JUICEDMOTORSPORTS
Old 06-12-2012, 08:45 AM   #29
LoPerformance Motorsports
Loperformance Motorsports
LoPerformance Motorsports's Avatar
Drives: 2011 2LT
Originally Posted by Wuiquen View Post
So totally necessary to remove the rear fender to do this?? or can I just remove the liner in the back and be able to get to the reverse light??
Yes it is totally necessary to remove the rear of car. But all you do is take screws out on the fender liner, you do not have to remove it. you have to take the screws out to be able to pull the sides of the rear valance off.
LoPerformance Motorsports is offline   Reply With Quote
Old 06-12-2012, 03:32 PM   #30
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
Ok, looks bright when looking at it, but no one has shown the light splash behind the car. What does it look like behind you?!
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 06-12-2012, 05:32 PM   #31
Drives: 2011 2LT
I'll will try and get some for ya. I was really wanting the difference in color more than anything. These will be nothing like the one that AAC sells, im sure. But for $10 they are better than stock ones.
Old 06-12-2012, 05:37 PM   #32
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
The light field should be same or better than stock at those brightness levels... The light you see in the pics is bouncing off of the internal reflectors in the housing, not directly from the chip... If that makes sense.
Toasty is offline   Reply With Quote
Old 06-12-2012, 08:39 PM   #33
Aceman1120
Aceman1120's Avatar
Drives: Orange Metallic RS
I'm guessing..No error codes?
Http://www.LaFiestaNy.com "Seek and You Shall Find"
Aceman1120 is offline   Reply With Quote
Old 06-12-2012, 09:07 PM   #34
Drives: 2011 2LT
No, I have not had any error codes at all. I have changed out every light on this car,except for the front blinker bulbs. That will be next. Changed every light on car to LED"S. I will keep you posted if I get any error's!!!!
Old 07-30-2012, 06:20 PM   #35
linvol20
linvol20's Avatar
Drives: 2013
so what bulb and from where should i buy if i just want to plug and play?
linvol20 is offline   Reply With Quote
Old 07-30-2012, 06:53 PM   #36
Toasty
Toasty's Avatar
like do what the OP did? He bought a 194 syle LED and pulled the base off. That's as close to plug and play as you get, without going to the AAC housing/bulb combo
Old 01-01-2013, 07:15 PM   #37
butters
It's not the batmobile!
butters's Avatar
Drives: 2012 Camaro LFX
Do you have a link to where you purchased the bulbs from?
butters is offline   Reply With Quote
Old 01-01-2013, 10:18 PM   #38
blackswan
blackswan's Avatar
Drives: Yes
Just wondering if you have the backup camera and if the camera adapts to the bright light OK at night?
blackswan is offline   Reply With Quote
Old 01-03-2013, 04:59 PM   #39
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
I just did this mod and it is awesome! Thanks for posting this! Wasnt difficult at all. I ended up using the same 25 led bulb. Name:  ImageUploadedByTapatalk1357253930.586368.jpg
Size:  50.8 KBName:  ImageUploadedByTapatalk1357253941.100848.jpg
I tried taking a pic of the output but its hard to pick it up on my iphone camera. However it is definitely much brighter and well worth doing.
I want to post a little tip
To get the leds in the correct way. You should line up the negative side of the led with the side of the original harness that has the writing on it.
Also i'd advise you guys to put a dab of silicon to hold the new led in place in the old harness and let it dry for 20-30 mins because i didnt the first time and it came lose after i finished putting it all back together -___-
Link to the leds i used.
http://www.ebay.com/itm/400319442582
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 01-15-2013, 08:13 PM   #40
CausticGuy
Drives: 2010 Chevrolet Camaro SS/RS
Cool mod guys! I'll be doing this too once it warms up a bit
CausticGuy is offline   Reply With Quote
Old 01-25-2013, 02:22 PM   #41
Asian Zero
Asian Zero's Avatar
Drives: 2010 IBM Camaro 1LT RS
Alright i ordered in a pair 42 SMD bulbs now Im just waiting for it to be warm to get my bumper off. Anyways...i just had a question about putting the LED into the stock bulb location. did you guys leave the stock bulb base in there and just replace it with the LED or did you take out the base and plug the LED directly into the bulb harness?
Asian Zero is offline   Reply With Quote
Old 01-25-2013, 03:45 PM   #42
mbrusco103
mbrusco103's Avatar
I separated the stock bulb from its stock base, you have to really pull and tug on it but it does come out. Then i guided the leds metal prongs through the base and put some silicon to keep it in place. Let it dry for a bit then plugged it right in to the stock harness. Good luck its fairly easy to do!
