HeadlightArmor
Old 06-05-2012, 10:40 AM   #1
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
Remove bugs easily with the Pinnacle Soft Scrub!
The Pinnacle Bug Safe Scrub is unique, somewhat rough feeling, honeycomb foam block that claims to remove bug guts and embedded residue from paint with out scratching or dulling the surface. Sounds almost too good to be true and holding the stiff foam block does little to assuage fear.
My car has recently been bombarded with bug remains as I made a 150 mile trip up Florida's coast somewhat north of the posted 70 mph speed limit.
The Pinnacle Safe Scrub Bug and Tar Remover.
Feeling the stiff honeycomb foam casts serious doubt in this products ability to remove stubborn bug excrement with out scratching the paint.
According to the directions, it is best to let the sponge soak for 5-10 minutes in soapy water prior to use. I filled a Blackfire Wash Bucket with 3 gallons of water mixed with Dodo Juice Supernatural Shampoo.
While the Pinnacle Soft Scrub was soaking I treated the front bumper of my Zoom Zoom 3 with CarPro's Tar-X.
The Tar-X was left to dwell for 5 minutes...
...then rinsed away. Some of the smaller bugs washed off but the larger stains remained. (They are hard to see in this picture unless you look closely.)
The Pinnacle Soft Scrub had become noticeably softer. I washed the bumper using light pressure and an ample amount of soap/water solution. Amazingly the bug residue came off immediately.
I rinsed the front bumper with care in order to avoid getting the rest of the Speed3 wet.
A Corbra Guzzler made quick work of the water spray.
The result was a predictably clean front bumper.
Finally I spun my car around to check the paint in sun. The result was paint that was literally as flawless as it was before.
Conclusion.
The Pinnacle Soft Scrub Bug and Tar Remover removed the bug residue with ease and when used according to the directions and gently will leave the paint in great condition.
Old 06-05-2012, 06:39 PM   #2
Stinkpickle
Stinkpickle's Avatar
Drives: Black 2LT/RS
Very interesting, I've always just peeled them off with a razor blade or flat head screwdriver!
How long is a single sponge suppose to last? That close up made me think no way.
Stinkpickle is offline   Reply With Quote
Old 06-05-2012, 09:24 PM   #3
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
Wow that's really interesting! I am about to drive 3000 miles coast to coast and am really worried about how to minimize the damage to the paint along the way. Would you even recommend this for a black car? What about road wrap? Any advice is appreciated! Thanks!
ChadG is offline   Reply With Quote
Old 06-06-2012, 10:46 AM   #4
Coop
Drives: 2010 Camaro 1SS
May have to give this a try. How long is the soft scrub good for? Until is wear out or does it last only a few uses?
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
Old 06-06-2012, 10:56 AM   #5
Todd@Autopia
The thing with (really acidic) bugs is they can begin to damage paint right away! If you are going on a road trip were you will not be able to wash for a while I would recommend using something on the paint first, like 3M low-tack painter's tape.
You can absolutely use this to clean a black car but you want to make sure you clean them frequently!
As long as you wash it out when it's done it will last a very long time!
Old 06-06-2012, 11:20 AM   #6
1954 Belair-man
1954 Belair-man's Avatar
Drives: 2010 Camaro IOM 1SS M6
WHAT?? A razor blade?? A flat head screwdriver?? Your just kidding right?
1954 Belair-man is offline   Reply With Quote
Old 06-06-2012, 11:54 AM   #7
Todd@Autopia
Well if he is serious then I want pictures!!!
Old 06-06-2012, 11:59 AM   #8
Stinkpickle
The real tough ones, those suckers get the butane torch!
I like this thing, I want!
Sent from my Galaxy Nexus using Tapatalk 2
Old 06-06-2012, 12:02 PM   #9
Vengeance Graphix
Vengeance Graphix's Avatar
Drives: 2010 IOM 2SS/RS
lol
+1
Old 06-06-2012, 12:13 PM   #10
1954 Belair-man
You had me going for a minute there!
