BeckyD @ James Martin Chevy
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Texas > Local Marketplace
Old 06-05-2012, 11:00 PM   #1
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
Talking No2 Kit and More
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!
PM ME for Extreme Bundle discount! All offers will be considered!
or individual priced as the following:
Lingenfelter RPM Limiter Timing Retard Launch Controller GM LS Engines
LNC-2000 Adjustable RPM Limiter & Timing Retard Controller 2 Step
My loss your gain I paid $300 shipped. Im selling it for $250
Sometimes referred to as a 2-step or launch controller, the LNC-2000 adjustable RPM limiter and timing retard controller can be used to provide consistent launch RPM off the line in drag racing and other standing start racing applications. In turbocharged applications the LNC-2000 can also be used to retard the timing in order to build more boost at the line.
The LNC-2000 can also be used as an adjustable individual cylinder RPM limiter, providing reliable and fast acting spark based engine RPM limit control. This is especially useful in vehicles that have auxiliary fuel control systems where it is not possible to make sure that both the factory ECM/PCM and the auxiliary systems both turn off fuel at exactly the same time. If the two don’t completely cut fuel at the same time you will run lean when the one system cuts off the injectors, risking severe engine damage.
The Timing Retard capabilities of the LNC-2000 can be used to retard timing by up to 15 degrees. For nitrous oxide applications the timing retard can be activated using the dedicated timing retard activation input to the LNC-2000. In turbocharged and supercharged engines the amount of retard can be controlled by the boost level using the 3 bar MAP sensor input. The LNC-2000 can also be used to retard the timing at the line to build boost in turbocharged vehicle applications with or without the launch control RPM active. The Timing Retard function can be used by itself or while the Launch Control RPM limit function is active.
Please note - although launch controllers like the LNC-2000 are often referred to as 2-step controllers, they are not true 2-step controllers. A 2-step has a high and a low RPM limit function with a switch of some type enabling one setting or the other. The LNC-2000 only has one RPM limit setting so if you are using the LNC-2000 as a launch control RPM limiter, you will need to use the factory ECM/PCM as the engine maximum RPM limiter engine speed governor.
The RPM limiter function of the LNC-2000 acts by disabling spark to individual cylinders and not fuel like most production RPM limiters so the 2-Step/Launch Control function is not meant for use on the street or for use on cars equipped with catalytic converters. The 2-Step/Launch Control function of the LNC-2000 is only for use at the race track on race vehicles not equipped with catalysts. Failure to follow these precautions can result in premature catalyst failure.
DO NOT operate the engine with the LNC-2000 RPM limit active for extended periods of time. Due to the raw fuel in the exhaust when the RPM limit is active, a risk of backfiring exists if you do so.
GM LS2 EFI NITROUS KIT
I paid $750 shipped. Im selling for $400 OBO. It also comes with a NX PURGE Solenoid.
The NOS LS2 plate system uses a billet plate with no spray bars. This unique design allows better atomization which prevents fuel puddles in your Manifold and provides the best cylinder to cylinder distribution for maximum power. This is no ordinary low HP kit. The plate and Solenoids supplied will easily support 200HP.
GM LS2 EFI Nitrous System Plate Design Adjustable up to 200 HP
NX Stand Alone Fuel System 15004
This kit cost me $730 Shipped. Im selling for $500
The Nitrous Express SAFE (Stand Alone Fuel Enrichment) system improves the performance of any nitrous system. The SAFE system includes a one gallon, high strength, composite fuel cell that can be mounted in most factory battery trays without modification. When used with Gasoline, this system will support up to 800 nitrous horsepower. When used with Methanol, this pump will support will support up to 400 nitrous horsepower. When used with race gas or methanol, the need to retard timing is significantly reduced. Often on V8 engines using nitrous boosts of 150 horsepower and above, zero timing retard is required. The SAFE system reduces the need to upgrade OEM fuel pumps, and will completely eliminate pressure drop at the fuel rail in EFI vehicles.
View Large Download
Nitrous Outlet Heated 10lb/15lb Nitrous Bottle Bracket (Requires 6AN main feedline)
View Large Download
Nitrous Outlet Bottle Heater
I paid $230. Im selling for $150
Nitrous Outlet billet, heated bottle brackets provide the cleanest install and best function possible. No other bottle heater transfers heat as fast and reliably as this one of a kind bottle heater.
  • Nitrous Outlet 6 AN automatic billet, heated bottle bracket.
  • Comes complete with bottle heater/billet bottle bracket, adjustable pressure switch, heavy duty relay, relay harness, wire and hard ware.
  • Designed to work with systems that use a 6 AN main feed line.
  • 225 Watts, 13 Volts, 17.31 Amps.
  • Works with all brand nitrous systems
Nitrous Outlet Bottle Braket
I paid $175. Im selling For $100
The 2010 Camaro Nitrous Bottle Mount provides a solid mounting area using factory bolting location so that you will not have to drill holes in the car.
  • Machined from 1/4in. thick aluminum plate and powder coated black.
  • Designed to work with two short style stainless steel bottle brackets or the Nitrous Outlet heated bottle bracket.
  • No drilling or modifications required.
  • Ease of installation and removal.
  • Made in the USA!
NX Remote Botlle Opener
I paid $280. Im selling for $200
moiy1983 is offline   Reply With Quote
Old 06-06-2012, 12:44 AM   #2
moiy1983
moiy1983's Avatar
Ohh nd the Nos plate kit will come with the msd window switch. Thanks!
Old 06-06-2012, 01:12 AM   #3
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
PM sent
KnightRiderSS is offline   Reply With Quote
Old 06-06-2012, 08:38 AM   #4
moiy1983
moiy1983's Avatar
Originally Posted by KnightRiderSS View Post
PM sent
PM Sent. Thanks!
Old 06-06-2012, 04:23 PM   #5
Ivan @ Southwest Speed
In on the N2O!!
PM Sent!
Ivan
Old 06-06-2012, 06:36 PM   #6
moiy1983
moiy1983's Avatar
Originally Posted by Ivan @ Southwest Speed View Post
In on the N2O!!
PM Sent!
Ivan
PM Answered!
Old 06-06-2012, 08:24 PM   #7
Mine!!
Thanks sir
Ivan
Old 06-06-2012, 10:12 PM   #8
beaSSt 2011
Drives: 2011 SS M6
Pm.
beaSSt 2011 is offline   Reply With Quote
Old 06-07-2012, 01:35 AM   #9
moiy1983
moiy1983's Avatar
SALE pending on:
NOS Kit
Old 06-07-2012, 02:38 PM   #10
beaSSt 2011
Drives: 2011 SS M6
Good guy to deal with.
Old 06-07-2012, 03:02 PM   #11
moiy1983
moiy1983's Avatar
NX stand alone fuel system sold. Thanks a bunch!
Old 06-08-2012, 03:02 PM   #12
moiy1983
moiy1983's Avatar
Bump
LNC-2000 still availible! Pefer local pick up.
Old 06-09-2012, 12:36 AM   #13
Bump for great service and communication! Buy with confidence!
Ivan
Old 06-09-2012, 06:10 PM   #14
moiy1983
moiy1983's Avatar
NO2 kit Sold!
Stand alone fuel system Sold!
Bottle bracket and opener, heater sold!
Sale pending on LNC-2000
