Old 06-05-2012, 09:54 PM   #1
DougDanger
Drives: 2011 2SS RS
line lock switch locations
Where did you guys put your line lock switches?
I see some power switches on A pillar and lock switch on shifter shaft.
Any other ideas for Auto trans?
DougDanger is offline   Reply With Quote
Old 06-05-2012, 09:57 PM   #2
jesserayjames
jesserayjames's Avatar
Drives: Drives a 2012 IOM 2SS/RS 6M
If I had a automatic, might put mine on console next to the shifter........................................... .........
CAMARO 2SS/RS 6M
jesserayjames is offline   Reply With Quote
Old 06-05-2012, 10:09 PM   #3
DougDanger
Drives: 2011 2SS RS
Just thinking of a practical place considering keeping hands and arms in a reasonable comfortable position during burnout, since this is new to me.
Old 06-05-2012, 10:15 PM   #4
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
I'd like some ideas also.
chevy 3 is offline   Reply With Quote
Old 06-05-2012, 11:04 PM   #5
Parag
Drives: 2010 camaro 2SS LS3
Most use the cruise control buttons
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline   Reply With Quote
Old 06-05-2012, 11:34 PM   #6
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Here is where the power switch is, and the activation switch is the horn button...
Turn this switch on, the blip the horn... If the horn works, the line lock isn't...If no horn, then you're good to go...
Press the brake, push the horn and get with it... when you're ready to roll out, just release the horn and hold the steering wheel...
Old 06-05-2012, 11:51 PM   #7
JM10
Se habla español
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
I plan to do this:
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 06-06-2012, 12:21 AM   #8
kpwalls06
Cory
kpwalls06's Avatar
Drives: 2010 Camaro 2SS/RS M6;
I mounted mine like the photo JM10 posted. Works great, and I actually like the way they look right there. Plus I have a manual, so it keeps my hand close to the shifter.
kpwalls06 is offline   Reply With Quote
Old 06-06-2012, 12:48 AM   #9
Quick
Quick's Avatar
Drives: 2012 Camaro SS 45th
I was going to buy one of those shifter handle with the paddle shift buttons and use those switches but gave up on the idea of using a line lock.
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh...
Quick is offline   Reply With Quote
Old 06-06-2012, 02:59 AM   #10
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
I put the master switch under the dash beneath the steering wheel and the momentary switch in the cigarette lighter location. Completely stealth and well within reach. Nothing can accidentally triggered either.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
Old 06-06-2012, 06:40 AM   #11
CFD
Drives: 2SS/RS L99 BLACK
The pistolgrip shifter doesn't have switches for line lock and I don't think you can use the tap shist switches for this purpose. Most who use my shifters with line lock or nitrous for drag racing use this one.
CFD is offline   Reply With Quote
Old 06-06-2012, 08:11 AM   #12
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Also another thread here about this:
http://www.camaro5.com/forums/showthread.php?t=179854
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 06-06-2012, 01:46 PM   #13
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
I use the Cruise Cancel as the temporary switch. Then I hid the power switch inside the AC duct to the left of the steering wheel. Unless you look for it, you don't even know it's there.
Three of Swords is offline   Reply With Quote
Old 06-06-2012, 09:27 PM   #14
DougDanger
Drives: 2011 2SS RS
Did you use the cruise cancel because it is not a data line?
Do you have the wiring diagram?
