HeadlightArmor
Old 06-05-2012, 08:18 AM   #1
mpyle007
mpyle007's Avatar
Drives: 2011 Camaro 2SS L99
Cig lighter
Anyone know if any of our 12 V charging sources are on all the time? Im trying to plug in something that I want to power so that when I turn on and off the car the power doesn't cycle on and off with ignition.
2011 Camaro 2SS L99 A6
Rotofab CAI w/ race scoop
TSP Long tube headers w/ high flow cats and full x-pipe
GMPP axle back exhaust system
Custom Dyno tune by ARD (Advanced Racing Dynamics)
BMR 1.4" Springs all four corners
"There is no replacement for displacement"
mpyle007 is offline   Reply With Quote
Old 06-05-2012, 08:33 AM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
ALL of the internal power in our cars POWER OFF when the ignition is turned off. The only way that you have have a "HOT" socket at all times is to rewire it straight to the battery source power.
Old 06-05-2012, 12:25 PM   #3
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Yep thats right, you have to wire in a new one. I went to walmart and bought a cig lighter for 5 bucks and wired it to the battery with a switch so I can turn it off. I wanted to charge my phone when the car was off. Kinda annoying not having the option to have it on.
=Stephens= is offline   Reply With Quote
Old 06-05-2012, 02:34 PM   #4
Chevrolet Customer Svc
Drives: GM Vehicles
On page 5-5 in the owner's manual, it states:
Power Outlets
The vehicle has two accessory power outlets; one is located below the climate control system and the other is inside the center console storage. They can be used to plug in electrical equipment, such as a cell phone or an MP3 player. The accessory power outlets do not work when the key is removed from the ignition and the driver door is opened. This helps to preserve the battery life of the vehicle.
I hope this information was helpful.
Brandon
Chevrolet Customer Service
Old 06-05-2012, 03:06 PM   #5
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
easy fix, power port on all the time
here you go
http://www.camaro5.com/forums/showthread.php?t=109776
lupe
overhaulengines is offline   Reply With Quote
Old 06-05-2012, 03:22 PM   #6
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
I have been considering the use of a momentary button and relay. My plan is to set it up so that if I press my button, the cigarette lighter will provide power, even when the car is off. But the next time I start the car, it will revert to losing power when the car is off (unless the button is pressed again).
jeepguy_1980 is offline   Reply With Quote
Old 06-05-2012, 03:29 PM   #7
Sir Nuke
Sir Nuke's Avatar
I looked at the link, and brought up my manual, but, which fuse did you tap into, which number? I'm looking at the diagarm in the manual in the pdf.....but the image is too fuzy. and I'm at work and can't go and look.
Old 06-05-2012, 05:26 PM   #8
jeepguy_1980
Check out this: http://www.camaro5.com/forums/showth...52&postcount=3
Most of the blanks on the fuse panel are already always hot.
