Old 06-06-2012, 08:25 PM   #1
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
Black Crud On Wheels?
What is this crap on my wheels? I tried using a Grime Degreaser, Tire Degreeser , Bug Remover. On my Wheels, This Sh** just wont come off! WTH? is this, i never use to have these before, scrub and scrub does nothing. Help? This wash i used a pressure washer, still didnt do anything.
Hellfighter is offline   Reply With Quote
Old 06-06-2012, 08:27 PM   #2
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
Looks like baked on iron into the clear coat. Try a polish on it. Should come right off.
Iomcamaro is offline   Reply With Quote
Old 06-06-2012, 08:29 PM   #3
Hellfighter
What you mean baked on iron? These are brand new wheels, and they are powder coated i believe, not sure what kind of polish works on powder coated wheels, i have one from CG for all kinds of wheels and tried it and it did nothing.
Old 06-06-2012, 08:52 PM   #4
Iomcamaro
Iomcamaro's Avatar
I bet those wheels are clear coated. And baked on iron is from excessive heat and brake dust. You could try an iron decontaminating wheel cleaner such as sonax or Wolf's Deironizer Gel.
Old 06-06-2012, 08:59 PM   #5
Hellfighter
which one would be the best for that?
Old 06-06-2012, 09:04 PM   #6
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
I'd actually try a clay bar first.
Saw a very similar looking speckling in almost the exact same spot on a set of wheels I recently cleaned up. Cleaners and scrubbing, nothing seemed to make any change.
Hit it with clay and it came off easily.
Old 06-06-2012, 09:06 PM   #7
Iomcamaro
Iomcamaro's Avatar
I just figured if Polish didn't bring it off that clay wouldn't.
Old 06-06-2012, 09:06 PM   #8
Iomcamaro
Iomcamaro's Avatar
Try using a paint polish too. A metal polish won't do much for CC wheels.
Old 06-07-2012, 07:53 AM   #9
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
That looks like iron residue from high-temperature braking. This is actually a common occurrence on cars that are tracked/driving aggressively.
You basically have two options (in terms of chemical cleaners).
One, you can use a strong wheel acid. This is probably the fastest choice in removing baked on break dust, but acids can damage the clear coat of your wheels.
The second option, and my preferred method, would be to use a iron decontamination spray.
CarPro makes some EXCELLENT (ie extremely high-rated) iron decontamination sprays that are pH neutral. Either will make quick, safe work of those deposits (assuming they are in fact baked on iron). Check out these threads...
http://www.camaro5.com/forums/showth...ghlight=carpro
Old 06-07-2012, 08:32 AM   #10
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
what would the manufacturer of the wheel say about this issue vs him buying products to clean/fix it??
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 06-07-2012, 10:46 AM   #11
Hellfighter
I bought my wheels from Alex @ Speeddepot, didnt get them directly from TSW, as far as aggression goes, this car is just DD to work and home and around, i dont drive my v6 like i am at a track.
Old 06-07-2012, 11:59 AM   #12
Todd@Autopia
Then start driving it!!!
That is the most common cause of baked on iron. Did the wheels come like this or has this occurred since ownership?
Old 06-07-2012, 12:34 PM   #13
Hellfighter
had wheels for maybe a month or little over that. And Daily Drove Since, wheels came with couple minor tiny scratches but thats about it, and some dust.
Old 06-07-2012, 12:36 PM   #14
Hellfighter
So i will try 3 options, Clay, Polish, if all fails i wanna try that baked iron remover, any good prices going for those yet?
