Caryle Racing
Old 06-06-2012, 11:58 PM   #1
blackswan
blackswan's Avatar
Drives: Yes
Pinging on 87
Anyone else? Happens on all brands on moderate acceleration and using 93 it runs great.
blackswan is offline   Reply With Quote
Old 06-07-2012, 05:58 AM   #2
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Haven't noticed any.
PalmerGA is offline   Reply With Quote
Old 06-07-2012, 06:26 AM   #3
Jonzmaro
Jonzmaro's Avatar
Drives: 2013 RS M6
Not a hint on mine. It's an auto, and in 95 degree weather, AC on....no pinging whatsoever on 87. I have only run Shell in it thus far.
Jonzmaro is offline   Reply With Quote
Old 06-08-2012, 12:04 AM   #4
Henry G.
Drives: 2012 Camaro LFX,CAI,DynomaxVT,RX CC
Turn up the radio it wont bother you. Seriously I have put 91 (super here in Kalifornia) since new, its about $3.90 more a tank, I didnt buy this beautiful car to chinze it with cheap gas. Hell I even put 91 in my Toyota Yaris but I really drove the shit outta that car it earned it.
Henry G. is offline   Reply With Quote
Old 06-08-2012, 12:07 AM   #5
theragtopguy
Lifetime Phillies Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
I used to run 87 without any issues, but she seemed kind of sluggish. So I started running Mid-grade 89 and she really likes that, so that's what I run.
No pinging ever!!
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
One of 82 GF Ragtops built in '15 out of 811 Total
Member of SEPA5+
theragtopguy is offline   Reply With Quote
Old 06-08-2012, 12:38 AM   #6
sprint17
Drives: 2012 ls
i tried 87 in mine once, it ran rough on the top end. i been putting shell 93 in ever since and it runs very smooth.
sprint17 is offline   Reply With Quote
Old 06-08-2012, 09:27 AM   #7
Kmorpheus
Drives: Green Dream Machine
I am not sure you should hear pinging, if the ECU is doing its job and monitoring the Knock Sensors it should be adjusting your timing. You will feel a loss of power but you should not be able to hear pinging.
Kmorpheus is offline   Reply With Quote
Old 06-08-2012, 12:14 PM   #8
bagelluvr
bagelluvr's Avatar
Drives: 2017 SS Camaro
No pinging ever!!
Same here....
bagelluvr is offline   Reply With Quote
Old 06-09-2012, 08:17 PM   #9
Spanky1
Drives: 2017 2SS Summit White Camaro M6
I always heard and read that any higher octane gas other than what was recommended in the owner's manual was a waste of money and doesn't improve performance.
Spanky1 is offline   Reply With Quote
Old 06-09-2012, 09:27 PM   #10
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
This is correct...unless the vehicle can advance timing to take advantage of the higher octane, which is the only thing an engine not designed for premium fuel can possibly do.
Higher octane fuel has a higher point at which ignition occurs. Typically, engines using premium when it is not designed to do so results in higher emissions because of more unburned fuel.
Your opinion, and mileage, may vary. I use 87 in mine without a second thought. I also do not lug my engine.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 06-10-2012, 08:27 AM   #11
SC2150
The LLT & LFX have 11.3-1 CR so you will get more power, better fuel economy out of it running 93. The ecu will retard timing when running 87 (the 87 is only for marketing as yes, the engine can and will run fine on 87, but 91-93 it will shine).
Even though you are fine running 87, I would not think of it as the spark pulled can be 4-6 degrees and that is alot of power & economy left on the table.
Now, a 8.5-1 cr motor anything above 87 IS a waste of money.
Old 06-10-2012, 11:26 AM   #12
JohnnyBfromPeoria
Have any data to support the above? I would be interested to see it. It does make sense to say the engine may be pulling off advance, but how can that be demonstrated?
John B.
Old 06-10-2012, 11:01 PM   #13
Henry G.
I would be curious too about that, however putting premium in your Camaro is one of those feel good things suckers like me buy into...so I'll continue to do it as its fairly cheap
Old 06-10-2012, 11:40 PM   #14
JohnnyBfromPeoria
I understand it's not much more to have to use 91 octane. I'd just like to see a link to some evidence that it'll take advantage of it and not just add more unburned residue in my cats and the rest of my exhaust.
The marketing thing telling people to use 87 octane makes sense. It would make sense to also not include a note, buried in the owner's manual, that higher performance could be expected from the use of 91 in the LFX. That might put some people off.
I have (totally unrelated example) a '95 Mitsubishi Montero SR that says "Premium Fuel Recommended" on the inside of the gas door. The manual says regular can be used, but a slight loss of performance will be noticed (pulls timing via 2 knock sensors). I use premium in that one, every time.
John B.
