cardboard and look to see if your leeking anything ...... your motor is a pretty tough one and if your burning or leaking a 1/2 quart to every 4 months of driving then you dont really have any problems
Old 05-15-2009, 01:40 AM   #5
25thanniversary
no leak of oil i have had parked for 2 months and i finally moved it and there were no oil spots. yes sometime were i screw the spark plugs in there are black not all of them.
TEAM LLT
2011 Camaro 1lt Rs
Old 05-15-2009, 01:52 AM   #6
ksmarshall
did your plug look like this ?
Old 05-15-2009, 01:53 AM   #7
ksmarshall
http://www.aa1car.com/library/fouled_sparkplug.jpg
Old 05-15-2009, 01:53 AM   #8
ksmarshall
Old 05-15-2009, 02:00 AM   #9
ksmarshall
if you say its black were you screw them in them there may be a leak coming from your valve cover gasket that is located just above the spark plug try looking around the valve covers to see if there is any fresh oil i also looked at you other form about the starting problem now when your car clicks does it eventually start or do u need a jump if your needing a jump you may need to have yor battery checked this can be done at auto zone for free if thats ok have your charging system checked your can do this at auto zone also or is u have a voltmeter you should be putting ot 13.5-14 into your battery when the car is rinning
Old 05-15-2009, 02:01 AM   #10
ksmarshall
buy the way that is an awsome looking car
Old 05-15-2009, 02:02 AM   #11
25thanniversary
no not like that
TEAM LLT
2011 Camaro 1lt Rs
Old 05-15-2009, 02:02 AM   #12
25thanniversary
thanks
TEAM LLT
2011 Camaro 1lt Rs
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
Some thoughts on "recent" developments on this site.... fbodfather 5th Gen Camaro SS LS LT General Discussions 258 05-08-2009 11:24 PM
4 SEMA CAMAROS finally unveiled by GM! (hi-res images & details) FenwickHockey65 Camaro Photos | Spyshots | Video | Media Gallery 237 11-03-2008 11:39 PM
Camaro Chat 9:30-10:00 jdpickering 5th Gen Camaro SS LS LT General Discussions 25 07-22-2008 03:11 PM
